Auto Format don't work
They work, but they might not do what you want
One thing you might notice is that sometimes there is a bit of a delay between they time you click (or use the keyboard shortcut) the Auto Format and when the sketch is updated. The reason is because the auto formatter is part of the language server and the language server must preprocess your program after every change to turn it from Arduino language into the C++ it understands. You'll see an indicator when this is in process by the spinning arrows circle indicator at the bottom left of the window.
The bug of the auto format capability intermittently failing to do anything is being tracked here:
