ASCII decimal to Text
Hello!
I am currently working on a project to print a .txt file to an Arduino using the Serial COM port. In windows I configured a Generic/Text printer which prints ASCII values to a specific COM port.
When I try to print the .txt file, it sends ASCII values (decimal) to the Serial port and the Arduino reads it without a problem.
Now I would like to convert the decimal ASCII values to strings or characters so I can output a text on my OLED screen.
My code looks like this:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET LED_BUILTIN // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES     20 // Number of snowflakes in the animation example
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000
int incoming;
void setup()   {
  // by default, we'll generate the high voltage from the 5v line internally! (neat!)
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  // init done
  // Show image buffer on the display hardware.
  display.display();
  //delay(2000);
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(10, 0);
  display.clearDisplay();
  display.println("READY");
  // invert the display
  display.invertDisplay(true);
  //delay(1000);
  display.invertDisplay(false);
  //delay(1000);
  display.display();
  //delay(2000);
    if (Serial.available() > 0) {
            // read the incoming byte:
            incoming = Serial.read();
            display.print("I received: ");
            display.println(mysrr);
            display.display();
    delay (500);
The output of this code on my OLED screen is:
"I recieved: 10" and the decimal number changes to other decimal numbers every 0,5 second until the .txt is done printing characters.
My question:
Can someone help me to write an ASCII decimal to text converter so I can print "Test" through the Serial port and have my OLED say "Test" in stead of decimal numbers?
Thanks in advance!
char incoming; You're welcome
Try printing the alphabet from A to Z
Do you see a pattern in the numbers ?
Have you Googled ASCII ?
Hey thanks for the quick replies guys, really appreciate it :slight_smile:
It works now!
The only thing I am still struggling with is how to put the characters into a string to form a word or phrase. Could you help me out with that?
Try this
samsambenben:
Elaborate your requirements with an example.
It works now!
Please post "it"
