Good Morning,
on PIN 13 I've connected a RELAY ... this relays in during arduino boot-up change a couple of times a state ...
this i think is not a good thing for my circuit because the connected devices is turned on and off in couple of seconds ...
reading the datesheet seems that is a clock out also ...I don't know if is this the reason for this kind of behavior ...
SCK/PCINT5 – Port B, Bit 5
SCK: Master Clock output, Slave Clock input pin for SPI channel. When the SPI is enabled as a Slave, this pin is configured as an input regardless of the setting of DDB5. When the SPI is enabled as a Master, the data direction of this pin is controlled by DDB5. When the pin is forced by the SPI to be an input, the pull-up can still be controlled by the PORTB5 bit.
PCINT5: Pin Change Interrupt source 5. The PB5 pin can serve as an external interrupt source.
Of course I can connect my delays on another pin but the problem is that I've my printed circuit board already did ... and I would like to use this without change for the moment it ...
I presume the atmega328p is on the PCB, rather than on an Arduino connected to the PCB. Did you include a 6-pin ICSP header on the PCB? If so, then you can program the chip using ICSP without a bootloader - which will fix the problem, because it is the bootloader that is pulsing that pin.
yes in the project there is burn the software via ISP now I've discover how to burn it ... so right now I burning only boot loader but the software i didn't find again how upload via isp ...
Configure the hardware as if you are burning the bootloader. Then upload your sketch, but instead of clicking the Upload button, hold down the Shift key and click the Upload button (or select "Upload using programmer" from the File menu).
What microcontroller exactly are you using on your board? The thread title mentions atmega328pu, so why are trying to build/upload for Arduino 2560, which uses a different processor?
btw as well as the atmega328-pu there is the atmega328p-pu, which is the one used on the Uno. They have different signatures. Make sure you know which one you have. If you select File->Preferences and then check "Show verbose output during upload", then I think it will display the device signature it finds when you try to upload.
Hi thanks for the information sorry for the delay burt I was at work a little bit busy ;-( ...
so this is the message. In my project I've 2 different arduino used ... UNO and 2560 then I will need to upload sketch into UNO and 2560. But if i will necessary I will do: UNO with ATMEGA328 and 2560 with atmega2560 ... What I don't understand is ...why I can upload with ISP cable that I've did (then I think is working with reset and other stuff...) I can uploader bootloader into ATMEGA328 and into ATMEGA2560 via isp and for the sketch I've this kind of issues ?
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/gnusso/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem621
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
