AsyncMQTT_Generic Library. Now supports ESP32, ESP8266, RP2040, WT32_ETH01, Portenta_H7 (WiFi/Ethernet), Teensy 4.1, STM32 + LAN8742A/LAN8720
AsyncMQTT_Generic library GitHub release
How To Install Using Arduino Library Manager
Features
This AsyncMQTT_Generic library is based on and modified from Marvin Roger's async-mqtt-client Library, to provide support to many more boards besides ESP32/ESP8266, such as STM32F, Portenta_H7, etc. boards. Those supported boards can be used with ESP8266/ESP32’s WiFi, LAN8742A Ethernet, Portenta_H7 WiFi/Ethernet.
Why Async is better
  • Using asynchronous network means that you can handle more than one connection at the same time
  • You are called once the request is ready and parsed
  • When you send the response, you are immediately ready to handle other connections while the server is taking care of sending the response in the background
  • Speed is OMG
  • Easy to use API, HTTP Basic and Digest MD5 Authentication (default), ChunkedResponse
  • Easily extensible to handle any type of content
  • Supports Continue 100
  • Async WebSocket plugin offering different locations without extra servers or ports
  • Async EventSource (Server-Sent Events) plugin to send events to the browser
  • URL Rewrite plugin for conditional and permanent url rewrites
  • ServeStatic plugin that supports cache, Last-Modified, default index and more
  • Simple template processing engine to handle templates
Currently supported Boards
This AsyncMQTT_Generic library currently supports these following boards:
  1. ESP32
  2. ESP8266
  3. WT32_ETH01 (ESP32 + LAN8720A) from v1.1.0
To-be-supported Boards
  1. STM32F/L/H/G/WB/MP1 boards with built-in Ethernet LAN8742A such as :
  1. STM32F4/F7 boards using Ethernet LAN8720 such as :
  • Nucleo-144 (F429ZI, NUCLEO_F746NG, NUCLEO_F746ZG, NUCLEO_F756ZG)
  • Discovery (DISCO_F746NG)
  • STM32F4 boards (BLACK_F407VE, BLACK_F407VG, BLACK_F407ZE, BLACK_F407ZG, BLACK_F407VE_Mini, DIYMORE_F407VGT, FK407M1)
  1. Portenta_H7 using either Murata WiFi or Vision-shield Ethernet
Changelog
Releases v1.1.0
  1. Add support to WT32_ETH01 (SSL and non-SSL)
  2. Add examples for WT32_ETH01
Releases v1.0.1
  1. Fix Library Manager warnings
  2. Suppress all compiler warnings
  3. Optimize library code by using reference-passing instead of value-passing
Initial Releases v1.0.0
  1. Initial porting and coding to support ESP32 (SSL and non-SSL) and ESP8266 (non-SSL)
Examples
1. For ESP32
  1. FullyFeatured_ESP32
  2. FullyFeaturedSSL_ESP32
2. For ESP8266
  1. FullyFeatured_ESP8266
3. For WT32_ETH01
  1. FullyFeatured_WT32_ETH01
  2. FullyFeaturedSSL_WT32_ETH01
Debug Terminal Output Samples
1. FullyFeatureSSL_ESP32 on ESP32_DEV
This is terminal debug output when running FullyFeaturedSSL_ESP32 on ESP32_DEV connecting to broker.emqx.io secured MQTT server (port 8883).
Starting FullyFeatureSSL_ESP32 on ESP32_DEV
AsyncMQTT_Generic v1.1.0 for ESP32 core v2.0.0+
Connecting to Wi-Fi...
WiFi ready
WiFi STA starting
WiFi STA connected
WiFi connected
IP address: 192.168.2.81
Connecting to MQTT...
Connected to MQTT broker: broker.emqx.io, port: 8883
PubTopic: async-mqtt/ESP32_SSL_Pub
Session present: 0
Subscribing at QoS 2, packetId: 1
Publishing at QoS 0
Publishing at QoS 1, packetId: 2
Publishing at QoS 2, packetId: 3
Subscribe acknowledged.
  packetId: 1
  qos: 2
Publish received.
  topic: async-mqtt/ESP32_SSL_Pub
  qos: 2
  dup: 0
  retain: 1
  len: 6
  index: 0
  total: 6
Publish received.
  qos: 0
  dup: 0
  retain: 0
  len: 10
  index: 0
  total: 10
Publish acknowledged
  packetId: 2
Publish received.
  qos: 1
  dup: 0
  retain: 0
  len: 6
  index: 0
  total: 6
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 6
  index: 0
  total: 6
  packetId: 3
2. FullyFeatureSSL_WT32_ETH01 on WT32-ETH01 with ETH_PHY_LAN8720
This is terminal debug output when running FullyFeaturedSSL_WT32_ETH01 on WT32-ETH01 connecting to broker.emqx.io secured MQTT server (port 8883).
Starting FullyFeatureSSL_WT32_ETH01 on WT32-ETH01 with ETH_PHY_LAN8720
WebServer_WT32_ETH01 v1.4.1 for core v2.0.0+
ETH starting
ETH connected
ETH got IP
IP address: 192.168.2.97
PubTopic: async-mqtt/WT32_ETH01_SSL_Pub
Session present: 0
Publishing at QoS 0
  packetId: 1
  qos: 2
Publish received.
  topic: async-mqtt/WT32_ETH01_SSL_Pub
  qos: 0
  dup: 0
  retain: 0
  len: 15
  index: 0
  total: 15
  packetId: 2
Publish received.
  qos: 1
  dup: 0
  retain: 0
  len: 6
  index: 0
  total: 6
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 6
  index: 0
  total: 6
  packetId: 3
Releases v1.2.0
  1. Add support to STM32F/L/H/G/WB/MP1 (without TLS/SSL) using built-in LAN8742A Ethernet, such as Nucleo-144, DISCOVERY, etc.
  2. Add examples for STM32
1. FullyFeature_STM32 on NUCLEO_F767ZI
This is terminal debug output when running FullyFeature_STM32 on STM32F7 NUCLEO_F767ZI connecting to broker.emqx.io MQTT server. The Ethernet loss was tested by disconnecting, then reconnecting the Ethernet cable.
Starting FullyFeature_STM32 on NUCLEO_F767ZI
AsyncMQTT_Generic v1.2.0 for STM32
Connected to network. IP = 192.168.2.118
Connected to MQTT broker: broker.emqx.io, port: 1883
PubTopic: async-mqtt/STM32_Pub
Session present: 0
Publishing at QoS 0
  packetId: 1
  qos: 2
Publish received.
  topic: async-mqtt/STM32_Pub
  message: STM32 Test3
  qos: 2
  dup: 0
  retain: 1
  len: 11
  index: 0
  total: 11
Publish acknowledged.
  packetId: 2
Publish received.
  message: STM32 Test1
  qos: 0
  dup: 0
  retain: 0
  len: 11
  index: 0
  total: 11
Publish received.
  message: STM32 Test2
  qos: 1
  dup: 0
  retain: 0
  len: 11
  index: 0
  total: 11
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 11
  index: 0
  total: 11
  packetId: 3
Ethernet disconnected   <==== Test disconnect Ethernet very short time
Ethernet reconnected.
Ethernet disconnected   <==== Test disconnect Ethernet long enough time to force MQTT disconnection
Disconnected from MQTT. <==== MQTT disconnected and reconnected
Session present: 0
Subscribing at QoS 2, packetId: 4
Publishing at QoS 0
Publishing at QoS 1, packetId: 5
Publishing at QoS 2, packetId: 6
  packetId: 4
  qos: 2
Publish received.
  qos: 2
  dup: 0
  retain: 1
  len: 11
  index: 0
  total: 11
  packetId: 5
Publish received.
  qos: 0
  dup: 0
  retain: 0
  len: 11
  index: 0
  total: 11
Publish received.
  qos: 1
  dup: 0
  retain: 0
  len: 11
  index: 0
  total: 11
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 11
  index: 0
  total: 11
  packetId: 6
Releases v1.2.1
  1. Add support to many STM32F4 and STM32F7 (without TLS/SSL) using LAN8720 Ethernet, such as F407xx, NUCLEO_F429ZI, DISCO_F746NG, NUCLEO_F746ZG, NUCLEO_F756ZG, etc.
  2. Add examples for STM32_LAN8720
1. FullyFeatured_STM32_LAN8720 on BLACK_F407VE
This is terminal debug output when running FullyFeatured_STM32_LAN8720 on STM32F4 BLACK_F407VE connecting to broker.emqx.io MQTT server.
Starting FullyFeatured_STM32_LAN8720 on BLACK_F407VE
AsyncMQTT_Generic v1.2.1 for STM32
Connected to network. IP = 192.168.2.132
Session present: 0
Publishing at QoS 0
  packetId: 1
  qos: 2
Publish received.
  qos: 2
  dup: 0
  retain: 1
  len: 11
  index: 0
  total: 11
  packetId: 2
Publish received.
  qos: 0
  dup: 0
  retain: 0
  len: 11
  index: 0
  total: 11
Publish received.
  qos: 1
  dup: 0
  retain: 0
  len: 11
  index: 0
  total: 11
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 11
  index: 0
  total: 11
  packetId: 3
Releases v1.3.0
  1. Add support to Portenta_H7, using either Murata WiFi or Vision-shield Ethernet
  2. Add examples for Portenta_H7_Ethernet and Portenta_H7_WiFi
1. FullyFeatured_PortentaH7_WiFi on PORTENTA_H7_M7
This is terminal debug output when running FullyFeatured_PortentaH7_WiFi on STM32H7 PORTENTA_H7_M7 using Murata WiFi, connecting to broker.emqx.io MQTT server.
Starting FullyFeatured_PortentaH7_WiFi on PORTENTA_H7_M7
AsyncMQTT_Generic v1.3.0 for Portenta_H7_M7
Connecting to SSID: HueNet1
Connected to SSID: HueNet1
Local IP Address: 192.168.2.134
Signal strength (RSSI):-37 dBm
PubTopic: async-mqtt/Portenta_H7_WiFi_Pub
Session present: 0
Publishing at QoS 0
  packetId: 1
  qos: 2
Publish received.
  topic: async-mqtt/Portenta_H7_WiFi_Pub
  message: Portenta_H7_WiFi Test 3
  qos: 2
  dup: 0
  retain: 1
  len: 23
  index: 0
  total: 23
  packetId: 2
Publish received.
  message: Portenta_H7_WiFi Test1
  qos: 0
  dup: 0
  retain: 0
  len: 22
  index: 0
  total: 22
Publish received.
  message: Portenta_H7_WiFi Test 2
  qos: 1
  dup: 0
  retain: 0
  len: 23
  index: 0
  total: 23
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 23
  index: 0
  total: 23
  packetId: 3
2. FullyFeatured_Portenta_H7_Ethernet on PORTENTA_H7_M7
This is terminal debug output when running FullyFeatured_PortentaH7_Ethernet on STM32H7 PORTENTA_H7_M7, using built-in Ethernet, connecting to broker.emqx.io MQTT server.
Starting FullyFeatured_PortentaH7_Ethernet on PORTENTA_H7_M7
Connected to network. IP = 192.168.2.133
PubTopic: async-mqtt/Portenta_H7_Ethernet_Pub
Session present: 0
Publishing at QoS 0
  packetId: 1
  qos: 2
Publish received.
  topic: async-mqtt/Portenta_H7_Ethernet_Pub
  message: Portenta_H7_Ethernet Test3
  qos: 2
  dup: 0
  retain: 1
  len: 26
  index: 0
  total: 26
  packetId: 2
Publish received.
  message: Portenta_H7_Ethernet Test1
  qos: 0
  dup: 0
  retain: 0
  len: 26
  index: 0
  total: 26
Publish received.
  message: Portenta_H7_Ethernet Test2
  qos: 1
  dup: 0
  retain: 0
  len: 26
  index: 0
  total: 26
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 26
  index: 0
  total: 26
  packetId: 3
[ATCP] setCloseError() to: Connection reset => -14
Session present: 0
Publishing at QoS 0
  packetId: 4
  qos: 2
Publish received.
  qos: 2
  dup: 0
  retain: 1
  len: 26
  index: 0
  total: 26
  packetId: 5
Publish received.
  qos: 0
  dup: 0
  retain: 0
  len: 26
  index: 0
  total: 26
Publish received.
  qos: 1
  dup: 0
  retain: 0
  len: 26
  index: 0
  total: 26
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 26
  index: 0
  total: 26
  packetId: 6
Releases v1.4.0
  1. Add support to Teensy 4.1 using QNEthernet Library
  2. Add example for QNEthernet
1. FullyFeatured_QNEthernet on TEENSY 4.1 using QNEthernet
This is terminal debug output when running FullyFeatured_QNEthernet on TEENSY 4.1, using built-in Ethernet with QNEthernet Library, connecting to broker.emqx.io MQTT server.
Starting FullyFeatured_QNEthernet on TEENSY 4.1
AsyncMQTT_Generic v1.4.0 for Teensy 4.1 QNEthernet
Initialize Ethernet using static IP => Connected! IP address:192.168.2.222
PubTopic: async-mqtt/Teensy41_QNEthernet_Pub
Session present: 0
Publishing at QoS 0
  packetId: 1
  qos: 2
Publish received.
  topic: async-mqtt/Teensy41_QNEthernet_Pub
  message: Teensy41_QNEthernet_Pub Test3
  qos: 2
  dup: 0
  retain: 1
  len: 29
  index: 0
  total: 29
  packetId: 2
Publish received.
  message: Teensy41_QNEthernet_Pub Test1
  qos: 0
  dup: 0
  retain: 0
  len: 29
  index: 0
  total: 29
Publish received.
  message: Teensy41_QNEthernet_Pub Test2
  qos: 1
  dup: 0
  retain: 0
  len: 29
  index: 0
  total: 29
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 29
  index: 0
  total: 29
  packetId: 3
Releases v1.5.0
  1. Add support to ESP8266 W5x00 using lwIP_w5100 or lwIP_w5500 library
  2. Add support to ESP8266 ENC28J60 using lwIP_enc28j60 library
  3. Add example FullyFeatured_ESP8266_Ethernet
  4. Update Packages' Patches
1. FullyFeatured_ESP8266_Ethernet on ESP8266_NODEMCU_ESP12E using ESP8266_ENC28J60 Ethernet
This is terminal debug output when running FullyFeatured_ESP8266_Ethernet on ESP8266_NODEMCU_ESP12E, using ENC28J60 Ethernet with lwIP_enc28j60 Library, connecting to broker.emqx.io MQTT server.
Starting FullyFeatured_ESP8266_Ethernet on ESP8266_NODEMCU_ESP12E using ESP8266_ENC28J60 Ethernet
AsyncMQTT_Generic v1.5.0 for ESP8266
Connecting to network : .....................................
Ethernet DHCP IP address: 192.168.2.187
PubTopic: async-mqtt/ESP8266_Pub
Session present: 0
Publishing at QoS 0
  packetId: 1
  qos: 2
Publish received.
  topic: async-mqtt/ESP8266_Pub
  message: ESP8266_Ethernet Test3
  qos: 2
  dup: 0
  retain: 1
  len: 22
  index: 0
  total: 22
  packetId: 2
Publish received.
  message: ESP8266_Ethernet Test1
  qos: 0
  dup: 0
  retain: 0
  len: 22
  index: 0
  total: 22
Publish received.
  message: ESP8266_Ethernet Test2
  qos: 1
  dup: 0
  retain: 0
  len: 22
  index: 0
  total: 22
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 22
  index: 0
  total: 22
  packetId: 3
2. FullyFeatured_ESP8266_Ethernet on ESP8266_NODEMCU_ESP12E using ESP8266_W5500 Ethernet
This is terminal debug output when running FullyFeatured_ESP8266_Etherneton ESP8266_NODEMCU_ESP12E, using W5500 Ethernet with lwIP_w5500 Library, connecting to broker.emqx.io MQTT server.
Starting FullyFeatured_ESP8266_Ethernet on ESP8266_NODEMCU_ESP12E using ESP8266_W5500 Ethernet
Ethernet DHCP IP address: 192.168.2.188
Session present: 0
Publishing at QoS 0
  packetId: 1
  qos: 2
Publish received.
  qos: 2
  dup: 0
  retain: 1
  len: 22
  index: 0
  total: 22
  packetId: 2
Publish received.
  qos: 0
  dup: 0
  retain: 0
  len: 22
  index: 0
  total: 22
Publish received.
  qos: 1
  dup: 0
  retain: 0
  len: 22
  index: 0
  total: 22
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 22
  index: 0
  total: 22
  packetId: 3
Releases v1.7.0
  1. Fix ESP32 compile error. Check Missing default case in switch causes #10
  2. Change to new Forked ESPAsyncTCP library for ESP8266 boards, using WiFi or LwIP Ethernet, with ESP8266 core v3.0.2+ or WiFi with ESP8266 core v2.7.4 to avoid compile errors
Releases v1.6.1
  1. Workaround for RP2040W WiFi.status() bug using ping() to local gateway for example FullyFeatured_RP2040W
  2. Use WiFi macAddress for RP2040W _clientId
Releases v1.6.0
  1. Add support to RASPBERRY_PI_PICO_W with CYW43439 WiFi, using arduino-pico core v2.4.0+
  2. Add example FullyFeatured_RP2040W
  3. Update Packages' Patches
1. FullyFeature_RP2040W on RASPBERRY_PI_PICO_W
This is terminal debug output when running FullyFeature_RP2040W on RASPBERRY_PI_PICO_W, using CYW43439 WiFi, connecting to broker.emqx.io MQTT server.
Starting FullyFeature_RP2040W on RASPBERRY_PI_PICO_W
AsyncMQTT_Generic v1.7.0 for RP2040W CYW43439 WiFi
Connecting to SSID: HueNet2
Connected to SSID: HueNet2
Local IP Address: 192.168.2.180
Signal strength (RSSI):0 dBm
PubTopic: async-mqtt/RP2040W_Pub
Session present: 0
Publishing at QoS 0
  packetId: 1
  qos: 2
Publish received.
  topic: async-mqtt/RP2040W_Pub
  message: RP2040W Test3
  qos: 2
  dup: 0
  retain: 1
  len: 13
  index: 0
  total: 13
  packetId: 2
Publish received.
  message: RP2040W Test1
  qos: 0
  dup: 0
  retain: 0
  len: 13
  index: 0
  total: 13
Publish received.
  message: RP2040W Test2
  qos: 1
  dup: 0
  retain: 0
  len: 13
  index: 0
  total: 13
Publish received.
  qos: 2
  dup: 0
  retain: 0
  len: 13
  index: 0
  total: 13
  packetId: 3
Using AsyncMQTT_Generic and Portenta_H7_AsyncWebServer libraries combined, makes Mbd Os Crash after muliple Web Server Calls.
See javos65/AsyncWebServer_plus_MQTT: Example Portenta MQTT plus Async Webserver (github.com)
Any one with a working MQTT + Webserver example working?
