Basic: Function not executed
Hi there,
I am trying writing a basic function but for some reason the function is not executed and I can't figured out why. I wrote other simple functions before so I am :o . I may feel very dumb after the first reply, I know (don't troll me I just restarted some programing after stopping for 35 years). I can only see the loop printed messages but nothing from the called function. There is probably many issues in my program, just help me with this non executed function, the rest is my problem banging my old brain against C++.
Thanks!
// Convert UNIX time to human readable date and time
// Author: GA
#include <TimeLib.h>
long timeNow =  1552456800;
long timeLater = 1552467600;
static String convResult[4];
void setup(){
	while(!Serial) continue;
void loop(){
	if (Serial.read() == 'j') {
	Serial.println("Starting conversion 0");
	void dateTimeconv(String(timeNow), String(timeLater));
	Serial.println("Display result");
	Serial.println("Now Date: "+convResult[0]);
	Serial.println("Now time: "+convResult[1]);
	Serial.println("Later Date: "+convResult[2]);
	Serial.println("Later time: "+convResult[3]);
void dateTimeconv(){
	Serial.println("Starting date and time conversion");
	Serial.println("Conversion now");
	int minuteNow = minute(timeNow);
	String timeNowH = (String(hour(timeNow))+":"+printDigits(minuteNow));
	String dateNowH = (String(day(timeNow))+"-"+(String(monthStr(timeNow)))+"-"+(String(year(timeNow))));
	Serial.println("Conversion later");
	int minuteLater = minute(timeLater);
	String timeLaterH = (String(hour(timeLater)+":"+printDigits(minuteLater)));
	String dateLaterH = (String(day(timeLater))+"-"+(String(monthStr(timeLater)))+"-"+(String(year(timeLater))));
	Serial.println("Modif the array");
	convResult[0]=dateNowH;
	convResult[1]=timeNowH;
	convResult[2]=dateLaterH;
	convResult[3]=timeLaterH;
int printDigits(int digits) {
	// utility function if json time stamp returns with 0n or 00 minutes
	if (digits >= 0 && digits < 10){
		digits='0'+digits;
	else {
		digits='0'+'0';
	return(digits);
Here the dateTimeconv() function is not being called it is being declared. Remove the return type specifier at the beginning of the line
When you call a function you don't specify the return type (void) again, that's just in the function declaration.
Also in your main declaration of void dateTimeconv() you say it takes no parameters. But when you try to call it in loop() you try to pass two parameters to it - String(timeNow), String(timeLater). That's not going to work.
Steve
slipstick, slipstick,
Thanks for you replies. I remove the "void" calling the function and in the main declaration I used String dateTimeconv() and now I get Error: too many arguments to function 'String dateTimeconv()'
You need to do a bit of reading on functions. https://www.arduino.cc/en/Reference/FunctionDeclaration might help. It's really hard work trying to write C++ by just guessing.
The parameters are the bits in brackets after the function name. The return type is the thing before the name. String dateTimeconv() means it takes NO parameters but will RETURN a String.
Steve
slipstick:
I know, I have more ambitions than knowledge... Will dig the doc, will come back later
Thanks
since in this sketch you declare the variables before the "setup", they can be seen in the whole sketch, so no need to "passing" them in function
slipstick:
Steve
Thanks Steve
After some reading :wink: I modified my sketch. No complilation error, it is still not running but strangely I get different results depending on the Ardunio board I am using. On a UNO I can see only the "Starting conversion 0" message on the serial console but nothing from my function. On a MKR 101 "Starting conversion 0" from the loop(), and "Starting date and time conversion", "Conversion now" from my function but it seems that not all the function is executed. Code below. I commented large part of the function to insure that I am not messing in some way with the board performance.
demkat1 thank for your reply. It is just a test I need to learn and understand how to pass parameters to the function because this is how I will used it.
// Author: GA
void setup(){
void loop(){
dateTimeconv();
/* Serial.println("Now time: "+convResult[1]);
Serial.println("Later time: "+convResult[3]); */
// int minuteNow = minute(timeNow);
// String timeNowH = (String(hour(timeNow))+":"+printDigits(minuteNow));
/* Serial.println("Conversion later");
String dateLaterH = (String(day(timeLater))+"-"+(String(monthStr(timeLater)))+"-"+(String(year(timeLater)))); */
/* convResult[1]=timeNowH;
digits='0'+digits;
else {
digits='0'+'0';
return(digits);
Are you using Serial to both receive data and to print it to the Serial monitor ?
UKHeliBob:
No, I am only using Serial to print the message out. The Unix time string will come from a json data and some other parameters from a IC2 Adafruit board. These parts are already working, I just need to do the Unix time to Human readable format conversion. Even the Unix time conversion is working in the way as show below. But it is a learning exercise, I want something cleaner and more structured, so a function, and will display the data on a Web page not on the Serial Monitor.
Thanks
 Serial.print (F("Time & Date current: "));
 Serial.print("\t"+String(hour(timeNow))+":");
 printDigits(minuteNow);
 Serial.println("\t"+(String(day(timeNow))+"-"+monthStr(month(timeNow))+"-"+String(year(timeNow))));
 Serial.print("Time & Date prevision: ");
 Serial.print("\t"+String(hour(timeLater))+":");
 printDigits(minuteLater);
 Serial.print("\t"+(String(day(timeLater))+"-"+monthStr(month(timeLater))+"-"+String(year(timeLater))));
Finally running, I also found than my Arduino IDE was somewhere corrupt explaining abnormal incomplete Serial console output than made me really confused thinking my function was not working. I reinstalled the IDE but this time from the Arduino site not from the th Windows Store. Working code below. Thanks for your help.
// Author: GA
long timeNow =  1552975704;
long timeLater = 1552467611;
void setup(){
void loop(){
	dateTimeconv();
void dateTimeconv()
// Translate UNIX timestamp in human readable format
	String minuteNow = String(minute(timeNow));
	String minuteLater = String(minute(timeLater));
	String timeNowH = String(hour(timeNow))+":"+String(printDigits(minuteNow));
	String dateNowH = String(day(timeNow))+"-"+monthStr(month(timeNow))+"-"+String(year(timeNow));
	String timeLaterH = String(hour(timeLater))+":"+String(printDigits(minuteLater));
	String dateLaterH = String(day(timeLater))+"-"+monthStr(month(timeLater))+"-"+String(year(timeLater));
String printDigits(String digits)
// Adding leading 0 to time minutes
	if (digits == "0"){ // If the minute() function returned 0 minutes
	digits = "00";
	if (digits.length() == 1){ // If the minute() function returned more that 0 but less than 10 minutes
		digits="0"+digits;
	return digits;
