ATiny85 Debounce
I am using the Debounce example from the Arduino IDE. I have run the code on the ATiny85 and it works great. When I run the code without commenting out the section of code within setup(), it stops toggling the LED. The commented out section within setup() is to run pwm in fast mode.
I've tried changing the input pins for the push button but still no change :thinking:
                              ATtiny85
                           -------u-------
         X - A0 - (D 5) --| 1 PB5   VCC 8 |-- +5V
           X A3 - (D 3) --| 2 PB3   PB2 7 |-- (D 2) - A1  --> X
  PB SW I/P  A2 - (D 4) --| 3 PB4   PB1 6 |-- (D 1) - PWM --> To MOSFET
                   Gnd ---| 4 GND   PB0 5 |-- (D 0) - PWM --> LED O/P
// normal delay() won't work anymore because we are changing Timer1 behavior
// Adds delay_ms and delay_us functions
#include <util/delay.h>
// Clock at 8mHz
#define F_CPU 8000000        //F_CPU 8000000 (8Mhz). This is used by delay.h library
const int PWMPin = 1;        // Only works with Pin 1(PB1)
const int push_button = 4;   // Push button input to trigger HIT & HOLD.
const int ledPin = 0;        // The number of the LED pin
unsigned long hitDelay = 250;//250mS hit delay.
//variables will change:
int ledState = HIGH;          //the current state of the output pin
int buttonState;             //the current reading from the input pin
int lastButtonState = LOW;   //the previous reading from the input pin
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
  pinMode(push_button, INPUT);
  pinMode(ledPin, OUTPUT);
  //set initial LED state
  digitalWrite(ledPin, ledState);
  pinMode(PWMPin, OUTPUT);
  //Registers used to set FAST PWM in non inverting mode.
  TCCR0A = 1 << COM0B1 | 0 << COM0B0 | 1 << WGM01 | 1 << WGM00;
  TCCR0B = 1 << WGM02;
     //PWM frequency = clock speed / (prescaler X OCR0A)
     //8 000 000 / 64 = 125 kHz
    //64 - pre-scaler
    //125 kHz / 127 = ~1000 Hz
    //127 - OCR0A
  // disable interrupts to allow register changes
  TIMSK = 0;
  // set TOP to generate ~1 kHz
  OCR0A = 127;// 63=2Khz, 90=1.4Khz 127=1Khz,181=700hz, 255=500hz Timer counts up to these values then drops to zero again (bottom).
//  50 % duty cycle to start with if required ?? ?
  OCR0B = 31;//31
// start timer at 125 kHz (8 MHz / 64)
TCCR0B = 1 << WGM02 | 0 << CS02 | 1 << CS01 | 1 << CS00; //CS02,CS01,& CS00 Select the clock. (clk/64)
  // read the state of the switch into a local variable:
  int reading = digitalRead(push_button);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH), and you've waited long enough
  // since the last press to ignore any noise:
  // If the switch changed, due to noise or pressing:
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer than the debounce
    // delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
      // only toggle the LED if the new button state is HIGH
      if (buttonState == HIGH) {
        ledState = !ledState;
  // set the LED:
  // save the reading. Next time through the loop, it'll be the lastButtonState:
  lastButtonState = reading;
It is Timer 0 that determines the delay, not Timer 1.
The PWM part works when I use it alone in it's own sketch. I cannot include it in the debounce sketch as the the debounce code stops toggling the LED output. Is there anything obviously incorrect with the code that you can see? Thanks.
Well he code seems to be addressing Timer 0 not the Timer 1 as stated in the comment.
However what I don’t know is if the timer structure is the same in the ATtiny as it is in the AT328 which the code seems to be written for.
I would check but I am not at home at the moment only on my iPad.
Yes, as Grumpy_Mike told you, you use Timer0 for the PWM but still use the same timer by using the time keeping functions like delay() or millis(). You cannot use the same timer for the two functionalities at the same time. On the ATtiny85 timer 0 is used for time keeping.
Thanks both,
I decided not to use millis() and used _delay_ms() instead. It appears to work fine.
