Atlas Scientific OEM pH Sensor - IRAM Error
Hello,
Project - Read Atlas Scientific OEM Dev board OEM pH sensor
Arduino - NodeMCU ESP-12E
Board Manager Version - ESP8266 ver 2.6.0 (I tried 2.5 through 2.7.4)
GPIO Configuration:
Dev Board ----- > ESP-12E
VCC --- > VN
INT ----> D5 (GPIO14)
GND ----> GND
SDA ----> D2 (GPIO4 / SDA)
SCL ----> D1 (GPIO5 / SCL)
I attached the sample code for referance.
When I check the Serial Monitor I find this message:
>>>stack>>>
ctx: cont
sp: 3ffffef0 end: 3fffffc0 offset: 0000
3ffffef0:  feefeffe feefeffe feefeffe feefeffe
3fffff00:  000000fe 00000000 00000000 00000000
3fffff10:  00000000 00000000 00000000 00ff0000
3fffff20:  5ffffe00 5ffffe00 00000020 00000000
3fffff30:  00000003 00000002 3ffee910 40202f12
3fffff40:  4010067e 00000001 3ffef92c 40202f28
3fffff50:  00002580 0000001c 3ffee910 40203a95
3fffff60:  00000000 00000000 3ffee7b4 40203501
3fffff70:  3fffdad0 00000001 3ffee8e8 3ffee950
3fffff80:  3fffdad0 00000000 3ffee910 40203b44
3fffff90:  feefeffe 00000000 3ffee910 40201071
3fffffa0:  feefeffe feefeffe feefeffe 40202b64
3fffffb0:  feefeffe feefeffe 3ffe84e0 40100f89
<<<stack<<<
J⸮P⸮⸮⸮⸮ISR not in IRAM!
User exception (panic/abort/assert)
Abort called
>>>stack>>>
I tried to decode it using the ESP exception decoder but failed every attempt.
Does anyone have any suggestions here? I'm new to Arduino but familar with other platforms. I do realize that the OEM board is meant for devs. I'm just hopeful to get this code to run. I have an Arduino Uno ordered as well to try but Atlas did say it should work just fine on this board.
Thanks!
Joe
OEM_pH_Sample_code.zip (5.29 KB)
Read the first topic telling "How to use this Forum".
Post a real wiring diagram.
Post the code according to #7 in the topic above.
All ISRs must have the ICACHE_RAM_ATTR keyword in their declaration, or indeed you will get crashes (I thought the latest core would throw a complier error if you don't). Thsi forces the function to be placed in IRAM.
Like this:
void ICACHE_RAM_ATTR yourISR() {
Also, put the IRAM function before setup or the compiler thingy will not properly do the do.
