Attaching a wire to board with shield
code 1 (works, very basic). D1 Mini v4 with RED LED shield
// light show runs dim white when power on, button pushed once for 10 min each color and ends on bright white
//#include <ArduinoWiFiServer.h>
//#include <BearSSLHelpers.h>
//#include <CertStoreBearSSL.h>
//#include <ESP8266WiFi.h>
//#include <ESP8266WiFiAP.h>
//#include <ESP8266WiFiGeneric.h>
//#include <ESP8266WiFiGratuitous.h>
//#include <ESP8266WiFiMulti.h>
//#include <ESP8266WiFiScan.h>
//#include <ESP8266WiFiSTA.h>
//#include <ESP8266WiFiType.h>
//#include <WiFiClient.h>
//#include <WiFiClientSecure.h>
//#include <WiFiClientSecureBearSSL.h>
//#include <WiFiServer.h>
//#include <WiFiServerSecure.h>
//#include <WiFiServerSecureBearSSL.h>
//#include <WiFiUdp.h>
#define BUTTON_PIN 16
#define PIXEL_PIN D4
#define PIXEL_COUNT 7
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
boolean oldState = HIGH;
int     mode     = 0;    // Currently-active animation mode, 0-9
//  WiFi.mode(WIFI_OFF);
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  strip.begin(); // Initialize NeoPixel strip object (REQUIRED)
  strip.show();  // Initialize all pixels to 'off'
// Fill strip pixels one after another with a color. Strip is NOT cleared
// first; anything there will be covered pixel by pixel. Pass in color
// (as a single 'packed' 32-bit value, which you can get by calling
// strip.Color(red, green, blue) as shown in the loop() function above),
// and a delay time (in milliseconds) between pixels.
void colorWipe(uint32_t color, int wait) {
  for (int i = 0; i < strip.numPixels(); i++) { // For each pixel in strip...
    strip.setPixelColor(i, color);         //  Set pixel's color (in RAM)
    strip.show();                          //  Update strip to match
    delay(wait);                           //  Pause for a moment
  // Get current button state.
  boolean newState = digitalRead(BUTTON_PIN);
  // Check if state changed from high to low (button press).
  if ((newState == LOW) && (oldState == HIGH)) {
    // Short delay to debounce button.
    delay(20);
    // Check if button is still low after debounce.
    if (newState == LOW) {     // Yes, still low
      colorWipe(strip.Color(255,  0,   0), 0);    // Red
      delay(600000)  ;
      colorWipe(strip.Color(255,  150,   0), 150);    // Yellow
      delay(600000)  ;
      colorWipe(strip.Color(0,  255,   0), 150);    // Green
      delay(600000)  ;
      colorWipe(strip.Color(0,  0,   255), 150);    // Blue
      delay(600000)  ;
      colorWipe(strip.Color(180,  0,   255), 150);    // Purple
      delay(600000)  ;
      strip.clear();
      colorWipe(strip.Color(255,  255,   255), 0);    // White
      delay(0)  ;
    // Set the last-read button state to the old state.
    oldState = newState;
Code 2 (Works when written for an Uno and does with a breadboard, but not when put on the D1 Mini v4 with RED LED shield). [On a seperate note, I'm looking for a way to make this code waaayyy less complex. It currently feels like it's way more complex than it needs to be and I'd also like to be able to easily change the colors and delay times much easier.]
// State Machine x 2 controlling 1 Neopixel unit with different patterns and working Abort
// D1 mini
#define BUTTON_PIN2 5
//#define microsInOneSecond 1000000UL
//Top level variables:
int DEBUG = 1; //set to 1 to enable serial monitor debugging info
//Switch 1 variables:
int state_s1 = 0;
int state_prev_s1 = 0;
int pin_s1 = 16; //button 1
const int BUTTON1 = 16;
int val_s1 = 0;
unsigned long t_s1 = 0;
unsigned long t_led1 = 0;
unsigned long t_0_s1 = 0;
unsigned long bounce_delay_s1 = 10;
//unsigned long bounce_delay_s1a = 10;
unsigned long hold_delay_s1 = 1000;
//Switch 2 variables:
int state_s2 = 0;
int state_prev_s2 = 0;
int pin_s2 = 5; //button 2
const int BUTTON2 = 5;
int val_s2 = 0;
unsigned long t_s2 = 0;
unsigned long t_led2 = 0;
unsigned long t_0_s2 = 0;
unsigned long bounce_delay_s2 = 20;
unsigned long hold_delay_s2 = 1000;
//NEOPIXEL variables
int state_led1 = 0;//actual state of the state machine
int state_prev_led1 = 0;  //remember the prev state
int val_led1 = 0; //LED value (on or off)
int pin_led1 = D4;
unsigned long current_t_led1 = 0;  //current time of the LED state
unsigned long previous_t_led1 = 0; //previous time of the LED state
unsigned long t_0_led1 = 0; //The time that we last passed through a state of interest
unsigned long t_0_led1a = 0;
unsigned long on_delay_led1  = 5000;  //on time for the LED as it beeps
unsigned long off_delay_led1 = 5000;  //off time for the LED as it beeps
int beep_count_led1 = 0;  //number of times we've light up on this journey
int beep_number_led1 = 1;  //number of times we should light before resetting
//RED LED variables
int state_led2 = 0;//actual state of the state machine
int state_prev_led2 = 0;  //remember the prev state
//int pin_led2 = 11;  //LED pin
int val_led2 = 0; //LED value (on or off)
unsigned long current_t_led2 = 0;  //current time of the LED state
unsigned long previous_t_led2 = 0; //previous time of the LED state
unsigned long t_0_led2 = 0; //The time that we last passed through a state of interest
unsigned long on_delay_led2  = 5000;  //on time for the LED as it beeps
unsigned long off_delay_led2 = 5000;  //off time for the LED as it beeps
int beep_count_led2 = 0;  //number of times we've light up on this journey
int beep_number_led2 = 1;  //number of times we should light before resetting
  pinMode(16, INPUT_PULLUP);
  pinMode(pin_led1, OUTPUT);
  pinMode(10, INPUT_PULLUP);
  //pinMode(pin_led2, OUTPUT);
  //if DEBUG is turned on, initialize serial connection
  if (DEBUG) {
    //Serial.begin(115200);
    Serial.println("Debugging is ON");
  Serial.println( F( "\n\n\n  Loop Counter, free by GoForSmoke\n" ));
  Serial.println( F( "This sketch counts times that loop has run each second and prints it." ));
void colorClear(uint32_t color, int wait) {
//----------------State Machine S1 ---------------------
void StateMachine_s1() {
  //almost every state needs these lines, so I'll put it outside the State Machine
  val_s1 = digitalRead(pin_s1);
  state_prev_s1 = state_s1;
  //State Machine Section
  switch (state_s1) {
    case 0: //RESET
      // catch all 'home base' for the state machine
        colorWipe(strip.Color(0,  0,  0),  0);
      delay(2000);
      state_s1 = 1;
    case 1: //WAIT
      //wait for the switch to go low
      if (val_s1 == LOW) {
        state_s1 = 2;
    case 2: //ARMING!
      //Record the time and proceed to ARMED
      t_0_s1 = millis();
      state_s1 = 3;
    case 3: //ARMED
      //Check to see if the proper delay has passed. If a bounce occurs then RESET
      t_s1 = millis();
      if (t_s1 - t_0_s1 > bounce_delay_s1) {
        state_s1 = 4;
      if (val_s1 == HIGH) {
        state_s1 = 5;
    case 4: //DRAWN
      //if switch goes HIGH then trigger. Also check timer for a "long press"
        state_s1 = 5;
    case 5: //TRIGGERED!
      //reset the state machine, start the LED state machine
      if (DEBUG) {
        Serial.println("TRIGGERED switch 1!!");
      state_s1 = 6;
    case 6: //LED ON
      t_0_led1 = millis();
        state_s1 = 7;
      if (DEBUG) {
        Serial.println("LED1 ON RED");
    // ------------ AFTER LED TURNED ON -----REPEATING BUTTON CHECK --------------------------------------------------------------------------
    case 7: //check position of button
        state_s1 = 8; //proceed to starting time for debounce to check if real button press
        state_s1 = 11; //if no pressed button, proceed to state 11
    case 8: //set switch start time
      t_0_s1 = millis();
      state_s1 = 9;
    case 9: //check bounce delay
      t_s1 = millis();
        state_s1 = 10; //state 10 will ABORT
        state_s1 = 8;
      } //if no pressed button, proceed to state 11 timed LED off
    case 10: //ABORT OPTION
      if (val_s1 == HIGH)
      Serial.println("ABORT");
        state_s1 = 0;
      //go back to very beginning RESET
    // ------------------- TURN LED OFF ----------------------------
    case 11: //Check button
        state_s1 = 12;
    // --------------- Turn LED to BLUE ---------------------------------
    case 12: //Timed LED TO BLUE
      t_led1 = millis();
      if ((t_led1 - t_0_led1) > off_delay_led1) (
          colorWipe(strip.Color(0,  0,  255),  150));
      previous_t_led1 = t_led1;
        state_s1 = 13;
      if ((t_led1 - t_0_led1) <= off_delay_led1) {
        state_s1 = 11;
    case 13: //announce LED OFF
      Serial.println("LED is Blue");
        state_s1 = 14;
    //------------------ TURN LED to GREEN --------------
    case 14: //Check button
        state_s1 = 15;
    case 15: //TIMED LED ON to green
      t_led1 = millis();
      if ((t_led1 - previous_t_led1) > on_delay_led1)
        state_s1 = 16;
      if ((t_led1 - previous_t_led1) <= on_delay_led1) {
        state_s1 = 14;
    case 16: //announce LED ON again
      Serial.println("LED is Green");
      state_s1 = 17;
    // --------------- Turn LED to PURPLE ------------------
    case 17: //Check button
        state_s1 = 18;
    case 18: //TIMED LED ON to Purple
      t_led1 = millis();
        colorWipe(strip.Color(127,  0,  255),  150);
        state_s1 = 19;
        state_s1 = 17;
    case 19: //announce LED ON again
      Serial.println("LED is PURPLE");
      state_s1 = 0;
  //Instruct all the state machines to proceed one step (sometimes called a "cycle)
  StateMachine_s1();
  /////////////// StateMachine_s2(); - removed this code due to length. its the same just a different switch number switch_s2
  //Provide events that can force the state machines to change state
  //I like to program interactions between state machines here in the top level loop
  //if (state_s1 == 5) {state_led1 = 2;} //short press
  if (DEBUG) {
    //Make a note whenever a state machine changes state
    //("Is the current state different from the previous? Yes? OK well let's tell the world the new state")
    if ((state_prev_s1 != state_s1) | (state_prev_led1 != state_led1)) {
      Serial.print("Switch 1 State: "); Serial.print(state_s1);
      Serial.print('\n');
    if ((state_prev_s2 != state_s2) | (state_prev_led2 != state_led2)) {
      Serial.print("Switch 2 State: "); Serial.print(state_s2);
      Serial.print('\n');
I'll see if I can draw a diagram. I'm not good at that.
thanks
Ok, hopefully this helps.
This is the log. you can see if its pushed the state only gets to case 4
16:13:50.297 -> f2$l⸮⸮X⸮⸮⸮tR⸮⸮⸮⸮4⸮RhDebugging is ON
16:13:50.439 ->
16:13:50.439 ->
16:13:50.439 ->
16:13:50.439 -> Loop Counter, free by GoForSmoke
16:13:50.486 ->
16:13:50.486 -> This sketch counts times that loop has run each second and prints it.
16:13:54.463 -> Switch 1 State: 1
16:13:54.463 -> Switch 2 State: 1
16:13:54.463 -> Switch 2 State: 2
16:13:54.463 -> Switch 2 State: 3
16:13:54.510 -> Switch 2 State: 4
16:13:55.485 -> Switch 1 State: 2
16:13:55.485 -> Switch 1 State: 3
16:13:55.485 -> Switch 1 State: 4
case 4: //DRAWN
        state_s1 = 5;
which is where it should detect the button going high and trigger the next step
You have set pinMode()s for pins 16 and 10 in your sketch. Which pins are these on the D1 Mini ?
if you look at the 3rd picture (blue pcb with the sun on it) you can see the pin numbers
im not sure where you see that? They are set to 16 and 5
good catch! thanks! I'll change that and see what happens
no, it didn't work. It actually not even hooked up to a button right now anyway as I'm trying to troubleshoot one at a time. There seems to be some problem with it detecting the pull up to HIGH. not sure how to figure that out. I've checked the button with a multimeter and it checks out fine. But even if i touch the ground wire to 16 it doesn't detect it like a button
As you don't read that pin in your sketch posted recently I assume that you are referring to another sketch . Hoe exactly did you connect buttons to your pins eventually, which was your original question ?
I must be misunderstanding something. Is this not reading it?
int state_s1 = 0;
Those 4 lines of code don't read anything, they declare and define the value of variables
These are what I think are some of the relevant lines which should be checking the status of the button. Am I missing something? (note the are taken from various places in the sketch)
case 1: //WAIT
        state_s1 = 2;
case 2: //ARMING!
      t_0_s1 = millis();
      state_s1 = 3;
    case 3: //ARMED
      t_s1 = millis();
        state_s1 = 4;
        state_s1 = 5;
    case 4: //DRAWN
        state_s1 = 5;
      if (DEBUG) {
      state_s1 = 6;
    case 6: //LED ON
        state_s1 = 7;
      if (DEBUG) {
You have given pin 16 names in multiple ways
This itself is not a problem but it does make following the program logic more difficult. Start by using only one method to give pin 16 a name and use that throughout the sketch
You also have a variables named state_s1 and val_s1 which, although they hold different values, confuse things by having similar names. One appears to be the state of pin 16
and the other is used in switch/state. I suggest that you consider renaming val_s1 to something more meaningful such as button_pin_state to make the code more readable
None of these changes may fix your problem but should make reading the code easier
Later in the sketch you do
When you push the button, the color sequence should run until you let the button go?
Tape is an amazing, and underappreciated, invention.
