Help with servos jittering
Hi I have an issue with a project im seem to have messed up on, I have a set of wooden blinds that are controled via servos, untill recentley they worked fine, however they are now jittering on occations and cant work out why?
There are three servos one coe each blind. As i say untill recentley they seemed to wrok fine, I did change the jumper wires for a screw terminal connection which is when the issue started but even changing back to the jumper wires does not seem to have solved the issue. this is the code appologies if I have added it wrong.
#include <VarSpeedServo.h>
#include <IRremote.h>
int IRpin = 2;  // pin for the IR sensor
IRrecv irrecv(IRpin);
decode_results results;
// create servo objects
VarSpeedServo myservo1;
VarSpeedServo myservo2;
VarSpeedServo myservo3;
  irrecv.enableIRIn();  // Start the receiver
  myservo1.attach(9);
  myservo2.attach(10);
  myservo3.attach(11);
  int OPEN = 70;
  int CLOSE = 180;
  int SPEED1 = 25;
  if (irrecv.decode(&results)) {
    irrecv.resume();  // Receive the next value
  if (results.value == 16343199)  // change according to your IR remote button number
    myservo1.attach(9);   // attaches the servo on pin 9 to the servo object
    myservo2.attach(10);  // attaches the servo on pin 10 to the servo object
    myservo3.attach(11);  // attaches the servo on pin 11 to the servo object
    myservo1.write(OPEN, SPEED1);
    myservo2.write(OPEN, SPEED1);
    myservo3.write(OPEN, SPEED1);
    delay(1700);
    myservo1.detach();  // wait for servo 1 to finish
    myservo2.detach();  // wait for servo 2 to finish
    myservo3.detach();  // wait for servo 3 to finish
    if (results.value == 16347279)  // change according  to your IR remote button number
          myservo3.attach(11);  // attaches the servo on pin 11to the servo object
          myservo1.write(CLOSE, SPEED1);
          myservo2.write(CLOSE, SPEED1);
          myservo3.write(CLOSE, SPEED1);
          delay(1700);
          myservo1.detach();  // wait for S1
          myservo2.detach();  // wait for S1
          myservo3.detach();  // wait for S1
          delay(100);
If you didn't change your code, probably the answer is not there. Or did you?
So maybe it's your wiring that you should present here.
You didn't mention your board either.
It is possible to push the cladding (plastic/pvc/coating) under the screw, missing the conductor of the wire.
Check the servo cables too
thanks for the advise I worked out it was two things after going to my local hackspace they suggested using a stop function before the detach and also that it may be the new speed connectors I had soldered into the servo wires, guess what, it was the speed connectors. so back to wagos not as neat but it works.
I have a small issue I’m hopping someone can help with. When my home theatre Onkyo amp is turned on or off it sometimes causes the blind servos to move position, they don’t move a full sweep just a small jump in position. Any suggestions? Thanks
I suspect that is a power and connection issue, again.
