It is working perfectly right now (as far as I can tell), I had to add a "which LEDs are on/off?" in the sleep so it came back to the same pattern as when it slept (this only affects a few of the patterns). This pattern recovery doesn't work for the "snake" one (yet?), it's not a big practical deal (as the pattern corrects when it cycles around which is pretty fast), but of course it's bugging me lol. (Although at one point I had forgotten somehow to put in the sleep mode so it wasn't sleeping, and this was madness.)
The program spends most of its time in each pattern function, as that's where I assign LED on/off times. This might be a bit odd (and might not be the best C++ way to do this, I like things to be Pythonic aka "the right way looks nice too"), but is at least an offshoot of how I built the code (first made one pattern, so, keeping it in that pattern was ok, then it was path dependency after that so I kept up that way of doing it). So I have to check for the Mode (pattern) button and the Power (sleep) button in each function's loop. But it works!
I am not super concerned about actual power savings as long as it is saving a little power, but also it gives the user/wearer a way to stop the blinking (they might not blinking all the time).
The code isn't perfectly commented but here it is (keeping in mind the snake() pattern doesn't recover from sleep for one cycle of its pattern, ooh and there might be a sleep issue in the fire() function which I see has two loops, hmm). It's likely I have used some things that are not best practice (coming from Python and R linear scripts, with a background in Pascal).
// For the ICA South Africa 2026 Conference Badge project.
// Xbox-like controller, with blinky LEDs where the controller buttons are.
// Summer / Fall 2025
// Sleep help from jim-p and alto777 (Arduino forum).
// Include Libraries
// For Sleep and Interrupt functionality.
#include <avr/sleep.h>
#include <avr/interrupt.h>
// Global Variables
// YRGB is the order of the lights, starting at noon and going clockwise (based on the buttons on an XBox 360 controller).
// SET PINS HERE (note difference between Arduino Metro board and custom board pin numbers).
// You can't use the simple pin numbers from the chip, you need to translate them since the Arduino IDE uses a different scheme.
// Here: https://community.platformio.org/t/atmega328pb-arduino-pin-mappings/4248
const int led_yellow = PD2; // ATMega328PB pin references.
const int led_red = PD0;
const int led_green = PD1; // Weird order due to circuit layout realities of the PCB and the ATMEGA328PB.
const int led_blue = PD3;
// Different online schematics show different pin desginations. Beware!
const int button_onoff = 8; //12; PB0 // Really is sleep, PULL UP RESISTOR (long story).
const int button_mode = 9; //13; PB1 // The mode button, PULL DOWN RESISTOR.
// Mode buttons setup here.
// https://docs.arduino.cc/built-in-examples/digital/StateChangeDetection/
int button_state = 0; // Variable for reading the pushbutton status.
int button_prev = 0; // LOW. For the previous state of the button, helps get one click not a human-length hold/click.
// Pattern varaibles.
const int num_patterns = 11; // How many pattens do I have.
int pattern = 1; // 1 to num_patterns for # patterns of LED blinking. Will start at this pattern number.
// The ISR SUPER IMPORTANT, MCU and schematic specific.
ISR(PCINT0_vect) {
PCICR &= ~_BV(PCIE0); // Disable the PCINT[7:0] interrupts
pinMode(led_yellow, OUTPUT);
pinMode(led_red, OUTPUT);
pinMode(led_green, OUTPUT);
pinMode(led_blue, OUTPUT);
// Ports B, C, D, and E all have internal resistors that can be set.
pinMode(button_mode, INPUT); // Build has a pulldown resistor on it.
pinMode(button_onoff, INPUT_PULLUP); // INPUT_PULLUP if I set it like that, is that chip-internal? (I have a resistor on the board.)
// Input pullups essentially set the default state of the pin to HIGH or 1, so that the pin is not affected by interference.
// Do not need a resistor in this case. (I have one on the board.)
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Set sleep mode to full power down.
init_off(); // Make sure all LEDs are set to LOW to start.
if (pattern == 1) blink(); // Starts on this one (unless changed above).
if (pattern == 2) rotate();
if (pattern == 3) alternate();
if (pattern == 4) snake();
if (pattern == 5) rave();
if (pattern == 6) rando();
if (pattern == 7) random_path();
if (pattern == 8) bounce();
if (pattern == 9) sideside();
if (pattern == 10) fire();
if (pattern == 11) fireworks();
} // main loop
// SLEEP FUNCTION hooray
void sleeper() { // c/o jim-p (Arduino forum)
bool yellow_on = (digitalRead(led_yellow) == HIGH); // Have to reset the LEDs upon return from sleep.
bool red_on = (digitalRead(led_red) == HIGH);
bool green_on = (digitalRead(led_green) == HIGH);
bool blue_on = (digitalRead(led_blue) == HIGH);
init_off(); // Turns all LEDs off, because it can catch them on at button press.
PCIFR = 0x07; // Clear all the change on interrupt flags
bitSet(PCICR, PCIE0); // Enanble change interrupts on PCINT[7:0] pins
bitSet(PCMSK0, PCINT0); // Enable for PCINT0 (D8)
interrupts(); // Make sure interrupts are enabled
sleep_bod_disable(); // Disble BOD; saves power
sleep_mode(); // Enables sleep, puts cpu to sleep and disbles sleep when awoken
// We are now ASLEEP, will stay here until interrupt occurs (the interrrupt we just put on pin D8).
//ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
// Now we are awake here.
do {delay(20);}
while (digitalRead(button_onoff) == LOW); // Debounce, finger to get off the button. c/o alto777 (Arduino forum)
if (yellow_on) digitalWrite(led_yellow, HIGH); // Set the LEDs back to where they were (matters for some patterns).
if (red_on) digitalWrite(led_red, HIGH);
if (green_on) digitalWrite(led_green, HIGH);
if (blue_on) digitalWrite(led_blue, HIGH);
// SECONDARY FUNCTIONS (these assist the main pattern functions).
// Helper functions that set LEDs to various states.
void init_off() {
digitalWrite(led_yellow, LOW);
digitalWrite(led_red, LOW);
digitalWrite(led_green, LOW);
digitalWrite(led_blue, LOW);
void init_on() {
// For the mode/pattern button, which pattern by number.
void increment() {
pattern++; // Pattern is a global var so it is just set, not returned.
if (pattern > num_patterns) pattern = 1;
init_off(); // Because if you're in this function, the mode button was pushed, so start new pattern.
delay(70); // Perhaps avoid bounce?
// If the LEDs are on turn them off and vice-versa, for the blink pattern.
void reverse_all() {
if (digitalRead(led_red) == HIGH) init_off(); // If one is on, they are all on, turn all off.
else init_on();
} // reverse_all
// These two are used by the rave function, if off, turn it on and return an "on until" time, etc.
unsigned long rave_on(int which_led){
digitalWrite(which_led, HIGH);
unsigned long on_until = millis() + random(5, 50); // times adjusted
return on_until;
unsigned long rave_off(int which_led) {
digitalWrite(which_led, LOW);
unsigned long off_until = millis() + random(5, 50);
return off_until;
// All of these four turn one on and make sure the others are off.
void yellow_only() {
void red_only() {
void green_only() {
void blue_only() {
// Gamma Correction Function (for fading the LEDs).
int gamma_correct(int uncorrected_level) {
// Convert 0-255 to 0.0-1.0 .
float decimal_level = uncorrected_level / 255.0; // "If doing math with floats, you need to add a decimal point, otherwise it will be treated as an int." = 0
// Gamma adjust.
float corrected_decimal = decimal_level * decimal_level * decimal_level;
// Convert back to 0-255 metric and return it.
return corrected_decimal * 255;
// PRIMARY FUNCTIONS these are the patterns (they may call a seconadry function for common actions).
void blink() {
unsigned long start = millis();
unsigned long now;
init_on();
while (true) {
if (digitalRead(button_onoff) == LOW) { // if on/off button press, do sleep function call
do {delay(20);}
sleeper();
now = millis();
button_prev = button_state;
button_state = digitalRead(button_mode);
if (button_state == HIGH && button_prev == LOW) { // signal from mode button
increment();
return; // break out of the function
if (now - start >= 30) { // beta timing for board
reverse_all(); //
start = millis();
} // while
} // blink
void rotate() {
unsigned long now = millis();
unsigned long y_off = now + 45;
unsigned long r_off = now + 90;
unsigned long g_off = now + 135;
unsigned long b_off = now + 180;
while (true) {
do {delay(20);}
sleeper();
now = millis();
increment();
if (now >= y_off) {
y_off = now + 180;
r_off = now + 45;
else if (now >= r_off) {
r_off = now + 180;
g_off = now + 45;
else if (now >= g_off) {
g_off = now + 180;
b_off = now + 45;
else if (now >= b_off) {
b_off = now + 180;
y_off = now + 45;
} // while
} // rotate
void alternate() {
// Up and down, then left and right.
const int alternate_delay = 50; // The millis delay for this function. Changed for PCB.
unsigned long ud_on = millis(); // Up Down when it has turned on.
unsigned long lr_on = ud_on + alternate_delay; // Left Right on.
unsigned long now;
while (true) {
do {delay(20);}
sleeper();
now = millis();
increment();
if (now - ud_on >= alternate_delay) {
ud_on = lr_on + alternate_delay; // e.g., 50 + 50
else if (now - lr_on >= alternate_delay) {
} // while
} // alternate
void snake() {
// Grows and then shrinks YRGB
const int on_for = 125; // Times adjusted for PCB.
const int end_pause = 125; // Pause before restarting the snake loop.
unsigned long y_on = 0;
unsigned long r_on = 25;
unsigned long g_on = 50;
unsigned long b_on = 75;
unsigned long y_off = y_on + on_for;
unsigned long r_off = r_on + on_for;
unsigned long g_off = g_on + on_for;
unsigned long b_off = b_on + on_for;
unsigned long now = 0; // This was why the start pattern was wonky.
while (true) {
do {delay(20);}
sleeper();
increment();
if (now >= y_on) {
y_on = y_off + end_pause;
if (now >= r_on) {
r_on = r_off + end_pause;
if (now >= g_on) {
g_on = g_off + end_pause;
if (now >= b_on) {
b_on = b_off + end_pause;
if (now > y_off) {
if (now > r_off) {
if (now > g_off) {
if (now > b_off) {
now = millis() - start; // Should time the function and add it to the "now".
} // while
} // snake
void rave() {
// This is random on all of them: random(min, max+1).
unsigned long yellow_on_until = 0;
unsigned long yellow_off_until = 0;
unsigned long red_on_until = 0;
unsigned long red_off_until = 0;
unsigned long green_on_until = 0;
unsigned long green_off_until = 0;
unsigned long blue_on_until = 0;
unsigned long blue_off_until = 0;
// Start all on with random rave on values.
yellow_on_until = rave_on(led_yellow);
red_on_until = rave_on(led_red);
green_on_until = rave_on(led_green);
blue_on_until = rave_on(led_blue);
while (true) {
do {delay(20);}
sleeper();
now = millis();
increment();
// If on, should it be turned off? If off, should it be turned on?
if (digitalRead(led_yellow) == HIGH) { if (now > yellow_on_until) yellow_off_until = rave_off(led_yellow); }
else { if (now > yellow_off_until) yellow_on_until = rave_on(led_yellow); }
if (digitalRead(led_red) == HIGH) { if (now > red_on_until) red_off_until = rave_off(led_red); }
else { if (now > red_off_until) red_on_until = rave_on(led_red); }
if (digitalRead(led_green) == HIGH) { if (now > green_on_until) green_off_until = rave_off(led_green); }
else { if (now > green_off_until) green_on_until = rave_on(led_green); }
if (digitalRead(led_blue) == HIGH) { if (now > blue_on_until) blue_off_until = rave_off(led_blue); }
else { if (now > blue_off_until) blue_on_until = rave_on(led_blue); }
} // while
} // rave function
void rando() {
const int pause = 33;
int prev = 0;
int prev_2 = 0;
while (true) {
do {delay(20);}
sleeper();
now = millis();
increment();
if (now - start >= pause) {
start = millis();
int roll = random(1,5); // Gives it a value so you can compare on next line.
while (roll == prev_2) {roll = random(1,5);} // Reroll -- allows for 1 match but not more than that.
prev_2 = prev; // Okay passed, so update these two.
prev = roll;
if (roll == 1) {
yellow_only();
else if (roll == 2) {
red_only();
else if (roll == 3) {
green_only();
else if (roll == 4) {
blue_only();
} // if now - start
} // while true
} // rando
void random_path() {
// Random, but only activates a neighbor (a "path").
unsigned long last = 0;
const int pause = 40; // adjusted for PCB
int which = 1; // 1y 2r 3g 4b
int upit = 0; // Int read as Boolean, random, "up it" up the value or not, beware wrap 1-4.
last = millis();
while (true) {
do {delay(20);}
sleeper();
now = millis();
increment();
if (now - last >= pause) { // Time to move it one.
// First get the new LED number.
upit = random(0,2); // Returns 0,1 can be read as Boolean.
last = millis(); // Update that.
if (upit) {
which++;
if (which > 4) which = 1;
else { // Else don't up-it, lower it 1-4.
which--;
if (which < 1) which = 4;
if (which == 1) yellow_only();
else if (which == 2) red_only();
else if (which == 3) green_only();
else blue_only();
} // if time to move it one
} // while true
} // random_path
void bounce() { // 1, then 2&4, then 3, then 2&4, then 1, etc
// Similar to sideside function.
int which_step = 1; // Which step of the pattern, so which is on and which is next (1, 2, 3, 4).
unsigned long last = millis();
const int pause = 33; // adjusted
yellow_only(); // start
while (true) {
do {delay(20);}
sleeper();
now = millis();
increment();
last = millis();
which_step++;
if (which_step > 4) which_step = 1;
if (which_step == 1) yellow_only();
else if (which_step == 2) {digitalWrite(led_red, HIGH); digitalWrite(led_blue, HIGH); digitalWrite(led_yellow, LOW);}
else if (which_step == 3) green_only();
else if (which_step == 4) {digitalWrite(led_red, HIGH); digitalWrite(led_blue, HIGH); digitalWrite(led_green, LOW);}
} // while true
} // bounce
void sideside() { // u, r, d, r, u, l, d, l, u, etc, 1 2 3 4 for position, do where in pattern?
int which_step = 1; // Which step of the pattern, so which is on and which is next.
// 1u 2r 3d 4r 5u 6l 7d 8l 9u that is the start again so 1-8.
while (true) {
do {delay(20);}
sleeper();
now = millis();
increment();
last = millis();
which_step++;
if (which_step > 8) which_step = 1;
else if (which_step == 2) red_only();
else if (which_step == 4) red_only();
else if (which_step == 5) yellow_only();
else if (which_step == 6) blue_only();
else if (which_step == 7) green_only();
else if (which_step == 8) blue_only();
} // while true
} // sideside
void fire() {
// Start on blue, blink three times, fire aross to red, bounce back to y/g and b.
const unsigned long pause_between = 175;
// Seven blinks in the pattern. Hard code the entire thing why not.
unsigned long starter = 0;
unsigned long step1_on = 10; // B blinks three times.
unsigned long step1_off = 20;
unsigned long step2_on = 30;
unsigned long step2_off = 40;
unsigned long step3_on = 50;
unsigned long step3_off = 100; // longer pause before firing 100 so far times adjusted
unsigned long step4_on = 105; // b fires
unsigned long step4_off = 110;
unsigned long step5_on = 115; // hits r
unsigned long step5_off = 120;
unsigned long step6_on = 125; // bounces back to y/g
unsigned long step6_off = 130;
unsigned long now;
while (true) {
do {delay(20);}
sleeper();
increment();
now = millis();
if (now - start >= starter) {digitalWrite(led_blue, HIGH); starter += (155 + pause_between);}
else if (now - start > step1_on) {digitalWrite(led_blue, LOW); step1_on += (155 + pause_between);}
else if (now - start > step1_off) {digitalWrite(led_blue, HIGH); step1_off += (155 + pause_between);}
else if (now - start > step2_on) {digitalWrite(led_blue, LOW); step2_on += (155 + pause_between);}
else if (now - start > step2_off) {digitalWrite(led_blue, HIGH); step2_off += (155 + pause_between);}
else if (now - start > step3_on) {digitalWrite(led_blue, LOW); step3_on += (155 + pause_between);}
else if (now - start > step3_off) {digitalWrite(led_blue, HIGH); step3_off += (155 + pause_between);} // blue fires
else if (now - start > step4_on) {digitalWrite(led_blue, LOW); step4_on += (155 + pause_between);}
else if (now - start > step4_off) {digitalWrite(led_red, HIGH); step4_off += (155 + pause_between);} // s4 done, red lights up
else if (now - start > step5_on) {digitalWrite(led_red, LOW); step5_on += (155 + pause_between);}
else if (now - start > step5_off) {digitalWrite(led_yellow, HIGH); digitalWrite(led_green, HIGH); step5_off += (155 + pause_between);} // red done, y and g light up
else if (now - start > step6_on) {digitalWrite(led_yellow, LOW); digitalWrite(led_green, LOW); step6_on += (155 + pause_between);}
else if (now - start > step6_off) {
step6_off += (155 + pause_between);
int x = 200; // HIGH val for LED rounded down a bit.
float y = 0.0;
unsigned long previous_millis = millis();
while (true){
now = millis();
increment();
return; // break out of the function completely
if (x <= 0) break; // should break out of this inner while but not return
if (now - previous_millis >= 5) {
x = x - 10;
y = gamma_correct(x);
analogWrite(led_blue, y);
} // while inner true / button catch
} // If step_6 is completed.
} // while true
} // fire
void fireworks() {
// g pops, then y lights up and fades and r/b sparkle (back forth fast, and fade), like a firework. Requires PWM.
unsigned long now;
unsigned long previous_millis = millis(); // For fade cycle.
const int fade_interval = 7;
bool sparkle_lr = 1; // To alternate (sparkle) the two side LEDs.
int x = 200; // For brightness of LED fade.
int y; // Gamma corrected version of our good friend x.
const int pause_between = 150; // This is important or the green fires too soon. Also interacts with fade_interval and x.
unsigned long step1_start = 50; // Initial firing of the firework.
unsigned long step1_end = 57;
unsigned long step2_start = 100;
while (true) {
do {delay(20);}
sleeper();
now = millis();
increment();
if (now - start > step1_start && now - start < step1_end) digitalWrite(led_green, HIGH);
else if (now - start > step1_end) {
if (now - start > step2_start && x > 0) { // If in step2, x is the LED fade.
if (now - previous_millis >= fade_interval) { // If so, time to +/- LEDs.
sparkle_lr = !sparkle_lr;
x = x - 7;
analogWrite(led_yellow, y);
if (sparkle_lr) {analogWrite(led_blue, y); digitalWrite(led_red, LOW);}
else {analogWrite(led_red, y); digitalWrite(led_blue, LOW);}
} // if it is time to +/- the LEDs
} // if in step2
else if (x <= 0) {
step1_start = step1_start + pause_between; // If these step1 aren't here, they get out of sync due to x not being millis-centric.
step1_end = step1_end + pause_between;
step2_start = step2_start + pause_between;
start = start + pause_between;
init_off();
x = 200;
} // while true
} // fireworks
// END OF CODE
