- I know this will sound very simple and maybe stupid to some users but i really need some help and simple instructions on making this project successful I really do not know much about bluetooth and electronics etc but i hope this makes since and would appreciate ANY HELP!
I want to build a device that can communicate via bluetooth with a simple off and on command to activate a motor full throttle.I have purchased a HC-05 model and need to know do i need a arduino board in order to program it to communicate with an android BT device.
* I will have a simple switch connected to a AAA battery holder connected to a simple 3v motor and need to add the bluetooth device within the circuit so that when the switch is on i can connect to the bluetooth module via and android app and be able to turn the motor off and on remotely.
*will this even work? would i have any voltage issues to where i would need to add a resistor? would the power from the AAA batter be to powerful?
- most importantly do I need an BOARD to use the HC-06 bluetooth device once coded and programmed or can it be a standalone device?
th Arduino board is to big to place in the project and the project has to be mobile.
*can I use an existing BT android app to control it?
