avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
What should I do to address the problem? It's a NANO EVERY.
F
F
Please do this:
If the text exceeds the forum's 9000 character limit, save it to a .txt file and post it as an attachment. If you click the "Reply" button here, you will see an "Attachments and other settings" link.
Arduino:1.8.12 (Windows Store 1.8.33.0) (Windows 10), Scheda:"Arduino Nano, ATmega328P"
Lo sketch usa 22302 byte (72%) dello spazio disponibile per i programmi. Il massimo è 30720 byte.
Done. Should I change the setup to have a verbose message?
Le variabili globali usano 631 byte (30%) di memoria dinamica, lasciando altri 1417 byte liberi per le variabili locali. Il massimo è 2048 byte.
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Errore durante il caricamento dello sketch
Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
"Mostra un output dettagliato durante la compilazione"
in "File -> Impostazioni"
Select Tools > Processor > ATmega328P (Old Bootloader) and then try uploading again.
Some resp field change but the error stays..
Arduino:1.8.12 (Windows Store 1.8.33.0) (Windows 10), Scheda:"Arduino Nano, ATmega328P (Old Bootloader)"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
It works now. I checked the board -following yr checklist - and it was not the Nano Every but just Nano. Checked the port and it was correct.
But it gives another message. Probably a warning and not a show stopper.
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
Thks
F
