Hi, I am doing my project but im having slight difficulties. When I put the code in Arduino the value becomes zero.
Im using a pH sesnor from Inesa Scientific Instrument (E-201-C) and a peristaltic pump from DFRobot. The board that im using is Arduino UNO.
This is the code that i use that was giving me zero as the pH value
#include <Servo.h>
Servo acid_solution;
Servo alkaline_solution;
#define acid_pump 9
#define alkaline_pump 10
float calibration_value = 10.97;
int phval = 0;
unsigned long int avgval;
int buffer_arr[10], temp;
float value1,
value2,
value3,
value4,
value5,
main_value;
float ph_value;
pinMode(A0, INPUT);
acid_solution.attach(acid_pump);
alkaline_solution.attach(alkaline_pump);
Serial.println(ph_value);
getting_value();
value1 = ph_value;
delay(300);
getting_value();
value2 = ph_value;
delay(300);
getting_value();
value3 = ph_value;
delay(300);
getting_value();
value4 = ph_value;
delay(300);
getting_value();
value5 = ph_value;
main_value = (value1 + value2 + value3 + value4 + value5) / 5;
if (main_value > 6.5)
acid_solution.write(0); //Clockwise maximum speed rotation
acid_solution.write(90);
if (main_value < 5.5)
alkaline_solution.write(0);
alkaline_solution.write(90);
void getting_value()
for (int i = 0; i < 10; i++)
buffer_arr[i] = analogRead(A0);
delay(30);
for (int i = 0; i < 9; i++)
for (int j = i + 1; j < 10; j++)
if (buffer_arr[i] > buffer_arr[j])
temp = buffer_arr[i];
buffer_arr[i] = buffer_arr[j];
buffer_arr[j] = temp;
avgval = 0;
for (int i = 2; i < 8; i++)
avgval += buffer_arr[i];
float volt = (float)avgval * 5.0 / 1024 / 6;
float ph_value = -5.70 * volt + calibration_value;
please help me in this. Thank you
