Atmega328p+esp8266 and pn532 serial communication failure
Greetings...
I'm doing a small project to read an RFID card and send the data via API on the ESP8266. When the dip switch is activated for the ATmega328P, I can read the card data on the serial monitor. When the dip switch is switched to the ESP8266, I can connect to the WiFi and the data that I send via the serial monitor is captured and sent via API.
However, when both chips are activated in the dip switch in mode 1 and 2 (ATmega328P+ESP8266 simultaneously), it seems that nothing works and they don't communicate with each other. I've already rewritten the code in several ways but without success.
I use UART communication and the SCL and SDA output on the PN532 and it is connected to port 2,3.
code atmega
#include <SoftwareSerial.h>
#include <PN532_SWHSU.h>
#include <PN532.h>
SoftwareSerial SWSerial( 3, 2 ); // RX, TX
#define RX_PIN 10
#define TX_PIN 11
// Cria o objeto SoftwareSerial
SoftwareSerial espSerial(RX_PIN, TX_PIN);
PN532_SWHSU pn532swhsu( SWSerial );
PN532 nfc( pn532swhsu );
String stagId = "None", dispTag = "None";
byte nuidPICC[4];
void setup(void)
  SWSerial.begin(115200);
  espSerial.begin(9600);
  Serial.println("Hello Maker!");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata)
    Serial.print("Didn't Find PN53x Module");
    while (1); // Halt
  // Got valid data, print it out!
  Serial.print("Found chip PN5");
  Serial.println((versiondata >> 24) & 0xFF, HEX);
  Serial.print("Firmware ver. ");
  Serial.print((versiondata >> 16) & 0xFF, DEC);
  Serial.print('.');
  Serial.println((versiondata >> 8) & 0xFF, DEC);
  // Configure board to read RFID tags
  nfc.SAMConfig();
  readNFC();
    // Lê qualquer resposta do ESP8266 e envia para o monitor serial
  if (espSerial.available()) {
    Serial.write(espSerial.read());
  // Lê qualquer entrada do monitor serial e envia para o ESP8266
  if (Serial.available()) {
    espSerial.write(Serial.read());
  delay(1000); // Aguarda um segundo antes de enviar a próxima mensagem
void readNFC()
  boolean success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                       // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
  if (success)
    Serial.print("UID Length: ");
    Serial.print(uidLength, DEC);
    Serial.println(" bytes");
    Serial.print("UID Value: ");
    for (uint8_t i = 0; i < uidLength; i++)
      nuidPICC[i] = uid[i];
      Serial.print(" "); Serial.print(uid[i], DEC);
    stagId = tagToString(nuidPICC);
    Serial.print(F("stagId is : "));
    stagId.trim();
    Serial.println(stagId.c_str());
    //Serial.write(stagId.c_str());
    espSerial.println(stagId.c_str());
      delay(1000);  // 1 second halt
    // PN532 probably timed out waiting for a card
    Serial.println("Timed out! Waiting for a card...");
String tagToString(byte id[4])
  String tagId = "";
  for (byte i = 0; i < 4; i++)
    if (i < 3) tagId += String(id[i]) + "_";
    else tagId += String(id[i]);
  return tagId;
esp8266
    This sketch establishes a TCP connection to a "quote of the day" service.
    It sends a "hello" message, and then prints received data.
#include <ESP8266Firebase.h>
Firebase firebase("https://teste/");
#include <ESP8266WiFi.h>
#ifndef STASSID
#define STASSID "NET"
#define STAPSK "pass"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
//CONFIGURAÇÕES DO SERVIDOR
int    HTTP_PORT   = 80;
String HTTP_METHOD = "GET"; // or "POST"
char   HOST_NAME[] = "192.168.3.9"; // hostname of web server:
String PATH_NAME   = "/api.php";
  Serial1.begin(9600); // Comunicação serial com o ATmega328P
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  /* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
     would try to act as both a client and an access-point and could cause
     network-issues with your other WiFi-devices on your WiFi-network. */
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  firebase.setString("Test/question", "Is it really working?");
  firebase.setString("Test/answer", "Yes!");
  static bool wait = false;
  String IncomingString = "";
  boolean StringReady = false;
  //aguarda o envio da IDtag
  //while ((Serial.available()) & (StringReady == false)){
  if (Serial.available() > 0) {
    digitalWrite(LED_BUILTIN, LOW);  // Turn the LED on (Note that LOW is the voltage level
    //IncomingString = Serial.readString();
    //IncomingString = Serial.readStringUntil('\n');
    firebase.setString("Test/message", IncomingString);
    //if (!IncomingString.isEmpty()) {                // bail if we got an empty line
        StringReady = true;
        Serial.println("valor de incoming " + IncomingString);
  Serial.print("connecting to ");
  Serial.print(HOST_NAME);
  Serial.print(':');
  Serial.println(HTTP_PORT);
  Serial.println(IncomingString);
//strcat(host, IncomingString);  // Concatenate str2 to result
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  //if (!client.connect(host + "TAGID=" + IncomingString, port)) {
  if (!client.connect(HOST_NAME, HTTP_PORT)) {
    Serial.println("connection failed");
    delay(5000);
    return;
  // This will send a string to the server
  Serial.println("sending data to server");
  if (client.connected()) {
    String queryString = String("?TAGID=") + String(IncomingString);
    firebase.setString("Test/message", queryString);
    Serial.println("GET " + PATH_NAME + queryString + " HTTP/1.1");
    client.println("GET " + PATH_NAME + queryString);
    //client.println(HTTP_METHOD + " " + PATH_NAME + " HTTP/1.1");
    client.println("Host: " + String(HOST_NAME));
    client.println("Connection: close");
    client.println(); // end HTTP request header
  // wait for data to be available
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 5000) {
      Serial.println(">>> Client Timeout !");
      client.stop();
      delay(60000);
      return;
  // Read all the lines of the reply from server and print them to Serial
  Serial.println("receiving from remote server");
  // not testing 'client.connected()' since we do not need to send data here
  while (client.available()) {
    char ch = static_cast<char>(client.read());
    Serial.print(ch);
  // Close the connection
  Serial.println("closing connection");
  client.stop();
I moved your topic to an appropriate forum category @petruswhite.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
I didn't have time to read your code, but 115200 is too high baud rate for softwareserial.
Even without setting the rate it only works when I use the atmega328p alone.
You can't have multiple software serials.
Baud rate for sw serial should be max 19200
Esp8266 has only tx available on Serial1
On your Esp code you use only Serial for everything
Which board do you exactly have? If it's the ones that I remember:
The CH340 serial-to-usb converter can only be connected to either the 328P or to the ESP8266. Connecting it to both at the same time will not work.
If you set the dipswitches to use the 328P, the Tx of the CH340 is connected to the Rx of the 328P and the Rx of the CH340 is connected to the Tx of the 328P.
If you set the dipswitches to use the ESP8266, the Tx of the CH340 is connected to the Rx of the ESP8266 and the Rx of the CH340 is connected to the Tx of the ESP8266.
If you try to use both, the Tx of the 328P is connected to the Tx of the ESP8266 (which is at best an unhealthy scenario for the ESP8266) and the Rx of the 328P is connected to the Rx of the ESP8266. So they can not communicate with each other that way as Tx should be connected to Rx and Rx should be connected to Tx.
I can't help you further.
board_atmega_esp8266
My board is similar this.
