Help? :-?
Chip: Arduino duemilanove; Atmega328
Programmer: AVRISP mkII build date: (2009.08.21)
OS: Windows XP Home SP3
IC programming knowledge level: Banana-less Chimpanzee
I am using the ICSP pins on the arduino to program the 328.
I attempted to do the apparently "easy" way and use the arduino software. I get a error: "avrdude: usbdev_open(): did not find any USB device "usb"".
If you believe it would matter I will set upload.verbose=true then see the error, I will do so.
Settings in programmer.txt:
(stripped to just the one I am using)
avrispmkii.name=AVRISP mkII
avrispmkii.communication=usb
avrispmkii.protocol=stk500v2
Settings in Boards.txt:
atmega328.name=Arduino Duemilanove or Nano w/ ATmega328
atmega328.upload.protocol=stk500
atmega328.upload.maximum_size=30720
atmega328.upload.speed=57600
atmega328.bootloader.low_fuses=0xFF
atmega328.bootloader.high_fuses=0xDA
atmega328.bootloader.extended_fuses=0x05
atmega328.bootloader.path=atmega
atmega328.bootloader.file=ATmegaBOOT_168_atmega328.hex
atmega328.bootloader.unlock_bits=0x3F
atmega328.bootloader.lock_bits=0x0F
atmega328.build.mcu=atmega328p
atmega328.build.f_cpu=16000000L
atmega328.build.core=arduino
Settings in Preference.txt:
update.id=6842143608949844381
export.application.platform.windows=true
preproc.save_build_files=false
preproc.substitute_floats=true
run.options=
run.display=1
editor.divider.size=2
serial.port=COM14
preproc.enhanced_casting=true
editor.divider.size.windows=2
last.sketch1.path=C:\Documents and Settings\terror\Desktop\arduino-0017\hardware\libraries\LiquidCrystal\examples\HelloWorld\HelloWorld.pde
editor.font=Monospaced,plain,12
console.auto_clear=true
console.output.file=stdout.txt
last.sketch.count=0
export.application.platform=true
default.window.height=600
export.application.stop=true
serial.parity=N
serial.databits=8
board=atmega328
preproc.output_parse_tree=false
editor.external=false
editor.indent=true
last.screen.height=600
upload.using=bootloader
run.present.bgcolor=#666666
preproc.web_colors=true
editor.tabs.expand=true
run.present.stop.color=#cccccc
preproc.color_datatype=true
last.screen.width=1024
apple.laf.useScreenMenuBar=true
export.application.platform.linux=true
export.application.platform.macosx=true
editor.antialias=false
export.applet.separate_jar_files=false
editor.tabs.size=2
console.error.file=stderr.txt
preproc.substitute_unicode=true
console=true
run.present.exclusive.macosx=true
console.lines=4
run.options.memory.maximum=256
browser.linux=mozilla
preproc.imports=java.applet,java.awt,java.awt.image,java.awt.event,java.io,java.net,java.text,java.util,java.util.zip,java.util.regex
update.check=true
last.sketch0.path=C:\DOCUME~1\terror\LOCALS~1\Temp\untitled1652.tmp\sketch_nov22a\sketch_nov22a.pde
run.window.bgcolor=#EBE9ED
sketchbook.path=C:\Documents and Settings\terror\My Documents\Arduino
last.sketch0.location=262,0,500,600,420
update.last=1259108251031
export.delete_target_folder=true
platform.auto_file_type_associations=true
default.window.width=500
editor.caret.blink=true
serial.stopbits=1
serial.debug_rate=9600
run.options.memory.initial=64
upload.verbose=false
run.options.memory=false
last.sketch1.location=164,0,500,600,420
editor.invalid=false
editor.font.macosx=Monaco,plain,10
export.application.fullscreen=false
console.length=500
run.present.exclusive=false
