Continued from
New important feature
Now you can send HTTP requests to multiple addresses and receive responses from them.
Releases v1.7.1
Add example AsyncHTTPRequest_ESP_Multi to demo connection to multiple addresses.
Update Packages' Patches
Releases v1.7.0
Add support to new ESP32-S3
Add LittleFS
support to ESP32-C3
Use ESP32-core's LittleFS library instead of Lorol's LITTLEFS library for v2.0.0+
Releases v1.6.0
Reduce the breaking effect of v1.5.0 by enabling compatibility with old code to include only AsyncHTTPRequest_Generic.h
Releases v1.5.0
Fix multiple-definitions
linker error and weird bug related to src_cpp
. Check Different behaviour using the src_cpp or src_h lib #80
Optimize library code by using reference-passing
instead of value-passing
Update all examples
Releases v1.4.1
Warning: Releases v1.4.1+ can be used and autodetect ESP32 core v2.0.0+ or v1.0.6- for WT32_ETH01
Auto detect ESP32 core to use for WT32_ETH01
Fix bug in WT32_ETH01 examples to reduce connection time
Releases v1.4.0
Fix crashing bug when request a non-existing IP. Check Http GET polling causes crash when host disconnected #22
Modify platform.ini
to avoid compile error with PIO when using ESP8266/ESP32
Releases v1.3.1
Update platform.ini
and library.json
to use original khoih-prog
instead of khoih.prog
after PIO fix
Releases v1.3.0
Add support to WT32_ETH01 (ESP32 + LAN8720) boards
Add examples with new features
Releases v1.8.0
Add support to ESP8266 using W5x00 with lwIP_w5100 or lwIP_w5500 library
Add example AsyncHTTPRequest_ESP8266_Ethernet to demo the new feature.
Terminal Debug Output Sample
The terminal output of AsyncHTTPRequest_ESP8266_Ethernet example running on ESP8266_NODEMCU_ESP12E
to demonstrate how to use ESP8266_W5500 Ethernet Async feature.
Starting AsyncHTTPRequest_ESP8266_Ethernet on ESP8266_NODEMCU_ESP12E using ESP8266_W5500 Ethernet
AsyncHTTPRequest_Generic v1.8.0
Connecting ethernet..
Ethernet IP address: 192.168.2.187
abbreviation: EDT
client_ip: aaa.bbb.ccc.ddd
datetime: 2022-04-13T21:58:31.037966-04:00
day_of_week: 3
day_of_year: 103
dst: true
dst_from: 2022-03-13T07:00:00+00:00
dst_offset: 3600
dst_until: 2022-11-06T06:00:00+00:00
raw_offset: -18000
timezone: America/Toronto
unixtime: 1649901511
utc_datetime: 2022-04-14T01:58:31.037966+00:00
utc_offset: -04:00
week_number: 15
HHHHHH
abbreviation: EDT
datetime: 2022-04-13T21:59:31.025188-04:00
day_of_week: 3
day_of_year: 103
dst: true
dst_offset: 3600
raw_offset: -18000
unixtime: 1649901571
utc_datetime: 2022-04-14T01:59:31.025188+00:00
utc_offset: -04:00
week_number: 15
HH
Releases v1.8.1
Add support to ESP8266 using ENC28J60 with lwIP_enc28j60 library
The terminal output of AsyncHTTPRequest_ESP8266_Ethernet running on ESP8266_NODEMCU_ESP12E
to demonstrate how to use ESP8266_ENC28J60 Ethernet Async feature.
Starting AsyncHTTPRequest_ESP8266_Ethernet on ESP8266_NODEMCU_ESP12E using ESP8266_ENC28J60 Ethernet
AsyncHTTPRequest_Generic v1.8.1
Connecting to network : ..........................................................
abbreviation: EDT
datetime: 2022-04-13T23:54:42.973735-04:00
day_of_week: 3
day_of_year: 103
dst: true
dst_offset: 3600
raw_offset: -18000
unixtime: 1649908482
utc_datetime: 2022-04-14T03:54:42.973735+00:00
utc_offset: -04:00
week_number: 15
HHHHHH
abbreviation: EDT
datetime: 2022-04-13T23:55:42.894333-04:00
day_of_week: 3
day_of_year: 103
dst: true
dst_offset: 3600
raw_offset: -18000
unixtime: 1649908542
utc_datetime: 2022-04-14T03:55:42.894333+00:00
utc_offset: -04:00
week_number: 15
system
Closed
October 11, 2022, 4:28am
5
