Hi! This is my first Arduino project, so sorry if this is posted in the wrong thread/place. I've built a automatic door opener for my chickens using an arduino controlling a DC motor, 2 reed switches and a light sensor. It opens at sunrise and closes at sundown perfectly for 2-4 days, and then the trouble starts. Either i find the door not closed after dark, or it never opens during the morning/day. If i pull the power to the arduino and restart it, it will then work fine for a few days, before it malfunctions again. I will paste the code i've used. It has been a modified version of another project i found on Youtube. I have read somewhere that using "delay" is generally not advised, and I thought maybe that could be the problem, but I would appreciate any input.
Some more info : The BH1750 is the light sensor im using. Im using a TB6612FNG to control the motor.
// Newest
#include <Arduino.h>
#include <hp_BH1750.h>
hp_BH1750 BH1750;
int BUTTON_PIN1 = 7;
int BUTTON_PIN2 = 8;
int buttonState1 = 0;
int buttonState2 = 0;
int pwm = 12;
int in1 = 11;
int in2 = 10;
int MotorSpeed1 = 255;
bool avail = BH1750.begin(BH1750_TO_GROUND);
pinMode(BUTTON_PIN1, INPUT_PULLUP);
pinMode(BUTTON_PIN2, INPUT_PULLUP);
pinMode(pwm, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
buttonState1 = digitalRead(BUTTON_PIN1);
buttonState2 = digitalRead(BUTTON_PIN2);
if (buttonState2 != HIGH) {
// this function will run the motor down as long as switch 1 has not been triggered
while (buttonState2 != HIGH) {
// turn on motor and set speed to 255
analogWrite(pwm, 255);
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
//read the state of the switch again to make sure that it has not been triggered
// once buttonState2 has been triggered turn off the motor
digitalWrite(in2, LOW);
BH1750.start();
float lux = BH1750.getLux();
if (buttonState2 = HIGH && lux < 25)
delay(90000);
motordown();
else if (buttonState1 = HIGH && lux > 190) {
delay(90000);
motorup();
void motordown() {
BH1750.start();
//Read the state of switch 1 (the Bottom one) and place it in buttonState1
//read the state of switch 2 (the top one) and place it in buttonState2
//If switchState2 is high and the light is dark then continue
//wait 2 seconds
delay(3000);
//read the state of switch 1 (the bottom one) and place it in buttonState1
while (buttonState1 != HIGH) {
digitalWrite(in1, HIGH);
// now turn off motor
void motorup() {
BH1750.start();
//if switchState1 is high and the light is bright then continue
//delay 2 seconds
delay(3000);
//while buttonState2 is not high turn on the motor up
// this function will run the motor as long as switch 2 has not been triggered
I'm very confused by your sketch. You are restarting the BH1750 every time you want to take a measurement? That isn't necessary. If you want the BH1750 to only take a measurement when you want it to, you can put it into one-shot mode. I would look at this library as I found it easier to use with my BH1750 project. You can start the sensor once, put it into one-time mode and then trigger a reading when you want. I suspect you are running out of memory by starting the sensor every time you take a reading.
does the board have wifi? if so, then you could log information about the state to some kind of web service or local web server –> for example unexpected restarts
But if that doesn't pan, there is nothing wrong in your sketch that using millis() would fix, and both delay() and millis() can handle time forever.
Here's where the more info we'd like may come in handy.
A schematic, showing all the parts and how they are wired up with attention to include how they are wired for power, and where that power comes from.
A picture of your physical device, so we can see the wires and how tangled up or not they are, whether they are the right colour and so forth.
But first the restarting thing.
Most times, Arduinos can run forever. I can move my eyes just a bit and see three devices that have been in service here in the lab for years, only discontinuously so on account of power failures.
I presume your buttons are the limit switches, upper and lower, it might be worth calling them that to make you code easier to read.
upperLimitPin and lowerLimitPin.
Call pwm, motorSpeedPin.
Call in1 and in2, in1Pin and in2Pin, etc to identify them as fixed variables and pins.
There is some other code tidying you can do, but lets get your code working first.
So I've changed to the library you linked to now. I just used its default settings (continuous mode). So far it works fine, so I guess I'll just have to wait a few days to see if the problem occurs again. If it does I'll give the "one-time mode" a try. I didnt completely understand how to use the one-time mode, so thats why I try the continuous mode first. I have also cleaned up the code a bit and I will include it below. Thanks for all the suggestions so far! Really appreciate it!
#include <BH1750.h>
#include <Wire.h>
BH1750 lightMeter;
int lowerLimitPin = 7;
int upperLimitPin = 8;
int lowerLimitState = 0;
int upperLimitState = 0;
int motorSpeedPin = 12;
int in1 = 11;
int in2 = 10;
Wire.begin();
lightMeter.begin();
pinMode(lowerLimitPin, INPUT_PULLUP);
pinMode(upperLimitPin, INPUT_PULLUP);
pinMode(motorSpeedPin, OUTPUT);
lowerLimitState = digitalRead(lowerLimitPin);
upperLimitState = digitalRead(upperLimitPin);
if (upperLimitState != HIGH) {
// this function will run the motor down as long as upperLimitState has not been triggered
while (upperLimitState != HIGH) {
analogWrite(motorSpeedPin, 255);
// once upperLimitState has been triggered turn off the motor
float lux = lightMeter.readLightLevel();
if (upperLimitState == HIGH && lux < 25)
delay(90000);
motordown();
else if (lowerLimitState == HIGH && lux > 190) {
delay(90000);
motorup();
void motordown() {
//Read the state of switch 1 (the Bottom one) and place it in lowerLimitState
//read the state of switch 2 (the top one) and place it in upperLimitState
//wait 2 seconds
delay(3000);
//read the state of switch 1 (the bottom one) and place it in lowerLimitState
while (lowerLimitState != HIGH) {
void motorup() {
//if lowerLimitState is high and the light is bright then continue
//delay 2 seconds
delay(3000);
//while upperLimitState is not high turn on the motor up
I could certainly try to take some pictures and draw up a wire diagram. I just don’t understand how (if I hade wired it wrong) it would work for a couple of days after turning the power off and on again. I would have thought if there was something wrong with my wiring the door would not open/close at all
Without knowing what error is occurring you can't say for sure that it's not a mechanical problem. But I agree, it feels like a software problem. I have not used that BH1750 library. I use the Adafruit one. So I can't speak to whether that might be part of your problem. If you do decide to try the one-shot method, their library has an example of that included so it should be easy to switch.
You could also just write into your program to reset the board every day say, an hour after the door closes, therefore resetting the memory leak if there is one. Just add: void(* resetFunc) (void) = 0;
before your setup function. Then when you want to reset the board, just call: resetFunc();
But I would only use that as a last resort. I think there is still value in trying to nail down what the problem is and trying to fix it.
