I have doubts about which "programmer" I should choose for the generic Arduino
this is the error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x64
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x64
Failed uploading: uploading error: exit status 1
Welcome to the forum
Which Arduino board are you using ?
Is is a classic Nano by any chance ?
Is there a BOOT button, did you try it several times, is it a clone (Old Bootloader)
I don't know what the board is but its driver is ch341ser.if
and when i press the " board information" it says "unknown board" or similar thing
As mentioned above, try "old bootloader"
dosen't work...
Take a picture and show it here and someone will figure it out
A picture of the board so we can read the writing
Need to see the board to determine if it's a clone or not.
Ok, that is a modern UNO. In that case, make sure no other copy of the IDE is open. Stop the IDE and restart. Check the serial connection by clicking the bottom of the Board and Port selector (pics attached).
UNO's rarely fail but if it does reset the IDE, unplug the board and try again.
Screenshot 2024-08-19 at 09.42.08
It's a clone - but, anyway.
... and it needs "old bootloader" and when you flash the new one you'll curse yourself for doing so :slight_smile:
ok, but dosen't work too
same thing, dosen't work
i can't find the programer for my arduino
  • defect cable
  • decect usb port on pc
  • defect usb port on arduino
  • defect ch34x
... when you search the forum you'.. find lots of simillar threads of peaople not using the search engine ... well, not, 'cause you don't search ...
it is new...
