Hi to all,
i have an atmega328P(standalone 16Mhz) and i would know if is possible to use it as ISP programmer, with a usb to uart module.
Thank You
Hi to all,
Thank You
Yes. Load the ArduinoISP sketch onto it. If your USB-to-Serial implements Auto-reset (DTR) you should disable that.
Probably cheaper to order a USBasp from eBay for <$4.
motodaddo:
Hi to all,
i have an atmega328P(standalone 16Mhz) and i would know if is possible to use it as ISP programmer, with a usb to uart module.Thank You
Does it have arduino bootloader?
I've burned arduino pro mini bootloader on atmega328, and the chip on USB ->uart is a cp2002.
I noticed that bootloader is ok, in fact i've uploaded Arduino ISP sketch trough usb and the breath led is fine, bit when a try to use it as ISP programmer, the IDE gives errors. I used" Arduino ISP" as programmer in prefereces ->programmer
johnwasser:
This.
I really don't know why people spend their lives trying to build ISP programmers when they're so cheap.
fungus:
johnwasser:
Probably cheaper to order a USBasp from eBay for <$4.This.
Probably because is a way to learn something else! Anyway thank you for your answer....
Most likely because you live in SPAIN, not Veneuela!
alah:
Lo siento por ti amigo, dile a Maduro que abra una fabrica de programadores AVR.
Tell Maduro to create a public Industry for AVR programmers.
