I don't use any charger cable , I have a blue USB B to USB A cable which I bought with the Arduino . I don't think that it is the problem .
I'm going to ask you to post the full verbose output from an upload attempt.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open. - Uncheck the box next to Show verbose output during:
βcompilation in the "Preferences" dialog. - Check the box next to Show verbose output during: β upload.
- Click the "OK" button.
- Attempt an upload, as you did before.
- Wait for the upload to fail.
- You will see a "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
- Open a forum reply here by clicking the "Reply" button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press Ctrl+V (Command+V for macOS users).
This will paste the error output from the upload into the code block. - Move the cursor outside of the code tags before you add any additional text to your reply.
- Click the "Reply" button to post the output.
@paulpaulson note that @infinvo is using an Arduino Uno derivative board, not a Due:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
Sketch uses 2986 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 200 bytes (9%) of dynamic memory, leaving 1848 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\arduino_build_192218/sketch_nov24a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x77
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x77
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
option enabled in File -> Preferences.
Also the RX and TX leds doesn't blink while uploading the code......
There is a program named a "bootloader" that is stored in a special area of the memory in the primary microcontroller of your Arduino board. This program receives the data sent by the computer when you upload a sketch to the board. If the bootloader program is not working correctly, it can cause this "not in sync" error message during uploading.
The LED blinking after you reset the board indicates that the bootloader is present and running so I don't have any strong reason to suspect a problem with the bootloader. However, we have already eliminated any of the other easily resolvable causes of this upload failure, so the only thing left is the faint possibility that the bootloader was somehow corrupted in a way that allows it to still run well enough to blink the LED, but not well enough to perform an upload.
If so, the board might be recoverable by performing a "Burn Bootloader" operation. I have to warn you that the chances of this restoring the board to functionality are low. But I will provide instructions in case you want to give it a try.
You will need an "ISP programmer" in order to perform a "Burn Bootloader" operation. An ISP programmer is a piece of hardware that allows your computer to write directly to the flash memory of the primary microcontroller on the Arduino board.
If you don't have an ISP programmer, you can use a spare Arduino board as a DIY programmer (known as an "Arduino as ISP"). I'll provide instructions you can follow to do that:
Burning Bootloader with "Arduino as ISP" Programmer
A. Prepare "Arduino as ISP" programmer
Although the "Arduino as ISP" only works for programming targets of the AVR architecture, you can use some boards of other architectures (e.g., "AVR", "SAMD", "megaAVR") as an "Arduino as ISP" programmer.
I will refer to the board which will used as an "Arduino as ISP" as the "programmer board" from here on. The board you are burning the bootloader to will be referred to as the "target board".
- Disconnect the USB cable of the Arduino boards from your computer.
- Make the following connections between the pins on the "programmer board" and the "target board".
Programmer Target CIPO (AKA "MISO") CIPO VCC 5V (VCC on 3.3 V boards) SCK SCK COPI (AKA "MOSI") COPI 10 RESET GND GND β The documentation for the boards you are using will identify the location of these pins. If you are using an official Arduino board, check the pinout diagram on the documentation page for the board. - Connect the "programmer board" to your computer with a USB cable.
- Select File > Examples > 11.ArduinoISP > Arduino ISP from the Arduino IDE menus.
- Select your "programmer board" from Arduino IDE's Tools > Board menu.
- Select the port of your "programmer board" from Arduino IDE's Tools > Port menu.
- Select Sketch > Upload from the Arduino IDE menus.
- Wait for the upload to finish.
You are now ready to burn the bootloader using your "Arduino as ISP" programmer.
B. Burn Bootloader
Instructions for burning the bootloader:
β It is not possible to do this via "Arduino Web Editor". You will need to use Arduino IDE or Arduino CLI.
- Select the "target board" from the Tools > Board menu, and any other custom Tools menus (e.g., Tools > Processor).
- Select the appropriate programmer from the Tools > Programmer menu in Arduino IDE.
This is dependent on which board you are using as the "programmer board": - Select Tools > Burn Bootloader from the Arduino IDE menus.
- Wait for the process to finish successfully.
- Disconnect the USB cable of the "programmer board" from your computer.
- Disconnect the "programmer board" from the "target board".
Conclusion
Now connect the "target board" to your computer with a USB cable and try uploading again. Does the upload succeed now?
i don't have any ISP programmer or any other working arduino.So where can i get one ?
India
This clone you got, have you ever been able to use it?
I'm thinking that this can be at play in your case. The thread also describes the solution (to downgrade the driver for the CH340), see if this solve your issue (hope it does).
Nope ,never able to use that clone...
i think the driver downgrade didn't solve that issue
That's sad to hear. Hope you can get hold of another Arduino or a real programmer and get it sorted out. Good luck!
UPDATE : I got an fully functional ESP8266. Can I repair my arduino with that ?
