hai i'm developing a pico farad(30pf to 300pf) range capacitance meter and its accuracy is 1pf by using aurdino i just used several codes but its not working properly, please help me to complete my project , if i use any AD7745 ic ist good or not, if it is good please help me on that area.
Welcome to the forum
As your project has nothing to do with the actual Arduino Project it has been moved from that category to a more relevant one
Does your software detect the AD7745?
We need the following to accurately answer your question:
Annotated Schematic: Clearly show all connections, including power, ground, and power sources. This will help us understand your circuit setup and identify potential issues.
Technical Information Links: Provide links to technical documentation for each hardware component in your setup. Avoid links to sales sites like Amazon, as they often lack the detailed specifications we need to assist you effectively.
Why Do We Want This:
We can’t accurately assist without knowing the specifics of your setup. Clear, detailed descriptions will allow us to offer the best help possible. Without this information, diagnosing and solving your issues will be much harder.
Give yourself an belated Christmas present and pick up these resources, along with the Arduino Cookbook:
- Electronics for Beginners (eBook): Electronics For Beginners (eBook)
- Arduino Step-by-Step Projects Course: Arduino Step-by-step Projects Course | Build 25 Projects"
No not detected
not detected
Then there is a problem with the I2C bus.
Do you have the correct pull-up resistors?
Which Arduino are you using?
Hi, @ajaycmet
Can you please post some code that doesn't work?
What do you mean "not working properly"?
Tom....
