Can Burn Bootloader on Atmega2560V-8AU
Hi everyone,
I created some custom PCBs where I use Atmega2560 and it works perfectly.
Now I've upgraded to Atmega2560v-8AU, which I've read is pin-to-pin compatible.
Now I was writing the Bootloader on the new MCUs but I get the error:
avrdude: Version 6.3-20201216
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Utente\AppData\Local\Arduino15\packages\MegaCore\hardware\avr\2.2.0/avrdude.conf"
         Using Port                    : COM13
         Using Programmer              : stk500
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500
         Programmer Model: STK500
         Hardware Version: 15
         Firmware Version Master : 2.10
         Topcard         : Unknown
         Vtarget         : 5.2 V
         SCK period      : 8.7 us
         Varef           : 0.0 V
         Oscillator      : Off
avrdude: stk500v2_command(): command failed
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
To load the bootloader I use a Pololu shield:
I use the MegaCore Bootloader and to burn it I click the button at the bottom "Write the bootloader" (in Italian)
Obviously with Atmega2560 it works. With Atmega2560v unfortunately not.
P.S.: I used 4MHz internal Clock and 3,3V VCC
I suspect AVRDUDE is getting a wrong device signature. While the two uC's may be pin compatible, I would think they would be factory masked with a different device signature.
avrdude - How to modify Arduino boards.txt to support new MCUs - Arduino Stack Exchange
I think it's a bit complicated for me, could you help me in more detail? That article talks about the 328P, do you know if there is a guide for the 2560v?
arduino mega - changing device signature in avrdude - Arduino Stack Exchange
More articles if above is not helpful:
Atmega2560v-8AU chip signature AVRDUDE at DuckDuckGo
Thank you for your reply.
There are to many files whit that name.
Which should I change?
I tried changing that to MegaCore but it didn't work.
I've tried editing all the files but it still doesn't work.
I modified the file in the path that I find written in the log like this:
# ATmega2560
part
    id               = "m2560";
    desc             = "ATmega2560";
    signature        = 0x1e 0x98 0x01;
    has_jtag         = yes;
#    stk500_devcode   = 0xB2;
#    avr910_devcode   = 0x43;
    chip_erase_delay = 9000;
    pagel            = 0xD7;
    bs2              = 0xA0;
    reset            = dedicated;
    pgm_enable       = "1 0 1 0  1 1 0 0    0 1 0 1  0 0 1 1",
                       "x x x x  x x x x    x x x x  x x x x";
    chip_erase       = "1 0 1 0  1 1 0 0    1 0 0 0  0 0 0 0",
    timeout          = 200;
    stabdelay        = 100;
    cmdexedelay      = 25;
    synchloops       = 32;
    bytedelay        = 0;
    pollindex        = 3;
    pollvalue        = 0x53;
    predelay         = 1;
    postdelay        = 1;
    pollmethod       = 1;
    pp_controlstack     =
        0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
        0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
        0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
        0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02;
    hventerstabdelay    = 100;
    progmodedelay       = 0;
    latchcycles         = 5;
    togglevtg           = 1;
    poweroffdelay       = 15;
    resetdelayms        = 1;
    resetdelayus        = 0;
    hvleavestabdelay    = 15;
    chiperasepulsewidth = 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    idr                 = 0x31;
    spmcr               = 0x57;
    rampz               = 0x3b;
    allowfullpagebitstream = no;
    ocdrev              = 4;
    memory "eeprom"
        paged           = no; /* leave this "no" */
        page_size       = 8;  /* for parallel programming */
        size            = 4096;
        min_write_delay = 9000;
        max_write_delay = 9000;
        readback_p1     = 0x00;
        readback_p2     = 0x00;
        read            = "  1   0   1   0      0   0   0   0",
                          "  x   x   x   x    a11 a10  a9  a8",
                          " a7  a6  a5  a4     a3  a2  a1  a0",
                          "  o   o   o   o      o   o   o   o";
        write           = "  1   1   0   0      0   0   0   0",
                          "  i   i   i   i      i   i   i   i";
        loadpage_lo     = "  1   1   0   0      0   0   0   1",
                          "  0   0   0   0      0   0   0   0",
                          "  0   0   0   0      0  a2  a1  a0",
                          "  i   i   i   i      i   i   i   i";
        writepage       = "  1   1   0   0      0   0   1   0",
                          "  0   0   x   x    a11 a10  a9  a8",
                          " a7  a6  a5  a4     a3   0   0   0",
                          "  x   x   x   x      x   x   x   x";
        mode      = 0x41;
        delay     = 10;
        blocksize = 8;
        readsize  = 256;
    memory "flash"
        paged           = yes;
        size            = 262144;
        page_size       = 256;
        num_pages       = 1024;
        min_write_delay = 4500;
        max_write_delay = 4500;
        readback_p1     = 0x00;
        readback_p2     = 0x00;
        read_lo         = "  0   0   1   0      0   0   0   0",
                          "a15 a14 a13 a12    a11 a10  a9  a8",
                          "  o   o   o   o      o   o   o   o";
        read_hi         = "  0   0   1   0      1   0   0   0",
                          "  o   o   o   o      o   o   o   o";
        loadpage_lo     = "  0   1   0   0      0   0   0   0",
                          "  x   x   x   x      x   x   x   x",
                          "  x  a6  a5  a4     a3  a2  a1  a0",
                          "  i   i   i   i      i   i   i   i";
        loadpage_hi     = "  0   1   0   0      1   0   0   0",
                          "  x   x   x   x      x   x   x   x",
                          "  i   i   i   i      i   i   i   i";
        writepage       = "  0   1   0   0      1   1   0   0",
                          " a7   x   x   x      x   x   x   x",
                          "  x   x   x   x      x   x   x   x";
        load_ext_addr   = "  0   1   0   0      1   1   0   1",
                          "  0   0   0   0      0   0   0   0",
                          "  0   0   0   0      0   0   0 a16",
                          "  0   0   0   0      0   0   0   0";
        mode      = 0x41;
        delay     = 10;
        blocksize = 256;
        readsize  = 256;
    memory "lfuse"
        size            = 1;
        write           = "1 0 1 0  1 1 0 0  1 0 1 0  0 0 0 0",
                          "x x x x  x x x x  i i i i  i i i i";
        read            = "0 1 0 1  0 0 0 0  0 0 0 0  0 0 0 0",
                          "x x x x  x x x x  o o o o  o o o o";
    memory "hfuse"
        size            = 1;
        write           = "1 0 1 0  1 1 0 0  1 0 1 0  1 0 0 0",
        read            = "0 1 0 1  1 0 0 0  0 0 0 0  1 0 0 0",
    memory "efuse"
        size            = 1;
        write           = "1 0 1 0  1 1 0 0  1 0 1 0  0 1 0 0",
                          "x x x x  x x x x  x x x x  x i i i";
        read            = "0 1 0 1  0 0 0 0  0 0 0 0  1 0 0 0",
    memory "lock"
        size            = 1;
        read            = "0 1 0 1  1 0 0 0   0 0 0 0  0 0 0 0",
                          "x x x x  x x x x   x x o o  o o o o";
        write           = "1 0 1 0  1 1 0 0   1 1 1 x  x x x x",
                          "x x x x  x x x x   1 1 i i  i i i i";
    memory "calibration"
        size            = 1;
        read            = "0 0 1 1  1 0 0 0    x x x x  x x x x",
                          "0 0 0 0  0 0 0 0    o o o o  o o o o";
    memory "signature"
        size            = 3;
        read            = "0  0  1  1   0  0  0  0   x  x  x  x   x  x  x  x",
                          "x  x  x  x   x  x a1 a0   o  o  o  o   o  o  o  o";
# ATmega2560v
part
    id               = "m2560v";
    desc             = "ATmega2560V";
    signature        = 0x1e 0x98 0x03;
    has_jtag         = yes;
    pagel            = 0xD7;
    bs2              = 0xA0;
    reset            = dedicated;
    timeout          = 200;
    stabdelay        = 100;
    cmdexedelay      = 25;
    synchloops       = 32;
    bytedelay        = 0;
    pollindex        = 3;
    pollvalue        = 0x53;
    predelay         = 1;
    postdelay        = 1;
    pollmethod       = 1;
    pp_controlstack     =
    progmodedelay       = 0;
    latchcycles         = 5;
    togglevtg           = 1;
    poweroffdelay       = 15;
    resetdelayms        = 1;
    resetdelayus        = 0;
    idr                 = 0x31;
    spmcr               = 0x57;
    rampz               = 0x3b;
    ocdrev              = 4;
    memory "eeprom"
        size            = 4096;
        readback_p1     = 0x00;
        readback_p2     = 0x00;
                          "  o   o   o   o      o   o   o   o";
                          "  i   i   i   i      i   i   i   i";
                          "  0   0   0   0      0   0   0   0",
                          "  i   i   i   i      i   i   i   i";
                          "  x   x   x   x      x   x   x   x";
        mode      = 0x41;
        delay     = 10;
        blocksize = 8;
        readsize  = 256;
    memory "flash"
        paged           = yes;
        size            = 262144;
        page_size       = 256;
        num_pages       = 1024;
        readback_p1     = 0x00;
        readback_p2     = 0x00;
                          "  o   o   o   o      o   o   o   o";
                          "  o   o   o   o      o   o   o   o";
                          "  x   x   x   x      x   x   x   x",
                          "  i   i   i   i      i   i   i   i";
                          "  x   x   x   x      x   x   x   x",
                          "  i   i   i   i      i   i   i   i";
                          "  x   x   x   x      x   x   x   x";
                          "  0   0   0   0      0   0   0   0",
                          "  0   0   0   0      0   0   0   0";
        mode      = 0x41;
        delay     = 10;
        blocksize = 256;
        readsize  = 256;
    memory "lfuse"
        size            = 1;
    memory "hfuse"
        size            = 1;
    memory "efuse"
        size            = 1;
    memory "lock"
        size            = 1;
        size            = 1;
    memory "signature"
        size            = 3;
But I have the same output:
C:\Users\Utente\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude -CC:\Users\Utente\AppData\Local\Arduino15\packages\MegaCore\hardware\avr\2.2.0/avrdude.conf -v -patmega2560 -cstk500 -P COM13 -e -Ulock:w:0xff:m -Uefuse:w:0xfe:m -Uhfuse:w:0b11010110:m -Ulfuse:w:0xe2:m
         Using Port                    : COM13
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Topcard         : Unknown
         Vtarget         : 3.4 V
         SCK period      : 8.7 us
         Varef           : 0.0 V
         Oscillator      : Off
         this check.
Errore durante la scrittura del bootloader
I did a test with the custom PCB with Atmega 2560. I tried reading the signature with AVRDUDESS and it reads the right signature:
If instead I use the same custom PCB with Atmega2560v I get this error:
>>>: avrdude -c stk500v2 -P COM13 -b 19200 -p m8
WARNING: Unable to detect MCU
avrdude.exe: stk500v2_command(): command failed
avrdude.exe: initialization failed, rc=-1
             this check.
avrdude.exe done.  Thank you.
