Hi!
I've got a project I am working on which I could do with a little help and support on if anyone can help?
First of all, I will say have some electronics and programming knowledge and some formal training in both but most of it was a few years ago and I never got the opportunity to complete the course so I'm really sketchy at some things. Some things I get and understand really well, some things I'm just like.. ERM, WHAT? So please bare with me!
I've made a start on my project and have a few designs for what I want to do which is, in a nutshell, this...
I am a Radio Ham and I'm wanting to build my own Azimuth and Elevation system for steering a bunch of Yagi type antennas into space to receive satellite signals of various kinds on various frequencies and bands.
What I want to do is this: I want to use Orbitron, a sat tracking program which should output the AZ/EL data via Serial to my arduino. The arduino in turn takes the position data and translates that into movements to my motors.
I am a bit of an eccentric worker which doesn't help so I tend to pick away at the things that need doing in the order I feel capable of doing them so my work is a bit all over the place but I've made a start designing one side of the control circuits but I'd like someone just to take a look at what I've got this far just to see if everything looks okay. I'm not an electronics engineer, I've just been piecing together parts of common circuit layouts to make what I want so it's probably a very noobish circuit. I'm also not familiar with any circtuit deisgn software yet so I pretty much drew my circuits in a simple way that I could follow using VISIO LOL so some of the symbols may not be entirely accurate so I used ones close to what I need just to emphasize what the parts were.
It took me 18 hours straight at the computer to get this far LOL
E2A: Okay, so I thought the image wasn't showing - it's just slow to load....
This side of the circuit is purely for the elevation motor which is a 36V DC Horizon to Horizon dish motor which will be mounted on it's side and on top of a regular antenna rotator to provide elevation to the system.
The rotator or azimuth motor is going to be pretty much the same design except IT runs at 24VDC and not 36VDC so I'll replace them for 24VDC relays there.
As far as I can tell, that circuit looks done and ready but I'm no expert so could do with someone a bit more knowledgeable just to check it for me if they wouldn't mind please to see if they can see any obvious mistakes?
A friend of mine (who isn't always available to assist me) tells me there are better general purpose transistors out there than the TIP 120 for this application but failed to disclose any particular one so the TIP 120 may get swapped out when and if I find suitable replacement. Trying to get my head around the facts and figures for transistors has been a job in itself LMFAO.
I know I could probably go out and buy a shield or three to do half of the stuff I am wanting but I get no pleasure from assembling kits when I want to learn and for me, I get great satisfaction when I've done most of the work and built something from the ground up.
Any help, advice, support with my current design would be appreciated!
E2A: Just wanted to point out, in case it wasn't clear, the motor or elevator unit depicted in my circuit diagram is a phased motor. One common 0V with two +VCC cables; one to drive the motor forwards, one to reverse it and there are also 3 more wires which go to a 500 Ohm position keeper POT. I have not included the line of communication back from the POT to the arduino in this diagram but thought I should point out it does exist.
Thank you kindly!
Mike.
