Hello Guys,
i bought a shiny automatic hunter it uses a arduino nano with nano shield and 5 servos.
my problem is after some resets sometimes 100 or 500 - 1500 the servo that use most ( to press a and y butoon on the 3ds XL) it begins to jitter.
i tryed to use a new servo and another pin on the shield but nothing works in the long run.
here is the code maybe you can help. and is there normal that a pieeeeeeeep signal sound is always to listen ? ![]()
<#include <Servo.h>
#define NEWLINE '\n'
#define READ_LIGHT 'B'
#define READ_LIGHT_ADVANCED 'C'
#define LIGHT_LOW 'L'
#define LIGHT_HIGH 'H'
#define HOLD_UP '8'
#define HOLD_DOWN '2'
#define HOLD_LEFT '4'
#define HOLD_RIGHT '6'
#define PRESS_UP 'e'
#define PRESS_DOWN 'd'
#define PRESS_LEFT 's'
#define PRESS_RIGHT 'f'
#define BUTTON_A 'a'
#define BUTTON_B 'b'
#define BUTTON_X 'x'
#define BUTTON_Y 'y'
#define RELEASE_ALL '0'
#define SOFT_RESET_1 'S'
#define SOFT_RESET_2 'Z'
#define WONDER_TRADE 'W'
Servo myservo_1;
Servo myservo_2;
Servo myservo_3;
Servo myservo_4;
Servo myservo_5;
// Set variables for left and right buttons
int leftMax = 70;
int rightMax = 80;
int leftrightOff = 45;
// Set variables for up and down buttons
int upMax = 52;
int downMax = 96;
int updownOff = 74;
int YMax = 65;
int AMax = 80;
int AYOff = 45;
// Set variables for B and X buttons
int BMax = 70;
int XMax = 110;
int BXOff = 90;
// Set variables for Soft Reset
int SRMax = 100;
int SROff = 125;
int WMax = 130;
int arrowBackoffU = 5;
int arrowBackoffD = 5;
int arrowBackoffL = 5;
int arrowBackoffR = 5;
int arrow_releaseU=100;
int arrow_releaseD=100;
int arrow_releaseL=100;
int arrow_releaseR=100;
int button_release=120;
int prePress=200;
int lightCutoff = 150;
int LDR = 0;//pin assignment for LDR
int v1 = 0;
char b1;
myservo_1.attach(7);
myservo_2.attach(8);
myservo_3.attach(2);
myservo_4.attach(5);
myservo_5.attach(6);
pinMode(LDR, INPUT);
myservo_1.write(leftrightOff);
myservo_2.write(updownOff);
myservo_3.write(AYOff);
myservo_4.write(BXOff);
myservo_5.write(SROff);
if (Serial.available() > 0)
int letter = Serial.read();
if((letter != NEWLINE)&&(letter !=READ_LIGHT)&&(letter != READ_LIGHT_ADVANCED))
releaseAll();
switch (letter) {
//Compare Light sensor reading to cutoff value and return if it is higher of lower
case READ_LIGHT:
v1 = analogRead(LDR);
if(v1 < lightCutoff)
Serial.print(LIGHT_LOW);
Serial.print(LIGHT_HIGH);
//Take reading from light sensor, reduce range by factor of 4 and send to serial
case READ_LIGHT_ADVANCED:
delay(10);
b1=v1/4;
Serial.print(b1);
case HOLD_UP:
myservo_2.write(upMax);
delay(prePress);
myservo_2.write(upMax+arrowBackoffU);
case PRESS_UP:
delay(arrow_releaseU);
case HOLD_LEFT:
myservo_1.write(leftMax);
delay(prePress);
myservo_1.write(leftMax+arrowBackoffL);
case PRESS_LEFT:
delay(arrow_releaseL);
case HOLD_DOWN:
myservo_2.write(downMax);
delay(prePress);
myservo_2.write(downMax-arrowBackoffD);
case PRESS_DOWN:
delay(arrow_releaseD);
case HOLD_RIGHT:
myservo_1.write(rightMax);
delay(prePress);
myservo_1.write(rightMax-arrowBackoffR);
case PRESS_RIGHT:
delay(arrow_releaseR);
case BUTTON_Y:
myservo_3.write(YMax);
delay(button_release);
case BUTTON_B:
myservo_4.write(BMax);
case BUTTON_X:
myservo_4.write(XMax);
case BUTTON_A:
myservo_3.write(AMax);
case SOFT_RESET_1:
myservo_5.write(SRMax);
delay(250);
case SOFT_RESET_2:
delay(250);
case WONDER_TRADE:
myservo_5.write(WMax);
delay(250);
case RELEASE_ALL:
releaseAll();
void releaseAll() {
