I could use some programming assistance if someone would be so kind. I will post the code and then explain the issue.
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::PAROLA_HW
#define MAX_DEVICES 8
#define PAUSE_TIME 5000
#define SCROLL_SPEED 50
#define CLK_PIN 13
#define DATA_PIN 11
#define CS_PIN 10
char Day = "Monday";
// HARDWARE SPI
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// SOFTWARE SPI
//MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
void setup(void)
// initialise the LED display
P.begin();
P.setZoneEffect(0, true, PA_FLIP_LR);
void loop(void)
//if (Day == "Monday") {
char *msg[] = {"Test text A","Test text B",};
static uint8_t cycle = 0;
if (P.displayAnimate())
// set up the string
P.displayText(msg[cycle], PA_CENTER, SCROLL_SPEED, PAUSE_TIME, PA_PRINT, PA_NO_EFFECT);
// prepare for next pass
cycle = (cycle + 1) % ARRAY_SIZE(msg);
I would like to include the code: char *msg[] = {"Test text A","Test text B",}; within an if statement. But when I do, i get the following error: 'msg' was not declared in this scope
Could someone please explain how to correct this error?
Thank you in advance for your assistance.
Scott
