Hello!
Firstly, I know tomorrow is Thanskgiving, so to everyone who celebrates it, and however y'all do so, have a good Holiday!
So, re: al of this, I've asked questions, done quite a bit of searching and reading, and was ready to sit down and start plugging wires into my breadboard, but then, I crashed into another question.
What about the connection to Ground...?
A VERY few images show a connection from the LED cluster, to Ground. I think I found maybe three, but they're different from one another in diagramming the actual LED cluster.
Most do not show any connection to Ground.
Does that mean there is no connection between the LED cluster, and Ground...? Should there be one, or not? It's very confusing to me because I'd thought there always has to be a connection to Ground for the sake of safety. So I'm wondering which is correct, because sadly, I just cant tell.
Re: resistors:
Some sources have resistors associated with every LED, some showing them connected to the LEDs' anode pins, others to the cathode pins; other sources show one resistor at the start of each LED cluster/group, and still others put the resistors after everything.
I've thought that the resistor should be between the Voltage source, and the LED's anode, but now I'm confused abut that as well. Any clarification would be great!
Ultimately, I'm wondering:
Is there any sort of published standard, or a paper that's not overly esoteric, which can be followed? I know there are many brilliant people who can do the math and figure all of this out - sadly, I'm far from being one of them. ButI still would like very much to do the fairly-basic project I have in mind. And right now, I'm just totally and completely boggled. So if anyone has a link to a working standard, could you share the link or the book/paper title...?
Well, first of course, whatever you all do for Thanksgiving, I hope it's an enjoyable day tomorrow! ![]()
- Kris
