Hello community,
I've spent ~10 hrs and still unable to get my code to workable state and need some help.
Short: I have deep sleep (PWR_DOWN) in my Attiny85 code. The wake trigger is external interrupt or pin change interrupt. When I'm trying to use watchdog for power-efficient time counting, it's not working.
However, it's working when I add delays in function which enables watchdog.
Setup:
- ATTINY85 at Digispark dev board;
- running at 1 MHz;
- pin 3 is connected to shake sensor;
- pin 2 is connected to button;
- 2 and 3 is in INPUT_PULLUP, other sides are connected to GND.
Workflow:
ShakeSensor producing PC interrupt, setting the flag. If this flag is set, payload inside loop is executed and loop counter will be reset.
If flag is not set, watchdog timer is being started for 120 ms. After that loop counter will be incremented.
If loop counter exceeds constant, MCU will fall into deep sleep.
Button will generate external interrupt which will reset duty cycle.
If I'll have delay(60) in WDT setup, it's working.
If I'll replace WDT sleep by delay(120), it's working.
I left some commented lines with alternatives which I've checked and they didn't work too.
What's wrong with my code?(below)
Code:
#include <Arduino.h>
#include <avr/wdt.h>
#include <avr/sleep.h>
#include <avr/power.h>
#define led1 0 //1
#define led2 1 //2
#define led3 4 //4
#define shakeSensor 3
#define buttonPin 2
const int brightness = 64;
int count = 50;
int time = 500;
volatile int idlecycles = 0;
volatile bool blockInterrupted = false;
volatile bool interrupted = false;
const int cyclesCuttOff = 50;
int target;
//workers
void roll();
void showSequence(int, int, int);
void blinkNumber(int, int);
void showNumber(int, int);
void fadeNumber(int);
//sleep, wdt, interrupts
void fallasleep();
void letTheDogOut();
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(shakeSensor, INPUT_PULLUP);
pinMode(buttonPin, INPUT_PULLUP);
pinMode(5, INPUT);
cli();
GIMSK = _BV(INT0) | _BV(PCIE); //INT0, PCINT0
PCMSK = _BV(PCINT3);
sei();
ADCSRA &= ~(1 << ADEN);
power_adc_disable();
blinkNumber(5, 250);//ready
bool getInterrupted()
return interrupted && !blockInterrupted;
void fallasleep()
blinkNumber(6, 250); //show that we're going to sleep
cli();
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
// Turn off ADC
ADCSRA = 0;
// diable all modules availables
power_all_disable(); // power off ADC, Timer 0 and 1, serial interface
//configure interrupts
GIMSK = _BV(INT0); //external only
sleep_enable();
sei();
sleep_cpu();
sleep_disable();
power_all_enable(); // power everything back on
cli();
GIMSK |= _BV(PCIE); //both
sei();
blinkNumber(1, 250); //exiting sleep
void letTheDogOut()
//delay(60); //Suddenly working OK with delays
//blinkNumber(3, 50);
/*cli();
MCUSR = 0;
WDTCR = _BV(WDCE) | _BV(WDE) | bit(WDIF); //enable editing, disable reset, clean old int flag (?!)
WDTCR = _BV(WDIE) | _BV(WDP1) | (WDP0); //run dog for ~125ms*/
wdt_reset();
wdt_enable(WDTO_120MS);
WDTCR |= _BV(WDIE);
sleep_enable();
sei();
sleep_cpu();
sleep_disable();
//blinkNumber(4, 50);
//interrupt handlers
ISR(PCINT0_vect)
interrupted = true;
ISR(INT0_vect)
ISR(WDT_vect)
wdt_disable();
idlecycles++;
//main loop
if (interrupted || digitalRead(shakeSensor) == 0) //pulled down by shaking
interrupted = false;//clear flag
idlecycles = 0;//reset idle counter
roll();
fadeNumber(target);
//delay(120);idlecycles++ //working with delay instead of watchdog
letTheDogOut();//handler will increment cycles count
if (idlecycles >= cyclesCuttOff)//going into deep sleep
blockInterrupted = true;
fallasleep();
//delay(500);
fadeNumber(target); //showing last number after pressing the button
idlecycles = 0;
//LED routines below
