Attempting to program the AD7745 to detect capacitance values
For my project, I am using an AD7745 to detect the capacitance in a droplet as it passes. I have the wiring correctly connected, though I think there may be issues with the code:
#include <Wire.h>
// Define the AD7745 I2C address and register addresses
// These address pointers were from page 14 of the AD7745 datasheet
#define AD7745_ADDRESS 0x48
#define AD7745_CAPDATA 0x00
#define AD7745_CONFIGURATION 0x01
#define AD7745_CAPACITANCE_MSB 0x02
#define AD7745_CAPACITANCE_LSB 0x03
const int AD7745_RDY_PIN = 28;// RDY pin is connected to digital pin 28 on Arduino Due
// Define a variable to hold the capacitance value
float capacitanceValue;
  Wire.begin();
  // Set the AD7745 configuration
  Wire.beginTransmission(AD7745_ADDRESS);
  Wire.write(AD7745_CONFIGURATION);
  Wire.write(0x00);
  Wire.endTransmission();
  // Set the Arduino digital pin for the AD7745 RDY pin as an input
  pinMode(AD7745_RDY_PIN, INPUT);
  // Wait for the AD7745 RDY pin to go high
  while (digitalRead(AD7745_RDY_PIN) == LOW) {}
  // Read the capacitance value from the AD7745
  Wire.write(AD7745_CAPACITANCE_MSB);
  Wire.requestFrom(AD7745_ADDRESS, 2);
  uint8_t msb = Wire.read();//variables to store two bytes of data read from AD7745
  uint8_t lsb = Wire.read();
  capacitanceValue = ((msb << 8) | lsb) * 0.000001;  // Convert raw value to capacitance in farads
  // Print the capacitance value to the Serial monitor
  Serial.print("Capacitance value: ");
  Serial.print(capacitanceValue, 6);  // Print with 6 decimal places
  Serial.println(" F");
  // Wait for a short time before starting the next conversion
  delay(100);
What I am trying to do is that I want to see that the capacitance can change if I wave my hand above it, even when there are no capacitors connecting to its appropriate pins. The problem I am encountering is that the serial monitor is continuously producing the exact same capacitance value every second with absolutely no changes whether I have the capacitor connected to it or not.
Check up this topic: "How to get the best out of this forum." regarding posting code.
Forum is usually interested in schematics for issues like this. Pen and paper often works well.
