Yet another Finite State Machine introduction
Hello everyone,
On this gray day, considering the number of questions that boil down to programming a finite automaton (or a state machine), I thought I would translate my small tutorial I also have in French to explain how to approach this type of code in a structured manner. Of course, there are libraries that do this more or less for you, but understanding how it works can often allow you to do without libraries that might weigh down your code.
The general idea is to write a program that controls a "system" that must react by triggering "actions" that modify the system, for example, based on "events" that occur, and the reaction may depend on the current state of your system.
Here's a real-life example to better understand:
Take a light bulb connected to a push-button switch. You press the button, what should happen? It's simple: if the bulb was off, then it should turn on (action = power the bulb), and if it was on, then it should turn off (action = cut off power to the bulb).
So, we introduce the concept of the system's state here.
We will have two states: lightOff and lightOn, which we will depict like this
and there is only one possible event, which is clicking the button.
When an event is detected, it triggers an action that may lead to a state change. In this scenario, if the system is in the "off" state and detects a button click, it will transition to the "on" state. During this transition, a specific action is taken – turning the light on. Similarly, when the system is in the "on" state, a click event will lead to a transition to the "off" state, accompanied by the action of turning the light off.
Therefore, we can represent our system as follows:
Very often, we encounter such systems in timers. We can thus introduce a new type of event related to the time spent in a particular state. In the case of a timer, if the system is in the "on" state and the set time has elapsed, it is necessary to turn off the light. Here, we observe an event (timeout), an action (turning off the light), and a state transition (moving from "on" to "off").
Therefore, we can represent our system with an additional transition as follows:
Since the purpose of this tutorial is not to delve into the theory of finite automata, I'll let you explore Wikipedia for more information and will focus on examples that are commonly encountered when working with Arduinos.
To make this type of coding easier, you need to understand a few elements of the C++ language.
A practical tool for the state machine programmer: enumerations
In C++, an enumeration is a type, named or not, that groups in a list named constants
There is an associated value for each element in the list which will be distinct from the others — by default the first will be 0, the second 1, the third 2, etc. For example, you can write the following code:
enum {monday, tuesday, wednesday, thursday, friday, saturday, sunday} day;
This declares a variable day that can take on one of the values from the list (monday, tuesday, wednesday, thursday, friday, saturday, sunday).
click if you want to read more about enums
So, if you run the following code on an Arduino:
  day = thursday;
  Serial.println(day);
void loop() {}
You will see "3" in the Serial console (set at 115200 baud).
If you want to assign specific values to certain elements in the list, it's possible. The default numbering starts at 0 and increments by 1, unless the program explicitly assigns a value to enumerated constants (in which case it takes that value, and the following ones increment by one compared to the preceding one in the declaration order). For example:
enum {monday=1, tuesday, wednesday, thursday, friday, saturday, sunday} day;
This declares that Monday is 1, so Tuesday is 2, and so on. If you use this definition in the above code, instead of printing "3," you will see "4." (You could also say:
enum {monday, tuesday, wednesday, thursday=12, friday, saturday, sunday} day;
In this case, Monday would be 0, Tuesday 1, Wednesday 2, Thursday 12, Friday 13 (lucky number), Saturday 14, etc.)
Note that since C++11 (available in the latest versions of the IDE), it is possible to define the underlying type for enumeration variables. By default, it is an integer (type int) that takes up two bytes of memory on an UNO. If you have only a few states (less than 255) and their values don't matter (below 255), you can add the byte type to the declaration and save one byte. You might also want to use unsigned long, for example, if you need large predefined values like reading an IR remote code.
In this code, the variable day will be an int on two bytes:
And in this code, the variable day will be a byte, so on a single byte:
enum :byte {monday, tuesday, wednesday, thursday, friday, saturday, sunday} day;
Why am I mentioning this? Because an enum is very convenient for listing the states of our system so that the programmer can easily understand it.
In the above example of the timer, we saw that we had two states. Thus, we could declare:
enum {lightOff, lightOn} currentState;
This way, we define a variable currentState that can take on the value of lightOff or lightOn.
Another practical tool for the state machine programmer: the switch/case statement.
I'll let you read the programming documentation on the switch/case statement. Its interest lies in the fact that often in our state machines, we need to say "if the current state is this, then do this; otherwise, if the current state is that, then do something else, etc."
If you have many possible states, all these nested tests make the code difficult to read, and the switch/case statement simplifies all of that. By cleverly combining this with our enum, for example, we can write:
switch (currentState) {
  case lightOff:
    // do something
  case lightOn:
    // do something else
Let's look at a Practical Implementation:
Let's build a case somewhat similar to that of the timer but a bit more complex to have many states to manage.
Step 1: Set up your breadboard and connect the Arduino.
You will need:
  • 4 LEDs of different colors (red, orange, yellow, green)
  • 4 resistors of 200Ω or 220Ω for example (suitable for current limiting with your LEDs)
  • A momentary button
  • An Arduino UNO or similar
  • Wires to connect everything
Here is the setup:
Connect:
  • Pin 4 ➜ Button ➜ GND (wire in diagonal across the button ensures the correct pin connections)
  • Pin 8 ➜ 220 Ω ➜ (anode) Red LED (cathode) ➜ GND
  • Pin 9➜ 220 Ω ➜ (anode) Orange LED (cathode) ➜ GND
  • Pin 10➜ 220 Ω ➜ (anode) Yellow LED (cathode) ➜ GND
  • Pin 11➜ 220 Ω ➜ (anode) Green LED (cathode) ➜ GND
Now, starting from here, we will perform a couple exercises
Exercise #1
In this exercise, we want to start with all lights off, and the button should sequentially turn on the LEDs,
  • First press: the green LED lights up.
  • Second press: the green LED stays on, and the yellow LED lights up.
  • Third press: the orange LED lights up in addition.
  • Fourth press: the red LED lights up in addition.
  • Fifth press: everything turns off.
This strongly resembles a state machine, which we could describe as follows:
The states:
  • All off (REST)
  • Green LED on (G)
  • Green and Yellow LEDs on (GY)
  • Green, Yellow, and Orange LEDs on (GYO)
  • Green, Yellow, Orange, and Red LEDs on (GYOR)
Initial state = REST
Possible action = click on the button
And here is the diagram of possible transitions:
so how are we going to code this ?
In order to focus on the core topic, I will use a button library. There are many available and I like Toggle from @dlloyd. He introduced his library here in the forum and his GitHub offers extra information (and source code).
The library is pretty simple to use. You define a Toggle instance, in the setup you call begin passing the pin number and in the loop you poll the button to update its state and you have simple functions you can call to detect if an event happen. The most useful one for us is onPress() which returns true once when the button has been pressed. The library manages bouncing for us.
So back to our code.
We need to declare all the pins used for the LEDs, instantiate the button, and code the state machine using a union for the different states names, we will have a neat switch/case, as mentioned above.
Here is a Wokwi for testing
click to see the code
// Button management library
#include <Toggle.h> //  https://github.com/Dlloydev/Toggle
const byte buttonPin = 4; // Our button is on pin 4
Toggle button;
// Pins used for LEDs
const byte pinRedLed = 8;
const byte pinOrangeLed = 9;
const byte pinYellowLed = 10;
const byte pinGreenLed = 11;
// The list of possible states of our system
// along with a currentState variable taking one of these values
enum {REST, STATE_G, STATE_GY, STATE_GYO, STATE_GYOR} currentState;
void turnLedsOff() {
  digitalWrite(pinGreenLed, LOW);
  digitalWrite(pinYellowLed, LOW);
  digitalWrite(pinOrangeLed, LOW);
  digitalWrite(pinRedLed, LOW);
void runStateMachine() {
  button.poll(); // update the state of the button
    case REST:                            // we are at rest and if we get a click, turn on the green LED
      if (button.onPress()) {             // this is our event detection
        digitalWrite(pinGreenLed, HIGH);  // execute the associated action. Green LED powered
        currentState = STATE_G;           // note the new state of our system
    case STATE_G:                         // green LED was on and if we get a click, turn on the yellow LED
        digitalWrite(pinYellowLed, HIGH); // execute the associated action. Yellow LED powered
        currentState = STATE_GY;          // note the new state of our system
    case STATE_GY:                        // green and yellow were on, if we get a click, turn on the orange LED
        digitalWrite(pinOrangeLed, HIGH); // execute the associated action. Orange LED powered
        currentState = STATE_GYO;         // note the new state of our system
    case STATE_GYO:                       // green, orange, and yellow were on, if we get a click, turn on the red LED
        digitalWrite(pinRedLed, HIGH);    // execute the associated action. Red LED powered
        currentState = STATE_GYOR;        // note the new state of our system
    case STATE_GYOR:                      // everything was on, if we get a click a click, return to rest
        turnLedsOff();                    // execute the associated action. return to the initial state
        currentState = REST;
// We initialize our system in the setup
  // configure
  pinMode(pinRedLed, OUTPUT);
  pinMode(pinOrangeLed, OUTPUT);
  pinMode(pinYellowLed, OUTPUT);
  pinMode(pinGreenLed, OUTPUT);
  button.begin(buttonPin);
  // define Initial conditions
  turnLedsOff();
  // we update ou system based on possible events
  runStateMachine();
  // Here, we can do other things as long as it doesn't take too long and is non blocking
All the intelligence of the machine is in the runStateMachine() function, which is straightforward to read thanks to the switch/case and the use of easily readable state codes as declared in the enum and the convenient Toggle library.
In simple terms, within the switch/case, for each state we check if the button has been pressed and if it is we know that we need to move to the next state. By looking at the diagram, we know what action to take and what the next state is. So, it's just a matter of coding that. It's quite simple! :blush:
Exercise #2
In this exercise, we are asked to ensure we don't waste energy. We should not keep the light on for too long, so we are required to add a timer. The specification says: "If the light is on for more than 15 seconds without any user action, then turn everything off."
Now that we are experienced, we immediately see that this involves a new type of event that we will need to consider in our state machine: the passage of time.
Our machine is therefore getting a little more complicated. We have a new event to consider, the "timeout" event which will generate new transitions: a transition from all states except "all off" to the "all off" state.
On a diagram, the new transitions look like this:
(Of course, they are added to the existing transitions.)
How are we going to handle this?
Certainly, we cannot use delay(15000) in our code; otherwise, the buttons would no longer be operational. We must not block the code.
We won't reinvent the wheel for this; we'll use a classic technique.
You have all read the tutorial (if not, you should) "Blink Without Delay," which is one of the standard examples for time management.
For extra information and examples look at
Once you grasp this concept, we will apply it.
So, we will need a variable chrono that will store the "time" of the last user action and a constant for how long we need to wait before registering a timeout event
// Introducing time as an additional event
unsigned long chrono; // Note: unsigned long, like millis()
const unsigned long TimeOut = 15000ul; // 15 seconds (ul at the end for unsigned long, a good habit to adopt)
We need to rearm our timer every time the user presses a button, since the specifications say 15 seconds after the last action. Therefore, we will add a line of code in our state machine function to reset our "stopwatch":
chrono = millis(); // We just had an action, so we reset our stopwatch
last we should we test for time out.
We could add this test into all states (in then switch) this would be done by adding this test to all. states except REST
      else if (millis() - chrono >= TimeOut) { // timeout event
        turnLedsOff();
The function would then become
        turnLedsOff();
        turnLedsOff();
        turnLedsOff();
        turnLedsOff();
The positive aspect of doing this is that we maintain only one switch/case where all the relevant events are tested against each state (so we have one if for every arrow leaving a state)
The negative aspect is that we repeated a lot of code. Not everything needs to be in the switch/case, as long as the events are tested you are fine. So a better code would be to first test for the clicks and then if the state is not REST, test for timeout
here is the wokwi with this second approach
#include <Toggle.h> // // https://github.com/Dlloydev/Toggle
Toggle button;
  // TEST FOR CLICK
  // TEST FOR TIMEOUT
  if ((currentState != REST) && (millis() - chrono >= TimeOut)) {     // timeout event
    turnLedsOff();
  // configure
  turnLedsOff();
  runStateMachine();
as you can see now we have a more complex state machine with many transitions
but the code stayed simple and easy to read.
using state machines is a good way to first think about the system you want to manage, see what state can exist and what triggers transitions between those states and then it's easy to code and your code architecture is sound / easy to extend.
exercice 3
➜ left to the reader
rewrite the code using the OneButton library.
In this library you use attach callback functions to the button for specific events and when it happens, the function is called. You can have a callback for a simpleClick for example, and this is a good place where you could have your state machine.
exercice 4
extend now your code to add double click. A double click should light on all LEDs if they are not all on, and turn them all off is they are all on.
This is an event easily tracked by the OneButton library and so you attach a callback to the doubleClick event in which you have another small state machine dealing with the various sates.
In a switch you can group cases that have a similar treatment so the function could be like
void doubleClickCallback() {
    case REST:                      // we are at rest and if we get a double click, turn all LEDs on
      turnLedsOn();                 // execute the associated action. return to the initial state
    case STATE_G:                   // green LED was on and if we get a double click, turn all LEDs off
    case STATE_GY:                  // green and yellow were on, if we get a double click,  turn all LEDs off
    case STATE_GYO:                 // green, orange, and yellow were on, if we get a double click,  turn all LEDs off·
    case STATE_GYOR:                // everything was on, if we get a click a double click,  turn all LEDs off
have fun.
Is there a non blocking delay that's as easy to use as the built in delay function?
Clubbing 2 or more programs
Programming for Arduino Uno
ESP 32 Sensor data collection
Looking for some state machine design advice
One button library - isIdle not triggering after sleep
How can I set a variable in loop and use it in setup?
Wokwi Simulations for Arduino Built-In Examples
Web Server are laggy, so slow or even can't be opened
PIR sensor problem
Do Loop running over RTC comparison
When to read sensors whilst running a state machine?
HELP! Changing the melody using buttons while it's playing
Const char START_CHAR = '<'; const char END_CHAR = '\n';
Optimizing code for SPEED / STABILITY, ways to write, stepper example
How to use an ezButton to turn off the alarm on a sunrise alarm clock
Muting a buzzer with a button until a value is reached again
I need help replacing a series of delay() statements
Boat Project code help
K changes loop not working
The output is coming slowly to serial monitor
Plant watering system
Which code is better for 3 leds ON OFF via Serial
Controllind solenoid using arduino two modes of operation
Code is randomly getting stuck in a particular function
Esp8266 play sound engine simulation
Pause and Resume incrementing
I need help with a combination game
20x4 LCD i2c menu with rotary encoder
Arduino Library for UART base Displays
Several challenges while programming an auto-winding airsoft magazine
First code troubleshooting
Problem to read the http get response with GSM A7670
Using snore function for ATtiny 85
Function in .cpp crashes device after 20 seconds (watchdog?)
Seeking assistance with an Arduino RFID-based medication management system that is failing to enter 'DangerState' and failing to function properly
'Clap-on, clap-off' servo not working
Issue with LCD Display of Time on Timer
Adding in a pause button to a loop
Debugging Two ways communication between Python3 and Arduino
Beginner needs help with debounce logic
HELP! Additional 8 Relay without delay
Delay help with neopixel strip
Pressing two buttons at once
Understanding serial communication with another software
Read a specific hex byte from a data packet
Error de mi código
Tricky code to write
Need HELP for a Arduino Menu code
Replacing a 10k potentiometer with a programmable timer
Help with switching players in a 2p game
WS8211 Uno and DY SV5W MEGATRON
Arduino ATMEGA 2560 serial communication with another ATMEGA2560
Simultaneous short and long presses
Problem with long delay
Arduino problema a unire 2 codici
IR Remote & Servo Motor
Code check please - [SOLVED]
ATMEGA328PB wake with button & interrupt
Need help with toggle switching a servo in "for" loop
Gave up on millis and using delay instead for two separate things
Variable not updating unless printed, or something else?
Multiple relays
Serial communication overflow
Void loop inside a switch case?
Can this be done with a state machine
Recording time difference between input0 and input1
Variable zone/relay Timer
Multiple state machines
Traffic light system Way too complex ? for a beginner (1 - 2 years)
Flowchart for school
How do I structure a logic to store the pin number in an array?
Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled
Problem to integrate another sound in a project with buzzer
Multiple relays
State code for two functions on on switch
Make the button differentiate between 2x and 1x press
AccelStepper and two buttons simplest code
Stop a motor with a sensor
The forward and reverse problem of the two automatic doors with DC motors and limit switch sensors
Storing Button State
Removing delay()
Applying a PAUSE and RESUME feature in my Pneumatic Pick-and-Place Project
Code not continuing after hitting one combination of conditions (logic issue)
The blinking LEDs wont run in Sequence 3 codes
Blink without delay Leuchtturm Roter Sand
Multiple tasks from one if-statment
To read the state of two break beam sensors for robot arm
Photo & Motion sensor issue
Flashing 2 LEDS independent timing when button is pressed
Click button "if statement"
Coding with "millis()" with "pseudo-results" (not working as intended)
The lcd screen doesn't show the input from the keypad
Duration from CloudSchedule variable not working!
Using Interrupts With If Statements
Combine multiple state machines
Sketch fails after running successfully first time
Problem with code for arduino game
Help with do/while loops
Need help making this bluetooth ball gun
Need help writing a state machine
Please help a noob figure out his DIY MIDI project
Using AccelStepper to execute premade set of movements
Running 2 functions on ESP8266 (Buzzer and display)
Coding help for Arduino Light Sequence
How to verify if an audio file has completed playing on the DFPlayer Mini
LINE CHANGING Function in arduino uno and l293d motor shield
Loops with conditions
Servo code non blocking
How do i multi task with an arduino uno
Stepper Motor not moving
Trying to add a button in my For Cycle
Want Help With My Project (Arduino Car/Robot)
Using array notation or similar to create multiple instances of a State Machine
3in1 carwash vendo machine
Building a UI with different Menus and Submenus on Arduino
I need a counting system for arduino 21 key remote. sorry if in wrong topic, im new
Arduino nano "swallowing" timings?
Converting fixed length string to char and float
1 analog in, 2 digital out
How to make a loop run for a specific time then switch to another loop and then back and so on
I do not read analog input with millis function
Repeated Beam Sensor Inputs interfering with Loop
Changing loops using ky-40 encoder button
Simultaneous loops
My school is stupid
How to use millis as a timer after a button press
Random output to relays
Find peak value of piezo sensor hit, multiple sensors
Code doesn't work and port problem's
Help in Arduino code! [SOLVED]
How to blink a light without blocking other functionality
Help...what is going on?
How to make a Flappy Bird game on an 8×8 LED Matrix with MAX7219 driver
Whack a Mole - Need a 'Winner' Counter!
IF Loops and timers
Fermare una funzione
Map() function output
Interruttore automatico - Risolto
Stepper Motor Position Using Button Presets
Hi guys, I am trying to build a final project for school. Trying to control a stepper motor speed with a rotary encoder, but so far no luck
Continue an IF statement after input is stopped
Matrix multitap keypad
How to control 3 LED's using SunriseSunset data from SolarCalculator library
Traffic light intersection simulation project
Another millis() Question
Vehicle Immobiliser with Auto-Start function - A small problem!
Présentation projet et demande conseils
12 button wireless buzzer game - ambitious?
Programming help
Millis() in 2 var: 2nd var is smaller than first?
State machine design?
N/South Traffic lights with two pedestrian buttons using millis()
Faster ADC on Arduino R4 Wifi
Arduino based rc car with object follow
Switch-case with enum won't activate unless a button is pressed
How do i get the both motors to work at the same time with a timer?
Password protected system
How to build a relay timer
Delay() appears to no longer operate in ms
Arduino UNO Freezes after a few hours
Stepper with 2 blinking leds
Blinking LED while continuous servo moves
Create code for a semi random FastLED pattern
One if statement overwriting another if statement
Setting variable and overriding for a timer in arduino
Making a LED switch but it's a bit more complex
Limit byte values with Encoder
