Hello, I am having issues with some of the chips I ordered. Disclaimer beforehand that I am still new to this so I'm doing my best to explain.
I've been using these, which usually have the ATMEGA2560-16U chip like in the product picture. I received a batch of 18 of these from my last order, and 11 of them have a ATMEGA2560V-8AU chip, and coincidentally I'm having issues with all the boards with that chip.
In the datasheet on digikey, I found this part which seems to indicate a clear difference between the two:
Speed Grade:
– ATmega640V/ATmega1280V/ATmega1281V:
• 0 - 4MHz @ 1.8V - 5.5V, 0 - 8MHz @ 2.7V - 5.5V
– ATmega2560V/ATmega2561V:
• 0 - 2MHz @ 1.8V - 5.5V, 0 - 8MHz @ 2.7V - 5.5V
– ATmega640/ATmega1280/ATmega1281:
• 0 - 8MHz @ 2.7V - 5.5V, 0 - 16MHz @ 4.5V - 5.5V
– ATmega2560/ATmega2561:
• 0 - 16MHz @ 4.5V - 5.5V
I can't find any pictures online anywhere of these little MEGA PRO 2560 embed chips having anything but the ATMEGA2560-16U.
When I try uploading code in the Arduino IDE, I get byte mismatch errors. When I researched the errors, I bought a USBAsp device. I tried burning the bootloader and uploading the program using the programmer with ICSP pins connected, and I've also tried the Arduino programmer "Gammon" script using another Arduino as the programmer.
I can't seem to get these ATMEGA2560V-8AU boards to work. Strangely, I managed to get my sketch uploaded to one of them, and it seems to function, but when I try uploading Blink or something, it gives me avrdude byte mismatch errors again. However, on that particular board, even with the errors, sketches seem to upload and work. All other boards I have tried that usually isn't the case.
At first I thought maybe the ATMEGA2560V-8AU chips aren't meant to be mated with the Arduino MEGA 2560 setup and the factory made a mistake putting those chips on there. (Also reinforced by the fact I can't find any reference to those boards existing with these chips, and the different specs in the datasheet). However, since I have one of them semi-working, it makes me think I can still somehow make these work.
I'm still learning and can't quite make sense of it. Did I get ripped off and sold bad boards with cheaper chips? Is there some way to burn bootloaders on these 2560V chips to make them work? I'd appreciate any tips.
One last note, all of these 2560V boards show up as Board Unknown when I try to view the Board Info in the Arduino IDE.
