I am very new to Arduino (and fritzing so please excuse my poor layout). I am trying to automate my patio sun shade, eventually it will incorporate a photocell but I wanted a proof of concept first with buttons. The first and last buttons represent limit switches and the middle button represents a toggle switch (which will eventually become the photocell).
An example of what I am trying to do is; If the upper limit switch is active and I press the toggle button, the stepper runs until it hits the lower limit switch, if the lower limit switch is active and I press the toggle button then the stepper should run the other direction until it hits the upper limit switch.
I have serial prints to show what is happening, if I hold either of the "limit switches" then the serial monitor displays (rather spams) the corresponding print line, however the stepper motor is not moving how I would expect it to. I have to be holding a limit switch and holding the toggle for it to move in a direction, even then it only moves approximately 1 step per second. If I release the limit switch and continue to hold the toggle then the stepper steps one back and one forward for the duration that I depress the switch. The code I have is based off of someone attempting the same thing but with a DC motor, I tried to accommodate it to a stepper motor and am having trouble.
// constants won't change. They're used here to set pin numbers:
const int uplimitPin = 9; // pin number for upper limit switch
const int togglebuttonPin = 10; // pin number for the toggle switch
const int downlimitPin = 11; // pin number for the lower limit switch
const int dirPin = 2; // direction pin for stepper
const int stepPin = 3; // step pin for stepper
// variables will change:
boolean uplimitState = 0; // variable for reading the status of the upper limit switch
boolean togglebuttonState = 0; // variable for reading the toggle switch status
boolean downlimitState = 0; // variable for reading the status of the lower limit switch
int shadePosition = 2; // Tells progam what position the shade is in
* setup inputs for switches and outs for motor pins
* serial begin to read the switches to test for errors
// initialize the stepper pins as outputs:
pinMode(dirPin, OUTPUT);
pinMode(stepPin, OUTPUT);
// initialize the pushbutton pins as an inputs:
pinMode(uplimitPin, INPUT);
pinMode(togglebuttonPin, INPUT);
pinMode(downlimitPin, INPUT);
* this function turns motor foward
void shadeDown() {
// turn motor foward:
digitalWrite(dirPin, HIGH);
digitalWrite(stepPin, HIGH);
delayMicroseconds(1000);
digitalWrite(stepPin, LOW);
* this function turns motor backwards
void shadeUp() {
// turn motor in other direction:
digitalWrite(dirPin, LOW);
* Stop the motor form moving
void stopShade() {
// read the state of the pushbutton value:
uplimitState = digitalRead(uplimitPin);
togglebuttonState = digitalRead(togglebuttonPin);
downlimitState = digitalRead(downlimitPin);
// check if the limit is active. If it is, the limitState is HIGH:
if (uplimitState == HIGH) {
shadePosition = 2;
Serial.println(F("The shade is up"));
stopShade();
}else if (downlimitState == HIGH) {
shadePosition = 1;
Serial.println(F("The shade is down"));
stopShade();
if (togglebuttonState == HIGH) {
if( shadePosition == 1 ){
shadeUp();
delay(100);
shadePosition = 2;
delay(100);
}else if (shadePosition == 2 ) {
delay(100);
shadeDown();
delay(100);
shadePosition = 1;
arduino-uno
The shadeUp and shadeDown functions only do a single step at a time. The code in loop changes direction after each of those functions have been called (doing a single step).
Hi @balthozar .
see if this sketch meets your need.
RV mineirin
boolean flagUp = false;
boolean flagDn = false;
void shadeDown() {
void shadeUp() {
void stopShade() {
flagUp = false;
flagDn = false;
if (digitalRead(togglebuttonPin) == HIGH)
flagUp = true;
flagDn = true;
if (digitalRead(uplimitPin) == HIGH)
shadePosition = 2;
else if (digitalRead(downlimitPin) == HIGH)
shadePosition = 1;
if ( flagUp == true && shadePosition == 1 ) // Is down
flagDn = false;
shadeUp();
Serial.println(F("The shade up"));
if (flagDn == true && shadePosition == 2 ) // Is Up
flagUp = false;
shadeDown();
Serial.println(F("The shade down"));
Thank you!
This makes the buttons work as intended, and I think I understand what is going on in the code with the flags. But now my problem is that I can't change the speed at which the stepper turns, I tried adjusting the delays but it still spins at about 18RPM. I tried diving into the stepper and AccelStepper libraries to no avail, somehow ended up making it spin at one step per second. I think this is way out of my league for a first project...
Hi @balthozar .
The motor speed is controlled by the "delayMicroseconds(1000);"
within the functions shadeDown() and shadeUp().
The largest value that can be used in delayMicroseconds() is 16383.
If you need the motor to be slower than 16383 useg, switch to using delay(), but the values must be written 1000 times smaller, as delay(1) equals delayMicroseconds(1000).
The larger the delay value, the slower the motors speed.
But each engine has its maximum speed limit.
When it reaches this speed it does not turn more and is emitting an audible medium
or high frequency noise.
I have tried to adjust the delays, that is how I adjusted the speeds in the simple stepper control tutorial, however that is not working here, no matter what value I change "delayMicroseconds(1000); to, the speed of the motor while running stays the same.
I left them unconnected for full stepping. I'm probably wrong, but the only difference I can see between the Arduino example code on steppers (where I am able to adjust speed) and the code above(where I can't get the speed to change) is that the example code writes the dirPin outside of the step loop. The code above is writing dirPin inside of the shadeDown() and shadeUp() functions.
Hi .
NEMA17 is a specification of engine mechanics.
I have a 17hs4401 model here.
Could you tell the model of yours, or the current it drains and the torque?
The following code works for being able to adjust the speed by adjusting the delayMicroseconds
This was the code I used to make sure I had the stepper and driver hooked up correctly before I tried to use the code with the limit switches.
// Define pin connections & motor's steps per revolution
const int stepsPerRevolution = 200;
// Declare pins as Outputs
// Set motor direction clockwise
// Spin motor slowly
for(int x = 0; x < stepsPerRevolution; x++)
delayMicroseconds(2000);
delay(1000); // Wait a second
// Set motor direction counterclockwise
// Spin motor quickly
Hi .
I found the problem.
Printouts are affecting motor step time.
Test this new sketch without any messages printed.
Increase the speed by changing the value of variable myTime at the start.
I left it initially with 500 mSec, because with 400 my motor
it vibrated but did not rotate.
If necessary increase this value.
RV mineirin
unsigned long myTime = 500;
void shadeDown() {
delayMicroseconds(myTime);
void shadeUp() {
void stopShade() {
flagUp = false;
flagDn = false;
flagUp = true;
flagDn = true;
shadePosition = 2;
//Serial.println(F("The shade is up"));
shadePosition = 1;
//Serial.println(F("The shade is down"));
flagDn = false;
shadeUp();
//Serial.println(F("The shade up"));
flagUp = false;
shadeDown();
//Serial.println(F("The shade down"));
Hi .
The arduino takes about 14 to 16 milliseconds to print this line "Serial.println(F("The shade up"));".
And at each step of the motor it printed a line of this one.
Note that the time for each step is around 500 to 1000 microseconds, which equates to 0.5 to 1 milliseconds.
So these 14 milliseconds made the motor very slow, as this time had to pass between each step.
I don't know if I was clear in my explanation.
RV mineirin
