Hello,
I have modified blink example as below. Using STM32 blue bill with ST link.
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
delay(10000); // wait for a second
My expectation is - LED should be on for 1 sec and should be off for 10 seconds? Is my understanding not right?
I see the opposite behaviour. - led on 10sec, off for 1 sec. can I ask why?
It's all a matter of how the LED is wired. If the LED were connected between the LED_BUILTIN pin and ground, then your expectation would be correct. However, in this case the LED is connected between LED_BUILTIN and Vcc, so when the pin is set LOW the LED turns on.
Don't make the mistake of thinking HIGH always means "on". HIGH and LOW are just arbitrary states. You might find your code is easier to understand and maintain if you do something like this:
const byte LEDOnState = LOW;
const byte LEDOffState = HIGH;
digitalWrite(LED_BUILTIN, LEDOnState); // turn the LED on
digitalWrite(LED_BUILTIN, LEDOffState); // turn the LED off
I am so sorry, what is that answer, like cheating? just swapping ? not good
digitalWrite(LED_BUILTIN, LOW); // turn the LED on (HIGH is the voltage level)
digitalWrite(LED_BUILTIN, HIGH); // turn the LED off by making the voltage LOW
I am using the STM32 blue pill's built in LED on PC13. I dont know if -" LED is connected between LED_BUILTIN and Vcc, ", but would like to how to confirm this.
krisferrari:
How is making an LED active LOW cheating? I can see you're still stuck on this HIGH == on thing. That's going to be detrimental to your progress in learning electronics if you can't get past it. Many circuits are active LOW.
krisferrari:
You already did confirm it with your sketch. You just don't seem to be willing to believe the results of your experiment.
