Barcode Scanner not working on portenta h7
I am trying to use a barcode scaner with my portenta h7 and it is saying that there can't be any software serial and if I remove it and try to use serial1 to define the TX and RX pins it still doesnt work. Any ideas?
#define Serial1
Serial1 (13, 14);
#include "SparkFun_DE2120_Arduino_Library.h"
DE2120 scanner;
#define BUFFER_LEN 40
char scanBuffer[BUFFER_LEN];
  Serial1.begin(115200);
  Serial.println("DE2120 Scanner Example");
  if (scanner.begin(Serial1) == false)
    Serial.println("Scanner did not respond. Please check wiring. Did you scan the POR232 barcode? Freezing...");
    while (1)
  Serial.println("Scanner online!");
  if (scanner.readBarcode(scanBuffer, BUFFER_LEN))
    Serial.print("Code found: ");
    for (int i = 0; i < strlen(scanBuffer); i++)
      Serial.print(scanBuffer[i]);
  delay(200);
I just did some more reserch and if anyone is looing for the code that works you can find it here!
credits to sanruskmv who figured it out for another project.
