I tried to remove some excess blank lines and give it a saner indentation...
//Interrupt implemenation.
const int led = 13;
const int zone1 = 8;
const int zone2 = 9;
const int zone3 = 10;
const int zone4 = 11;
const int in1 = 2; //Interrupt 0;
const int in2 = 3; //Interrupt 1;
int ledState = LOW;
int buttonState =0;
unsigned long previousMillis = 0,preM1=0,preM2=0,preM3=0,preM4=0,preMS=0,preInt=0,preUni;
long interval = 1000;
unsigned long UniTime = 1000; //60*60*60*1000;
int StateCheck =1;
int StateCheck2 =0;
int ZoneCheck=1,ZoneCopy=1;
int i=0;
int Track=0,Track1=0,Track2=0,Track3=0,Track4=0,TrackS,TrackUni;
unsigned long PreMcounter =0;
unsigned long MilliCounter =0;
// digital pins=output
pinMode(led, OUTPUT);
pinMode(zone1, OUTPUT);
pinMode(zone2, OUTPUT);
pinMode(zone3, OUTPUT);
pinMode(zone4, OUTPUT);
pinMode(in1, INPUT);
pinMode(in2, INPUT);
attachInterrupt(0, StateChange, LOW);
attachInterrupt(1, Check, LOW);
switch (ZoneCheck) {
case 1:
if (StateCheck == 1) {
Flash();
Zone1F(UniTime);
else {
digitalWrite(zone1, LOW);
case 2:
Flash();
Zone2F(UniTime);
else {
digitalWrite(zone2, LOW);
case 3:
Flash();
Zone3F(UniTime);
else {
digitalWrite(zone3, LOW);
case 4:
Flash();
Zone4F(UniTime);
else{
digitalWrite(zone4, LOW);
case 5:
if (StateCheck == 2) {
ZoneCopy = ZoneCheck;
Zone1F(10000);
Flash();
//Special Zone function on Zone1
int ZoneSpec1(int c)
if (TrackS==0)
preMS = millis();
TrackS=1;
unsigned long curMS = millis();
if(curMS - preMS < c)
digitalWrite(zone1, HIGH);
TrackS =0;
StateCheck = 0;
//Zone Functions
int Zone1F(int c)
if (Track1==0)
preM1 = millis();
Track1=1;
unsigned long curM1 = millis();
if(curM1 - preM1 < c)
else if (curM1 - preM1 > c)
Track1 =0;
ZoneCheck = 2;
int Zone2F(int c)
if (Track2==0)
preM2 = millis();
Track2=1;
unsigned long curM2 = millis();
if(curM2 - preM2 < c)
digitalWrite(zone2, HIGH);
Track2 =0;
ZoneCheck = 3;
int Zone3F(int c)
if (Track3==0)
preM3 = millis();
Track3=1;
unsigned long curM3 = millis();
if(curM3 - preM3 < c)
digitalWrite(zone3, HIGH);
Track3 = 0;
ZoneCheck = 4;
int Zone4F(int c)
if (Track4==0)
preM4 = millis();
Track4=1;
unsigned long curM4 = millis();
if(curM4 - preM4 < c)
digitalWrite(zone4, HIGH);
Track4 =0;
ZoneCheck = 1;
StateCheck = 0;
//LEDBlink Storie
void Flash()
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(led, ledState);
//PORTED CODE !
void Check()
if (StateCheck == 0)
StateCheck = 2;
ZoneCheck = 5;
// digitalWrite(led, HIGH);
detachInterrupt(1);
else if(StateCheck == 1)
StateCheck = 2;
ZoneCheck = 5;
// digitalWrite(led, LOW);
detachInterrupt(1);
int UniDelay(int c)
int i=0;
if (TrackUni==0)
preUni = millis();
TrackUni=1;
int t = (c*10000);
unsigned long curUni = millis();
if(curUni - preUni < t)
i++;
TrackUni =0;
/* void StateCheck(int x)
for (int i=0;i<x+1;i++)
else if(StateCheck == 0)
{break;}
int Zone1F(int c)
unsigned long preM = previousMillis;
unsigned long curM = millis();
if ((curM - preM) <= c)
curM = millis();
//StateChange();
ZoneCheck = 1;
previousMillis = preM;
else if ((curM - preM) > c)
//StateChange()
ZoneCheck = 2;
void StateChange()
StateCheck = 1;
Track =0;
else if(StateCheck == 1) {
StateCheck = 0;
//digitalWrite(led, LOW);
Uh ?
detachInterrupt(1);
Still quite puzzling code, especially without any comment.
You should either add copious comments or describe what you're trying to achieve.
