The code below does two things I do not understand...
When the code runs, the very first thing is a serial output of
button PRESSED: 9
originally I didn't have the delay() in the setup() and it sensed a pressed @ 0 millis().
I can end up with "button pressed" as the last thing in the serial output, despite the button NOT being pressed -- I can verify this by using an led or volt meter in line, but in simpliest mode
Ground -> button -> arduino digital pin 2.
So even tho the button isn't pressed, the code thinks otherwise. Next button press will result in a single "button RELEASED".
Can someone explain that please? I'm totally losted.
Still, an initial "button pressed' message, and pressing/releasing the button can result in a "button pressed" message remaining (and again, pressing the button generates only a button released" message, no double "button pressed" so it doesn't seem to be a timing issue, athough it must be.
attachInterrupt(digitalPinToInterrupt(learn_PIN), &buttonDown, CHANGE);
Where does it say to use '&' for the ISR (in re. the syntax)?
I was reviewing and they updated the Reference since the (only) time I ever did with an ISR [using the direct interrupt number instead of this newer 'digitalPinToInterrupt()' convention.]
How it's wired (@vaj4088): Sorry for not being clear: The button is between ground and pin #2 so when it's pushed, it brings pin#2 to ground. See attached, both fritzing & image
Clear Interrupt flag (@dlloyd): Cool; but that doesn't explain why I an end up in a button-pushed state when it's released... See attached, I am not 'holding' the button when I take the screen shot
"&" convension(@Runaway Pancake) -- like a LOT of things in arduino, it can be "Arduino" or "C"... that is distracting from the question... Take it out if it helps you... Result is the same. This code is identical, and used in the above image.
Also you do not denounce so your interrupts when functioning correctly will catch many up and down events while you think you just pressed the button once
dlloyd:
You'll need to clear the interrupt flag in setup after you configure pin 2 as INPUT_PULLUP and write HIGH to the pin.
There is no need to write HIGH to the pin - that's what INPUT_PULLUP does for you - sets the pin as INPUT And then set it HIGH to activate the built in PULLUP hence the mode INPUT_PULLUP
The interrupt flag is probably not set at that time unless the button was already pressed but indeed no harm in clearing it properly unless the button is down in which case you might want to capture this
I thought either way would only clear bit 0 in the register by writing logical 1 to it.
Sorry, I'm failing to see the difference in the net effect ... unless "|=" takes 2 cycles and "=" is a one cycle operation. Is that it?
The main thing here is you don't read the actual state of the button.
The button will bounce. If you press it, it falls, but if it bounces up again before the ISR is ended to handle the falling you have an error. Because now you are waiting for it to rise but it's already high. And because you Serial.print() in the interrupt the interrupt is SLOW.
And it's a bit overkill to use the interrupt pins for a simple button... Just poll it
Also, using
const byte LearnPin = 2;
to avoid the macro madness is considered to be better. See
My assumption that setting the INPUT_PULLUP before attaching the interrupt would actually guarantee that the pin is not floating as we steer that pin to a known state.
in recent (a few years now?) versions of the library, the first call to attachInterrupt in the program clears all interrupt flags.
--> so if there is no code before pinMode in the setup() does anything calls attachInterrupt and thus does create a situation where the Interrupt flag would be set before we prevent the pin from floating?
for intellectual curiosity of the readers
(because this surprised me when I learnt about it)
EIFR = bit(INTF0); // clear INT0 interrupt flag
...is the correct way to clear the flag.
Indeed. while the other way with a [color=blue][b]|=[/b][/color] would seem reasonable and might work, it generates loads of unnecessary code to read the value and then writing the logical 1 which clears the flag. [EDIT after the good comment from Whandall below: You might also clear the other interrupt if it was set though which is possibly not what you want to do!]
if you read the ATMEGA reference for this register (look for 13.2.3 EIFR – External Interrupt Flag Register) , the flag is actually cleared by writing a logical one to it. One may worry about bits 7:2 but they are currently Read Only in hardware and Reserved for future use.
Oh man, any other bits that are set in the register basically clear themselves. I guess with any register designed in this fashion (writing logical 1 clears the bit), you would need to do this.
Oh man x??!, in the Due there dozens and dozens of registers like this just for operations with I/O. Gulp.
dlloyd:
Exactly.
Exactly.
J-M-L:
would the clearing of the flag be necessary?
Yes. After enabling the pull-up (and waiting five clock cycles which occurs naturally because of overhead) and before calling attachInterrupt. If spurious triggers should be ignored the sequence is...
• Enable pull-up
• Wait five clock cycles (not necessary when using Arduino API functions)
• Clear the appropriate flag
• Call attachInterrupt
The External Interrupt hardware is functional from power-up. If the appropriate trigger ever occurs the INTF0 flag is set.
