avrdude: stk500_disable(): protocol error
I am receiving this error
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x0a
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x69
when uploading to a dfRobot Romeo board (it is similar to a Arduino Uno).
I am uploading a NewPing Library Example Program
// Example NewPing library sketch that does a ping about 20 times per second.
#include <NewPing.h>
#define TRIGGER_PIN  10  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     8  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
  delay(50);                     // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
  Serial.print("Ping: ");
  Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
  Serial.println("cm");
The program compiles but does not upload successfully.
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here using code tags.
Arduino: 1.8.7 (Windows Store 1.8.15.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 2472 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 220 bytes (10%) of dynamic memory, leaving 1828 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM16 -b115200 -D -Uflash:w:C:\Users\scott\AppData\Local\Temp\arduino_build_127293/NewPingExample.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM16
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 3.3
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\scott\AppData\Local\Temp\arduino_build_127293/NewPingExample.ino.hex"
avrdude: writing flash (2472 bytes):
Writing | ########################################
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0xcc
##avrdude: stk500_cmd(): programmer is out of sync
######the selected serial port ### does not exist or your board is not connected
# | 100% 2.95s
avrdude: 2472 bytes of flash written
avrdude: verifying flash memory against C:\Users\scott\AppData\Local\Temp\arduino_build_127293/NewPingExample.ino.hex:
avrdude: load data flash data from input file C:\Users\scott\AppData\Local\Temp\arduino_build_127293/NewPingExample.ino.hex:
avrdude: input file C:\Users\scott\AppData\Local\Temp\arduino_build_127293/NewPingExample.ino.hex contains 2472 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: loadaddr(): (b) protocol error, expect=0x14, resp=0x00
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x10
##avrdude: stk500_cmd(): protocol error
avr_read(): error reading address 0x0006
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x0c
avrdude done.  Thank you.
option enabled in File -> Preferences.
It's an old post but just in case this helps somebody:
the failure reason in my case was a incorrect ground connection in the circuit.
After connecting all ground pins correctly the error disappeared.
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\GRATIANO\AppData\Local\Temp\arduino_build_62951/sketch_jul06a.ino.hex:i
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfa
gdeidda:
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
