as knowing the voltage, the LED and how to calculate the resistance?
Hello, I want to know how I can calculate the voltage of the LEDs, I have not the datasheet,
and calculate the resistance-
I know the LED is 5mm and 20mA
The diameter of the LED is useless information. Ohm's law (V = I * R) tells you how to calculate R, knowing V and I.
Another value that you need to calculate the resistance is the forward voltage.
Assuming that voltage is 3V, the resistance will be:
R = V / I = (5 - 3) / 20mA = 2 / 20 mA = 0,1 kOhm = 100 Ohm
I believe that 20mA is to much current (or to much bright).
EDIT: I don't see that you are asking for the voltage. The voltage is a value that is given in the data sheet of your LED.
luisilva:
but how to calculate the voltage of the led?
For the first datasheet that I found in google:
http://www.msc-ge.com/download/opt/datasheets/3294-15-t2c9-1hmb.pdf
You can find in page 2 3 that the forward current is between 3 and 4V for a current of 20mA.
EDIT: For different values of current you have the graph "Forward Current vs. Forward Voltage" in page 6.
luisilva:
but the information is not accurate for my leds.
there is a practical way of knowing which is the, precise voltage led up correctly?
Yes. Using the value inaccurate (100 Ohm). And after that take measures with a multimeter.
luisilva:
so?
by chance the resistance is 100 :slight_smile:
Is that a question?
as resistance is connected properly?. do I need one or two resistance?
Or a 200ohm??
You need two resistances.
You have to measure what the voltage drop is for your LED, there is absolutely no way to calculate it from ohms law.
Your example:-
by chance the resistance is 100 smiley
Is incorrect.
Where did that 3 come from?
That should be the forward voltage that you have to measure if you don't have the data sheets. You measure the forward voltage drop at various currents ( that means using different resistors and measuring the current ) and plot a graph and join up the dots. Then with the graph look up the current you want to use and see what the forward voltage is.
Grumpy_Mike:
Your example:-
Is incorrect.
First of all, I don't know why you can have 2 LED's connected at the same pin (it just don't make sense).
Second, I don't know where do you learn electronics and how you can say that the 2 assemblies (with one and two resistors) are equivalents.
Third take a look to this. Your drawings are very, very crappy.
luisilva:
:D.
I have to connect 13 leds arduino. Two. By pin
Why 2 by 2? If you are using 20mA per LED and 2 per pin and 13 LED's, maybe with a little lucky you can burn your Arduino.
each pin is 40mA. two LEDs per pin 20mA* 2 = 40mA
you say, that does not use pin 2 and 13?
I think that is too much current for Arduino, and I think that the "40mA" is too close to the limit of the Arduino. Are you 100% sure that the "40mA" are not 42mA, for example?
luisilva:
no, I'm not sure. neither as check
Bi-pin LEDs
see attachment
