AS5600 Works with Arduino Mega but Not with Due – Need Help!
Hi everyone,
I’ve been using the AS5600 magnetic encoder with Arduino Mega, and everything works fine. However, when I switch to Arduino Due, I run into problems. I’ve tried the following:
  1. Pull-up resistors: I’ve used values like 4.7k, 10k, 20k, and even up to 47k ohms, but the AS5600 still doesn’t work properly with Due.
  2. Power: The AS5600 is powered with 3.3V.
  3. Communication: I’m using I2C communication, and I’ve verified that the Due is able to scan and find the device on the bus. But when reading data, I get corrupted values or the device doesn’t respond.
The same setup works flawlessly with the Mega. What could be the issue with Due? Any suggestions would be greatly appreciated!
#include <Wire.h>
#define AS5600_ADDRESS 0x36
#define RAW_ANGLE 0x0C
#define DR_PIN 26  // Direction pin for determining rotation direction
#define PQO_PIN 27  // Pin connected to PQO pin of AS5600
uint16_t zeroOffset = 0;
bool firstReading = true;
int32_t cumulativeAngle = 0;
int16_t previousAngle = 0;
bool directionNegative = false;
  Serial.begin(38400);  // Set the baud rate to 38,400 bps
  Wire.begin();
  pinMode(DR_PIN, INPUT);  // Set the direction pin as input
  pinMode(PQO_PIN, OUTPUT);  // Set the PQO pin as an output
  digitalWrite(PQO_PIN, HIGH);  // Keep PQO pin HIGH by default
void zeroAngle() {
  digitalWrite(PQO_PIN, LOW);  // Trigger zeroing on AS5600
  delay(10);  // Short delay to ensure zeroing is registered
  digitalWrite(PQO_PIN, HIGH);  // Return PQO pin to HIGH
  cumulativeAngle = 0;  // Reset the cumulative angle to zero
  firstReading = true;  // Reset the first reading flag to set a new zeroOffset
  // Read the current angle from the AS5600
  uint16_t currentAngle = readAS5600Angle();
  // Zero the angle at startup
  if (firstReading) {
    zeroOffset = currentAngle;
    previousAngle = 0;  // Initialize previous angle to zero
    directionNegative = digitalRead(DR_PIN) == LOW;
    firstReading = false;
  // Calculate the relative angle considering the zero offset
  int16_t relativeAngle = (int16_t)(currentAngle - zeroOffset);
  // Handle wrap-around from 0-360 degrees
  int16_t deltaAngle = relativeAngle - previousAngle;
  if (deltaAngle > 1800) {
    cumulativeAngle -= 4096;  // Handle wrap-around from 0 to 360 degrees
  } else if (deltaAngle < -1800) {
    cumulativeAngle += 4096;  // Handle wrap-around from 360 to 0 degrees
  // Apply the delta to the cumulative angle
  cumulativeAngle += deltaAngle;
  // Store the previous angle for the next loop iteration
  previousAngle = relativeAngle;
  // Apply direction (if directionNegative is true, make the angle negative)
  int32_t finalAngle = directionNegative ? -cumulativeAngle : cumulativeAngle;
  // Convert the cumulative angle to degrees (12-bit resolution)
  float angleInDegrees = (finalAngle * 360.0) / 4096.0;
  // Send the time and angle as a comma-separated string
  unsigned long currentTime = millis();
  Serial.print(currentTime);
  Serial.print(",");
  Serial.println(angleInDegrees);
  // Wait 50 microseconds before the next reading
  delayMicroseconds(50);
uint16_t readAS5600Angle() {
  Wire.beginTransmission(AS5600_ADDRESS);
  Wire.write(RAW_ANGLE);
  Wire.endTransmission();
  Wire.requestFrom(AS5600_ADDRESS, 2);
  uint16_t angle = 0;
  if (Wire.available() == 2) {
    angle = Wire.read() << 8;
    angle |= Wire.read();
  return angle;
It is the fact that the Due only produces a 3V3 signal, and you need it to produce a 5V signal to drive the sensor.
None of the things you have tried will work,
You need a level shifter, either one made of FETs like the AdaFruit one. Or two inverting transistors in series.
Like this:-
Mike
Thank you for the suggestion. However, the sensor works fine with the Arduino Mega when powered by 3.3V, without requiring any level shifter. This is why it's puzzling that it doesn't behave the same with the Due. Could there be another issue specific to the Due that's causing the problem?
Which is why I suggested that solution.
Does not compute. I don't think you can come to that conclusion from that set of "facts".
You seem to be ignoring the current output capacity from the Due pins.
Still your choice to ignore a possible solution. I have little more to add.
Hi, @mofo83
Welcome to the forum.
Where are you getting the 3V3 supply for the 5600?
If from the DUE, check the specs for the DUE and the current needed for the 5600.
Do you have a DMM? Digital MultiMeter?
Tom.. :smiley: :+1: :coffee: :australia:
