BareConductive Stop Audio when not Touched
I am an artist using the BareConductive Touch Pad. I have a code (pictured) which is supposed to play audio when touched and stop the audio I am trying to play when the captive trigger isn't being touched but its not working. Can anyone help
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post error messages in code tags as it makes it easier to scroll through them and copy them for examination
You might be better off with a state machine approach.
I would like to help but I cannot read what you posted. Fo9llow @UKHeliBob suggestion and post the code appropriately.
You might find our new project interesting. It was created by/for artists like you.
Hello!
I´m replying to this forum - as fellow touchboard users - is anyone else having issues with uploading new code to their touchboard? As Bareconductive has discontinued their services / products, with it has also gone their Arduino Library. I suspect this is the reason I can´t upload any new codes onto my touch board, and I´m stuck with the .mp3 code.
Is anyone else having this issue? Is there a solution?
Thanks in advanced!
