Hi
Got a problem with the new IDE 2.0. Everytime I try to program a ATTINY85 using a UNO as an ISP I keep getting the same error message of A Programmer is required to upload
The same code compiles and uploads using IDE 1.8.
Here is the output in IDE 2 when I try to upload the code.
Using board 'attinyx5' from platform in folder: C:\Users\Bowling tough\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Using core 'tiny' from platform in folder: C:\Users\Bowling tough\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Detecting libraries used...
"C:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=1000000L -DCLOCK_SOURCE=0 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D\\sketch\\Gauge_04_Production.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=1000000L -DCLOCK_SOURCE=0 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D\\sketch\\Gauge_04_Production.ino.cpp" -o "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny85 -DF_CPU=1000000L -DCLOCK_SOURCE=0 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB "-IC:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D\\sketch\\Gauge_04_Production.ino.cpp" -o "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D\\sketch\\Gauge_04_Production.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\Bowling tough\AppData\Local\Temp\arduino-core-cache\core_f236c7af231037a1903fbc3de79cce54.a
Linking everything together...
"C:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=attiny85 -o "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D/Gauge_04_Production.ino.elf" "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D\\sketch\\Gauge_04_Production.ino.cpp.o" "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D/..\\arduino-core-cache\\core_f236c7af231037a1903fbc3de79cce54.a" "-LC:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D" -lm
"C:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D/Gauge_04_Production.ino.elf" "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D/Gauge_04_Production.ino.eep"
"C:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D/Gauge_04_Production.ino.elf" "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D/Gauge_04_Production.ino.hex"
"C:\\Users\\Bowling tough\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\Bowling tough\\AppData\\Local\\Temp\\arduino-sketch-C4B20AB9ED6E433021D0B50C0BA9762D/Gauge_04_Production.ino.elf"
Sketch uses 1408 bytes (17%) of program storage space. Maximum is 8192 bytes.
Global variables use 9 bytes (1%) of dynamic memory, leaving 503 bytes for local variables. Maximum is 512 bytes.
A programmer is required to upload
