Hi!
Im trying to use the DS18B20 sensor for one of my wireless-sensor projects.
But don´t seem to work with the ATtiny1614?
Im using the OneWire lib, and the demosketch works fine on the Arduino Nano, but when im trying the same sketch on the Attiny1614 it seems to be stucked at the "No more adresses"?
And the temp always returns "-0.06"?
Here´s the code:
#include <OneWire.h>
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// https://github.com/milesburton/Arduino-Temperature-Control-Library
OneWire ds(2); // on pin 10 (a 4.7K resistor is necessary)
void setup(void) {
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
Could it be that the OneWire lib doesn´t support the megaTinyCore ( Im using spenceKonde )?
I also tried the Dallas lib but it wouldn´t even complie on the ATtiny1614, I got this message:
In file included from megaTinyCore\hardware\megaavr\2.2.7\cores\megatinycore/api/ArduinoAPI.h:52:0,
from megaTinyCore\hardware\megaavr\2.2.7\cores\megatinycore/Arduino.h:23,
from libraries\OneWire/OneWire.h:13,
from libraries\DallasTemperature\DallasTemperature.h:25,
from libraries\DallasTemperature\DallasTemperature.cpp:6:
libraries\DallasTemperature\DallasTemperature.cpp: In member function 'void DallasTemperature::setResolution(uint8_t)':
megaTinyCore\hardware\megaavr\2.2.7\cores\megatinycore/api/Common.h:45:22: error: 'l' was not declared in this scope
typeof (low) _l = (l); \
libraries\DallasTemperature\DallasTemperature.cpp:255:18: note: in expansion of macro 'constrain'
bitResolution = constrain(newResolution, 9, 12);
megaTinyCore\hardware\megaavr\2.2.7\cores\megatinycore/api/Common.h:45:22: note: suggested alternative: '_l'
megaTinyCore\hardware\megaavr\2.2.7\cores\megatinycore/api/Common.h:46:23: error: 'h' was not declared in this scope
typeof (high) _h = (h); \
megaTinyCore\hardware\megaavr\2.2.7\cores\megatinycore/api/Common.h:46:23: note: suggested alternative: '_h'
megaTinyCore\hardware\megaavr\2.2.7\cores\megatinycore/api/Common.h:47:35: error: expected ';' before '}' token
_x < _l ? _l : _x > _h ? _h :_x })
libraries\DallasTemperature\DallasTemperature.cpp: In member function 'bool DallasTemperature::setResolution(const uint8_t*, uint8_t, bool)':
libraries\DallasTemperature\DallasTemperature.cpp:281:21: note: in expansion of macro 'constrain'
newResolution = constrain(newResolution, 9, 12);
I can´t find any example with the DS18B20 running on the new ATtiny 1-series chips?
Regards
