I was using Arduino Create over the weekend and writing sketches to my Arduino Uno with no issues. I didn't even unplug it. Now I'm getting this error with every sketch I try to upload.
avrdude: no programmer has been specified on the command line or the config file
Specify a programmer using the -c option and try again
You may want to try clearing your browser cache etc as a first step.
Failing that please supply more information as per the post at the top of the forum "How to use this section of the forum"
I believe it's where I'm supposed to be, as it is the Create Online Editor with which I'm having trouble, but I'll happily post elsewhere if need be. It's not my intention to hijack a thread or post in the wrong forum.
The downloaded IDE is not being problematic. I've taken sketches which run on it and imported them to the online editor with no changes to the code and verified them (no problems), but they won't upload. I get the "Executing command: exit status 1" message with the aforementioned error in the output panel.
Not sure if this helps or not, but I had the same issue using the Arduino Editor Online to try and load sketches onto my boards today. It had worked fine a few weeks ago when I first tested it. Went to edit the sketch and re-upload today and no go from my Mac. I cleared the browser cache, uninstalled and reinstalled the Arduino Create Plugin, with no luck. I then installed the Arduino Create for Chrome OS on a chromebox I had available, and it worked fine there! I then tried to do it from a Windows Laptop I have and that ran into a totally different error of "an existing connection was forcibly closed by the remote host". Its a test laptop that I had laying around so I'm not too concerned with that error. Hope this helps someone sort out what's going on.
So if the problem is caused by {upload.verify}, how do I correct this - sorry if this is a dull stupid question but I am not at all sure how to solve this.
I don't think there's anything we can do to fix it. This is one of the problems with cloud-based tools. You have no control over them. You just need to wait and hope the Arduino team will fix the bug soon. In the meantime you can use the standard Arduino IDE, which can be downloaded here:
Many thanks for confirming my suspicion, I'll have to wait for the fix because I am unable to download the desktop version for some reason. Hopefully it will not take too long.
The strange thing is that I added a default definition of {upload.verify} two years ago:
which should ensure we never see {upload.verify} in an avrdude command.
So either Arduino Web Editor is using a super outdated version of Arduino AVR Boards (which it might be since it's using a version of avrdude from over two years ago), or else it's not using platform.txt at all (which would be insane).
Just to say I am having similar problems with a sketch that compiles and uploads to a Nano on the offline IDE on OSX, but although it compiles (Verifies) on the Safari Web Editir, it will not upload.
I thought at first the lack of an option for Nano old boot loader was the reason for this, as I have to use that option on the offline IDE to upload to my Nano.
I am not certain, but I did think an earlier version of my sketch did upload from the Web Editor a few weeks ago.
Hope that we can get some traction on this, as it is must be affecting quite a few Macintosh users of the Web Editor.
Thanks for that, it now works here, I am able to select the "old bootloader" option for my nano within the Safari Web Editor and upload my sketch without error.
