Balance bot improvement suggestions
Hello all, so i am looking to improve my balancing bot. The improvements i would like to make are in the design of the bot and the code for the bot ... my bot is rather simple at the moment and it is my intent to keep it simple, plus i have a limited parts supply to work with so i would like to avoid adding more components ( other than for adding some kind of user remote control, i am trying to just use what i have already) but understand if it is necessary.
parts list : 2 x Geared motors ( salvaged from a sumovore sumo bot )
1 x Arduino Nano
1 x MPU6050
1 x L293D
1 x 6.4V 500mAh Lithium Ion battery W/battery holder and on/off switch
( salvaged from a New Bright R/C truck ) CIRCUIT POWER SUPPLY
16 x AA Batteries ( 2 x 8-AA battery packs for 12V ) MOTOR POWER SUPPLY
2 x on/off switches ( one for L293D and the other for motor supply )
random parts used for the chassis
The code i used was found online. only made a small change. all the credit for the code is still in the code text.
/*Arduino Self Balancing Robot
 * Code by: B.Aswinth Raj
 * Build on top of Lib: https://github.com/jrowberg/i2cdevlib/tree/master/Arduino/MPU6050
 * Website: circuitdigest.com
#include "I2Cdev.h"
#include <PID_v1.h> //From https://github.com/br3ttb/Arduino-PID-Library/blob/master/PID_v1.h
#include "MPU6050_6Axis_MotionApps20.h" //https://github.com/jrowberg/i2cdevlib/tree/master/Arduino/MPU6050
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
/*********Tune these 4 values for your BOT*********/
double setpoint= 183.14; //set the value when the bot is perpendicular to ground using serial monitor.
//Read the project documentation on circuitdigest.com to learn how to set these values
double Kp = 17; //Set this first
double Kd = 0.5; //Set this second
double Ki = 25; //Finally set this
/******End of values setting*********/
double input, output;
PID pid(&input, &output, &setpoint, Kp, Ki, Kd, DIRECT);
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady()
    mpuInterrupt = true;
  Wire.begin();
  TCCR1B = TCCR1B & B11111000 | B00000001;    // set timer 1 divisor to     1 for PWM frequency of 31372.55 Hz
  TCCR2B = TCCR2B & B11111000 | B00000001;    // set timer 2 divisor to     1 for PWM frequency of 31372.55 Hz
  // initialize device
    Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
     // verify connection
    Serial.println(F("Testing device connections..."));
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    // load and configure the DMP
    devStatus = mpu.dmpInitialize();
    // supply your own gyro offsets here, scaled for min sensitivity
    mpu.setXGyroOffset(-261);
    mpu.setYGyroOffset(37);
    mpu.setZGyroOffset(8);
    mpu.setZAccelOffset(562);
      // make sure it worked (returns 0 if so)
    if (devStatus == 0)
        // turn on the DMP, now that it's ready
        Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        // enable Arduino interrupt detection
        Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
        attachInterrupt(0, dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        // get expected DMP packet size for later comparison
        packetSize = mpu.dmpGetFIFOPacketSize();
        //setup PID
        pid.SetMode(AUTOMATIC);
        pid.SetSampleTime(10);
        pid.SetOutputLimits(-255, 255);
        // ERROR!
        // 1 = initial memory load failed
        // 2 = DMP configuration updates failed
        // (if it's going to break, usually the code will be 1)
        Serial.print(F("DMP Initialization failed (code "));
        Serial.print(devStatus);
        Serial.println(F(")"));
//Initialise the Motor outpu pins
    pinMode (3, OUTPUT);
    pinMode (9, OUTPUT);
    pinMode (10, OUTPUT);
    pinMode (11, OUTPUT);
//By default turn off both the motors
    analogWrite(3,LOW);
    analogWrite(9,LOW);
    analogWrite(10,LOW);
    analogWrite(11,LOW);
    // if programming failed, don't try to do anything
    if (!dmpReady) return;
    // wait for MPU interrupt or extra packet(s) available
    while (!mpuInterrupt && fifoCount < packetSize)
        //no mpu data - performing PID calculations and output to motors
        pid.Compute();
        //Print the value of Input and Output on serial monitor to check how it is working.
        Serial.print(input); Serial.print(" =>"); Serial.println(output);
        if (input>150 && input<200){//If the Bot is falling
        if (output>0) //Falling towards front
        Forward(); //Rotate the wheels forward
        else if (output<0) //Falling towards back
        Reverse(); //Rotate the wheels backward
        else //If Bot not falling
        Stop(); //Hold the wheels still
    // reset interrupt flag and get INT_STATUS byte
    // get current FIFO count
    fifoCount = mpu.getFIFOCount();
    // check for overflow (this should never happen unless our code is too inefficient)
    if ((mpuIntStatus & 0x10) || fifoCount == 1024)
        // reset so we can continue cleanly
        mpu.resetFIFO();
        Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
    else if (mpuIntStatus & 0x02)
        // wait for correct available data length, should be a VERY short wait
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
        mpu.dmpGetQuaternion(&q, fifoBuffer); //get value for q
        mpu.dmpGetGravity(&gravity, &q); //get value for gravity
        mpu.dmpGetYawPitchRoll(ypr, &q, &gravity); //get value for ypr
        input = ypr[1] * 180/M_PI + 180;
void Forward() //Code to rotate the wheel forward
    analogWrite(3,output);
    analogWrite(9,0);
    analogWrite(10,output);
    analogWrite(11,0);
    Serial.print("F"); //Debugging information
void Reverse() //Code to rotate the wheel Backward
    analogWrite(3,0);
    analogWrite(9,output*-1);
    analogWrite(10,0);
    analogWrite(11,output*-1);
    Serial.print("R");
void Stop() //Code to stop both the wheels
    analogWrite(3,0);
    analogWrite(9,0);
    analogWrite(10,0);
    analogWrite(11,0);
    Serial.print("S");
i have 2 video's on my youtube channel of the bot in action. the first video is rather bad but proved to me that it did work. the second is of the current bot and the modified code above
first bot video
second bot video
as far as the code goes, i would like to add user control of the bot but simply have no clue. i have literally spent days looking for good information and can not seem to find anything of relevance.
thank y'all in advance.
"i would like to add user control of the bot but simply have no clue."
A wifi board might be used for the communication link.
