This has got me puzzled.
I have been using a FTDI ch430G usb programmer on my many Pro-Mini's for a long time without issue.
For the past 48hrs I have not been able to upload any code to them BUT I have a couple of UnoR3's with the same chipset which still work fine !!!
I have been using IDE1.8.19 on Windows 11 Pro
What I have tried so far...
3 different usb based FTDI CH430G programmers - no difference
Changed connecting cables FTDI to Pro-Mini - no difference
Uninstalled drivers for CH430 - rebooted and re-installed - no difference
Installed IDE2.2.1 - no difference
The ports are identified correctly
UPDATE - just used Clone UNO R3 as programmer - worked fine - baffled !
I include the upload data from the unsuccesful Pro-Mini an the sucessful UNOR3 clone
Arduino: 1.8.19 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\crust\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\crust\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries E:\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\crust\AppData\Local\Temp\arduino_build_764763 -warnings=none -build-cache C:\Users\crust\AppData\Local\Temp\arduino_cache_803658 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose E:\Documents\Arduino\Blink_4\Blink_4.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\crust\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\crust\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries E:\Documents\Arduino\libraries -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\crust\AppData\Local\Temp\arduino_build_764763 -warnings=none -build-cache C:\Users\crust\AppData\Local\Temp\arduino_cache_803658 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose E:\Documents\Arduino\Blink_4\Blink_4.ino
Using board 'pro' from platform in folder: C:\Users\crust\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\crust\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp" -o "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp" -o "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\crust\AppData\Local\Temp\arduino_cache_803658\core\core_arduino_avr_pro_cpu_16MHzatmega328_c31bc606cd2ce91b0fd4ab3a9def6f14.a
Linking everything together...
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763/Blink_4.ino.elf" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp.o" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763/..\\arduino_cache_803658\\core\\core_arduino_avr_pro_cpu_16MHzatmega328_c31bc606cd2ce91b0fd4ab3a9def6f14.a" "-LC:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763" -lm
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763/Blink_4.ino.elf" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763/Blink_4.ino.eep"
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763/Blink_4.ino.elf" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763/Blink_4.ino.hex"
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763/Blink_4.ino.elf"
Sketch uses 1042 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\crust\AppData\Local\Temp\arduino_build_764763/Blink_4.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x51
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\crust\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\crust\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries E:\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\crust\AppData\Local\Temp\arduino_build_764763 -warnings=none -build-cache C:\Users\crust\AppData\Local\Temp\arduino_cache_803658 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose E:\Documents\Arduino\Blink_4\Blink_4.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\crust\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\crust\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries E:\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\crust\AppData\Local\Temp\arduino_build_764763 -warnings=none -build-cache C:\Users\crust\AppData\Local\Temp\arduino_cache_803658 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose E:\Documents\Arduino\Blink_4\Blink_4.ino
Using board 'uno' from platform in folder: C:\Users\crust\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp" -o nul
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp" -o "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\standard" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp" -o "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp.o"
Compiling core...
Using precompiled core: C:\Users\crust\AppData\Local\Temp\arduino_cache_803658\core\core_arduino_avr_uno_c31bc606cd2ce91b0fd4ab3a9def6f14.a
"C:\\Users\\crust\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763/Blink_4.ino.elf" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763\\sketch\\Blink_4.ino.cpp.o" "C:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763/..\\arduino_cache_803658\\core\\core_arduino_avr_uno_c31bc606cd2ce91b0fd4ab3a9def6f14.a" "-LC:\\Users\\crust\\AppData\\Local\\Temp\\arduino_build_764763" -lm
Sketch uses 1042 bytes (3%) of program storage space. Maximum is 32256 bytes.
C:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\crust\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\crust\AppData\Local\Temp\arduino_build_764763/Blink_4.ino.hex:i
Using Port : COM5
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\crust\AppData\Local\Temp\arduino_build_764763/Blink_4.ino.hex"
avrdude: writing flash (1042 bytes):
Writing | ################################################## | 100% 0.16s
avrdude: 1042 bytes of flash written
avrdude: verifying flash memory against C:\Users\crust\AppData\Local\Temp\arduino_build_764763/Blink_4.ino.hex:
avrdude: load data flash data from input file C:\Users\crust\AppData\Local\Temp\arduino_build_764763/Blink_4.ino.hex:
avrdude: input file C:\Users\crust\AppData\Local\Temp\arduino_build_764763/Blink_4.ino.hex contains 1042 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.14s
avrdude: verifying ...
avrdude: 1042 bytes of flash verified
