Auduino Synth - LED Code combined with Synth code
hello all,
i was hoping someone could help me with combining the 2 attached codes...or at least letting me know if it is even possible.
i want the "Analog in 4: Grain repetition frequency" in the audino_v5.pde code to be merged with the flashing LED (the LED_code.pde) so that changes in the position of the "Analog in 4" potentiometer will correspond with the flashing frequency of the LED.
will this work?
auduino_v5.pde (6.04 KB)
LED_code.pde (993 Bytes)
Please post your code using code tags. The code tags make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click. Unless the sketch is too large, it's better if you post your code, rather than attach it. When it's attached, we have to download it, create a folder then open your code in our IDE. And afterwards, the folder remains unless we navigate to the "Temp" folder and manually remove it. It's much easier to just view the code in your post.
sorry about that!
OK. so what i want to do is take this code for the synth (i'm using potentiometers instead of LDRs):
  Example using 2 light dependent resistors (LDRs) to change
  FM synthesis parameters, and a knob for fundamental frequency,
  using Mozzi sonification library.
  Demonstrates analog input, audio and control oscillators, phase modulation
  and smoothing a control signal at audio rate to avoid clicks.
  Also demonstrates AutoMap, which maps unpredictable inputs to a set range.
  This example goes with a tutorial on the Mozzi site:
  http://sensorium.github.io/Mozzi/learn/Mozzi_Introductory_Tutorial.pdf
  The circuit:
     Audio output on digital pin 9 (on a Uno or similar), or
     check the README or http://sensorium.github.com/Mozzi/
     Potentiometer connected to analog pin 0.
       Center pin of the potentiometer goes to the analog pin.
       Side pins of the potentiometer go to +5V and ground
     Light dependent resistor (LDR) and 5.1k resistor on analog pin 1:
       LDR from analog pin to +5V
       5.1k resistor from analog pin to ground
     Light dependent resistor (LDR) and 5.1k resistor on analog pin 2:
  Mozzi help/discussion/announcements:
  https://groups.google.com/forum/#!forum/mozzi-users
  Tim Barrass 2013.
  This example code is in the public domain.
#include <MozziGuts.h>
#include <Oscil.h> // oscillator
#include <tables/cos2048_int8.h> // table for Oscils to play
#include <Smooth.h>
#include <AutoMap.h> // maps unpredictable inputs to a range
// int freqVal;
// desired carrier frequency max and min, for AutoMap
const int MIN_CARRIER_FREQ = 22;
const int MAX_CARRIER_FREQ = 440;
const int MIN = 1;
const int MAX = 10;
const int MIN_2 = 1;
const int MAX_2 = 15;
// desired intensity max and min, for AutoMap, note they're inverted for reverse dynamics
const int MIN_INTENSITY = 700;
const int MAX_INTENSITY = 10;
// desired mod speed max and min, for AutoMap, note they're inverted for reverse dynamics
const int MIN_MOD_SPEED = 10000;
const int MAX_MOD_SPEED = 1;
AutoMap kMapCarrierFreq(0,1023,MIN_CARRIER_FREQ,MAX_CARRIER_FREQ);
AutoMap kMapIntensity(0,1023,MIN_INTENSITY,MAX_INTENSITY);
AutoMap kMapModSpeed(0,1023,MIN_MOD_SPEED,MAX_MOD_SPEED);
AutoMap mapThis(0,1023,MIN,MAX);
AutoMap mapThisToo(0,1023,MIN_2,MAX_2);
const int KNOB_PIN = 0; // set the input for the knob to analog pin 0
const int LDR1_PIN=1; // set the analog input for fm_intensity to pin 1
const int LDR2_PIN=2; // set the analog input for mod rate to pin 2
const int LDR3_PIN=4;
const int LDR4_PIN=3;
Oscil<COS2048_NUM_CELLS, AUDIO_RATE> aCarrier(COS2048_DATA);
Oscil<COS2048_NUM_CELLS, AUDIO_RATE> aModulator(COS2048_DATA);
Oscil<COS2048_NUM_CELLS, CONTROL_RATE> kIntensityMod(COS2048_DATA);
int mod_ratio = 5; // brightness (harmonics)
long fm_intensity; // carries control info from updateControl to updateAudio
// smoothing for intensity to remove clicks on transitions
float smoothness = 0.95f;
Smooth <long> aSmoothIntensity(smoothness);
void setup(){
  Serial.begin(115200); // set up the Serial output so we can look at the light level
  startMozzi(); // :))
void updateControl(){
//  freqVal = map(LDR3_PIN, 0, 1023, 1, 100);
   int freqVal = mozziAnalogRead(LDR3_PIN); // value is 0-1023
   int FRQ = mapThis(freqVal);
   int knob2 = mozziAnalogRead(LDR4_PIN); // value is 0-1023
   int knob2Val = mapThis(knob2);
  // read the knob
  int knob_value = mozziAnalogRead(KNOB_PIN); // value is 0-1023
  // map the knob to carrier frequency
  int carrier_freq = kMapCarrierFreq(knob_value);
  //calculate the modulation frequency to stay in ratio
  int mod_freq = carrier_freq * mod_ratio * FRQ;
  // set the FM oscillator frequencies
  aCarrier.setFreq(carrier_freq);
  aModulator.setFreq(mod_freq);
  // read the light dependent resistor on the width Analog input pin
  int LDR1_value= mozziAnalogRead(LDR1_PIN); // value is 0-1023
  // print the value to the Serial monitor for debugging
  Serial.print("LDR1 = ");
  Serial.print(LDR1_value);
  Serial.print("\t"); // prints a tab
  int LDR1_calibrated = kMapIntensity(LDR1_value);
  Serial.print("LDR1_calibrated = ");
  Serial.print(LDR1_calibrated);
 // calculate the fm_intensity
  fm_intensity = ((long)LDR1_calibrated * knob2Val * (kIntensityMod.next()+128))>>8; // shift back to range after 8 bit multiply
  Serial.print("fm_intensity = ");
  Serial.print(fm_intensity);
  // read the light dependent resistor on the speed Analog input pin
  int LDR2_value= mozziAnalogRead(LDR2_PIN); // value is 0-1023
  Serial.print("LDR2 = ");
  Serial.print(LDR2_value);
  // use a float here for low frequencies
  float mod_speed = (float)kMapModSpeed(LDR2_value)/1000;
  Serial.print("   mod_speed = ");
  Serial.print(mod_speed);
  kIntensityMod.setFreq(mod_speed);
  Serial.println(); // finally, print a carraige return for the next line of debugging info
int updateAudio(){
  long modulation = aSmoothIntensity.next(fm_intensity) * aModulator.next();
  return aCarrier.phMod(modulation);
void loop(){
  audioHook();
and combine it with this flashing LED code here (where Pin2 will be the pot controlling the LED):
/* Analog Read to LED
 * turns on and off a light emitting diode(LED) connected to digital
 * pin 13. The amount of time the LED will be on and off depends on
 * the value obtained by analogRead(). In the easiest case we connect
 * a potentiometer to analog pin 2.
 * Created 1 December 2005
 * copyleft 2005 DojoDave <http://www.0j0.org>
 * http://arduino.berlios.de
int potPin = 2;    // select the input pin for the potentiometer
int ledPin = 13;   // select the pin for the LED
int val = 0;       // variable to store the value coming from the sensor
  pinMode(ledPin, OUTPUT);  // declare the ledPin as an OUTPUT
  val = analogRead(potPin);    // read the value from the sensor
  digitalWrite(ledPin, HIGH);  // turn the ledPin on
  delay(val);                  // stop the program for some time
  digitalWrite(ledPin, LOW);   // turn the ledPin off
i'm not exactly sure how to accomplish this...and, can i use separate tabs for the entire sketch?
any help is appreciated...the more i can see and compare, the faster i catch on. thanks!
