Basic Web Buttons Using Ethernet Shield
I have a working text button, but would like to make a more realistic button.
Working Button:
client.println("<a href=\"/?center\"\">CENTER</a>");
This is the button I am trying to get working:
client.println("<input type=submit name=center value=\"CENTER\">");
You didn't mention what's not working…
One thing worth fixing: unless you close the input tag, your browser may get cranky. Note carefully the extra / at the end, just before the closing '>':
client.println("<input type=submit name=center value=\"CENTER\"/>");
-br
Thanks! Yea, I guess I should have explained things a bit better. The first code example works great, but i want to replace it with the second code example. The first code is a text (link type) button, and the second code is a real button with text in it. The second piece of code shows up on the web page, but it does nothing. From my understanding it should work, but I am missing something. Since I am replacing one piece of code for another, I made sure to comment out the other. Can anyone please HELP.
My whole web page.
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println("Content-Type: text/html");
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Pan / Tilt Servo Test</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<h2> REMOTE SWITCH: </h2>");
          //client.println("<input type=range id=poop min=0 max=180 step=2 value=0>"); //Slider button for later
         //Servo1 movement
          client.println("<a href=\"/?right\"\">RIGHT</a>");
          //client.println("<a href=\"/?center\"\">CENTER</a>");
          client.println("<a href=\"/?left\"\">LEFT</a>");
          //servo2 movement
          client.println("<a href=\"/?up\"\">UP</a>");
          client.println("<a href=\"/?mid\"\">MIDDLE</a>");
          client.println("<a href=\"/?down\"\">DOWN</a>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(100);
          //stopping client
          client.stop();
Server button test code.
//zoomkat 8-04-12
//simple button GET server code to control servo and arduino pins 5, 6, and 7
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use ' instead of " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
///note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  pinMode(6, OUTPUT); //pin selected to control
  pinMode(7, OUTPUT); //pin selected to control
  pinMode(8, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("server multi pin button test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          client.println();
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          // For simple testing, pin 5, 6, 7, and 8 are used in buttons
          // DIY buttons
          client.println("<a href=/?on2 >ON</a>");
          client.println("<a href=/?off3 >OFF</a>");
          client.println("&nbsp;<a href=/?off357 >ALL OFF</a>
          // mousedown buttons
          client.println("<input type=button value=ON onmousedown=location.href='/?on4;'>");
          client.println("<input type=button value=OFF onmousedown=location.href='/?off5;'>");
          client.println("&nbsp;<input type=button value='ALL OFF' onmousedown=location.href='/?off3579;'>
          // mousedown radio buttons
          client.println("<input type=radio onmousedown=location.href='/?on6;'>ON</>");
          client.println("<input type=radio onmousedown=location.href='/?off7;'>OFF</>");
          client.println("&nbsp;<input type=radio onmousedown=location.href='/?off3579;'>ALL OFF</>
          // custom buttons
          client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?on8;'>");
          client.print("<input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?off9;'>");
          client.print("&nbsp;<input type=submit value='ALL OFF' style=width:100px;height:45px onClick=location.href='/?off3579;'>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf('2') >0)//checks for 2
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led 5 On");
          if(readString.indexOf('3') >0)//checks for 3
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led 5 Off");
          if(readString.indexOf('4') >0)//checks for 4
            digitalWrite(6, HIGH);    // set pin 6 high
            Serial.println("Led 6 On");
          if(readString.indexOf('5') >0)//checks for 5
            digitalWrite(6, LOW);    // set pin 6 low
            Serial.println("Led 6 Off");
           if(readString.indexOf('6') >0)//checks for 6
            digitalWrite(7, HIGH);    // set pin 7 high
            Serial.println("Led 7 On");
          if(readString.indexOf('7') >0)//checks for 7
            digitalWrite(7, LOW);    // set pin 7 low
            Serial.println("Led 7 Off");
            if(readString.indexOf('8') >0)//checks for 8
            digitalWrite(8, HIGH);    // set pin 8 high
            Serial.println("Led 8 On");
          if(readString.indexOf('9') >0)//checks for 9
            digitalWrite(8, LOW);    // set pin 8 low
            Serial.println("Led 8 Off");
          //clearing string for next read
          readString="";
zoomkat:
Thanks zoomkat, this is exactly what I was looking for, +1 for you!!!
