Auto reset problem on Atmega4809
Hi everyone
I wrote a code for serial testing.
I made a simple counter for each data transmission, and I noticed that the processor automatically resets at the same point or count value.
Does anyone know what's happening?
[code]
#define led 39
int counter = 0;
  pinMode (led, OUTPUT);
  Serial.println("START"));
    digitalWrite (led, HIGH);
    delay (300);
    digitalWrite (led, LOW);
       counter = 0;
}   // end setup routine
          counter += 1;
          Serial.println (counter);
//      Serial.println ("Hello World");
        delay (500);
        delay (1500);
}   // end main loop
[/code]
I disabled the reset pin (40) and left it as GPIO and the problem stopped.
Short circuit between PF5 and PF6?
No pullup resistor PF6 (RESET)?
Watchdog reset?
Hi, @jjcohen
Have you got a current limit resistor in series with the LED?
What Arduino controller are you using?
How are you powering your project?
Some images of your project would also help.
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
That doesn't compile.
 Serial.println("START");
Hi everyone.
Thank you for all the replies.
I discovered that the reset problem was caused by a watchdog timer connected to the circuit's reset line. When this timer is not triggered, it resets the microcontroller.
I use this timer to wake up the MCU every minute, as I turn it off completely to save power.
Therefore, this topic could be closed. Additional information below.
I have another question about the possibility of using the <SPI.h> library for the atmega4809 chip, so I ask: should I ask here or open another topic?
I would start a new topic as it does not sound like the new question has a relation with the problem described in the tile of this topic.
That shows that you should provide full information in an opening post; in this case your opening post should have included the schematic. Somebody could have picked up the WDT as a possible culprit 23 hours ago :slight_smile:
