avrdude device signature = 0xffffff
I was developing a firmware for a device, constantly recording and verifying the results and correcting the errors, until a certain moment appeared the error message when trying to record: "avrdude device signature = 0xffffff avrdude yikes invalid device signature", no longer performing recordings. I do not think the problem is the Arduino, because I was able to record in another microcontroller.
The microcontroller I use is an ATMEGA328P-AU and to record I use Arduino Duemilanove by ISP.
Could someone help me?
Thanks!
Leandro
Can you upload the basic BLINK program to the Arduino that gave rise to the error?
If not, post the exact error message that you get when you tried.
Nick Gammon's diagnostic program may help
...R
Sounds to me like one of your ISP wires has come loose.
johnwasser:
I tested the cable, wire by wire, and the tracks responsible for power and programming. It's all OK.
Robin2:
...R
Follow the message:
avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/rodrigo/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
User configuration file is "/home/rodrigo/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0xffffff (probably .reduced_core_tiny) (retrying)
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
Ocorreu um erro enquanto o sketch era carregado
0xFFFFFF sig indicates a wiring problem, usually MISO shorted to Vcc.
leandrolk:
In that case I suspect that something has gone wrong with the system clock on the target processor. You can't do serial programming unless the processor's system clock is running.
The ATMEGA328P-AU really burned. I traded for a new one and it all worked out perfectly.
The error occurred again. I do not know what to do.
Well, I using a 16Mhz crystal oscillator. I removed it from the circuit and made the programming changes to use the ATMEGA internal oscillator (8MHZ), but the write error continues.
leandrolk:
You have to keep the crystal attached until AFTER you set the fuses to use the internal oscillator. If it is set for a crystal and the crystal is not installed... No Clock. Therefore, no serial programming.
