Avrdude: ser_open(): can't open device
Hi
I know there are hundreds of post concerning this error message, and I have tried several solutions without any luck (including changing COM port number, switching ATmega328P processer between new and old). Hope some one can help.
I'm using a Nano, IDE 2.3.2, and Windows 11. No other applications are running, and IDE is only running one sketch at a time. No other USB devices are connected to the computer. Have tried several sketches that all compile successfully.
When I start IDE, I can upload a sketch one time (and the sketch works). When I try to upload a second time, I get the following error message (verbose output):
Sketch uses 2302 bytes (7%) of program storage space. Maximum is 30720 bytes.
Global variables use 190 bytes (9%) of dynamic memory, leaving 1858 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\klsnl\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\klsnl\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM5" -b115200 -D "-Uflash:w:C:\Users\klsnl\AppData\Local\Temp\arduino\sketches\8D15E155C2ADB03E350E1EAE10559B3E/LED_metronom.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\klsnl\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM5": Access is denied.
avrdude done.  Thank you.
Failed uploading: uploading error: exit status 1
Sometimes I can unplug the Nano, reconnect, and make again one upload. Uploading after this, gives the above error message. Sometimes I have to restart IDE. Other times waiting 10 minutes has the same effect. Either way I can only upload once, which makes experimenting with the Nano virtually impossible.
When the upload works the verbose output message is:
         Using Port                    : COM5
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\klsnl\AppData\Local\Temp\arduino\sketches\8D15E155C2ADB03E350E1EAE10559B3E/LED_metronom.ino.hex"
avrdude: writing flash (2302 bytes):
Writing | ################################################## | 100% 0.86s
avrdude: 2302 bytes of flash written
Hi @klausn. There is a known bug in Arduino IDE 2.x that can cause uploads to fail with this "Access is denied" error if you try uploading to a board using an FTDI FT232R USB chip (as is present on the official classic Nano and its faithful clones) while the Arduino IDE Serial Monitor or Serial Plotter is open.
A port can only be used by one process at a time, so Arduino IDE must automatically close the port in Serial Monitor and Serial Plotter during an upload, automatically opening it again after. For some reason, that juggling of the port control is not working with boards that have the FTDI USB chip.
If that bug is the cause of the problem you are having, the workaround will be to manually close the port in Serial Monitor/Serial Plotter before doing an upload. Please give that a try and then let me know if you still have the error while uploading:
Serial Monitor
  1. Click the X icon on the "Serial Monitor" tab in the bottom panel of the Arduino IDE window to close the tab:
  2. Upload the sketch.
  3. Open Serial Monitor again if needed (by clicking the icon on the IDE toolbar or the Tools > Serial Monitor menu item) after the upload is finished.
Serial Plotter
If you have the "Serial Plotter" window open, the procedure is a bit different from closing the Serial Monitor connection:
  1. Close the "Serial Plotter" window.
  2. If the "Serial Monitor" view is not already open, select Tools > Serial Monitor from the Arduino IDE menus to open it.
    ⓘ We must do an open/close cycle on Serial Monitor as a workaround for a bug in Serial Plotter
  3. Click the X icon on the "Serial Monitor" tab in the bottom panel of the Arduino IDE window to close the tab:
  4. Upload the sketch.
  5. Open Serial Monitor and/or Serial Plotter again if needed after the upload is finished.
Please let me know if you have any questions or problems while following those instructions.
That is uncanny - what a simple fix. It appears to be working now flawlessly!
Thanks @ptillisch for the quick response. Indeed closing the serial monitor was all I needed.
I have read through quite a number of post regarding the 'access denied' error, and never seen this fix before. Maybe it should be added to the FAQs or something. I think it could help a lot of Arduino users.
For now I'm back experimenting - thanks for the help!
You are welcome. I'm glad you are now able to upload.
Regards,
Per
