Hello,
I am a noob (even with forums).
I am unable to upload to the board, error listed below. I have also never been able to upload to the board, I received it yesterday. Here is an overview of what I have done and what occurs. Thanks for taking a look.
My Set up:
- Arduino nano (brand new from digikey)
- Arduino IDE installed
- Arduino sits on a breadboard with nothing plugged into it
- Running Windows 10 on a laptop
When I plug the Arduino into my laptop via USB, the following happens:
- USB Serial Port (COM 6) appears in Device Manager
- TX and RX LEDs blink extremely fast for a small portion of a second then turn off
- ON, Green LED lights up continuous
- L LED blinks relatively fast for roughly 4 to 5 seconds then slows to 1 second ON and 1 second off, repeating
In the IDE Tools I have the following settings:
- Board: Arduino Nano
- Processor: ATmega328P
- Port: Com6
- Programmer: Arduino as ISP
When I click "Get Board Info" in tools I get the following response:
- BN: Unknown Board
- VID: 0403
- PID: 6001
- SN: Upload any sketch to obtain it
Under Devices and Printers(via Control Panel), the Arduino appears as:
- FT232R USB UART
- Manufacturer: Unavailable
- Model number: Unavailable
- Categories: Unknown
- Description: Unknown
and under "Hardware" in properties it lists:
- USB Serial Converter
- USB Serial Port (COM6)
I have the example "Blink.ino" loaded from the examples.
When I try to upload it, everything seems fine at first and then the following error code is given ( from copy error messages with some of the early code removed such to limit the character length of this post):
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\bakke\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\bakke\AppData\Local\Temp\arduino_build_343601 -warnings=none -build-cache C:\Users\bakke\AppData\Local\Temp\arduino_cache_924347 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\bakke\Desktop\arduino-1.8.5-windows\arduino-1.8.5\examples\01.Basics\Blink\Blink.ino
BREAK
"C:\Users\bakke\AppData\Local\Temp\arduino_build_343601\sketch\Blink.ino.cpp" -o "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601\sketch\Blink.ino.cpp" -o "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601/Blink.ino.elf" "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601\sketch\Blink.ino.cpp.o" "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601/..\arduino_cache_924347\core\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\bakke\AppData\Local\Temp\arduino_build_343601" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601/Blink.ino.elf" "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601/Blink.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601/Blink.ino.elf" "C:\Users\bakke\AppData\Local\Temp\arduino_build_343601/Blink.ino.hex"
Sketch uses 928 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Users\bakke\AppData\Local\Temp\arduino_build_343601/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xdb
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
What I have done so far:
Tried to replace the Driver withno success as the windows indicates it has the best driver installed for COM6.
Performed Loop test successfully
Tried 3 different USB cables on 3 different USB ports
Tried different Programmers: I have no idea which one to use, however the results are not impacted based on changing the selection.
Tried The Online IDE in hopes of it recognizing the problem
Tried pushing the Reset button at random times before and during upload
Tried reinstalling IDE
Tried forcing the Driver update via "Have disk" which was possibly very stupid of me as I had to restart my very upset computer
Thank you for your help if you are able to help,
Eric
